SDK12 nRF52 SPI master using DMA : rx_buffer not filled
Hello everyone,
I am currently trying to make simple exchanges with an NFC chip using SPI.
Configuration is: nRF52 on dev board 10040 with example from SDK12 located in peripheral\spi.
I am using configuration already present which is SPI0 with Easy DMA enabled. Although, I changed the PIN assignments :
#ifndef SPI_SCK_PIN
#define SPI_SCK_PIN 12
// <o> SPI_MISO_PIN - Pin number  <0-31>
#ifndef SPI_MISO_PIN
#define SPI_MISO_PIN 14
// <o> SPI_MOSI_PIN - Pin number  <0-31>
#ifndef SPI_MOSI_PIN
#define SPI_MOSI_PIN 13
// <o> SPI_SS_PIN - Pin number  <0-31>
#ifndef SPI_SS_PIN
#define SPI_SS_PIN 15
Here follows my SPI configuration:
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin   = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin  = SPI_SCK_PIN;
spi_config.mode = NRF_DRV_SPI_MODE_1;
spi_config.frequency = NRF_DRV_SPI_FREQ_125K;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler));
I am trying to read a bunch of registers values by sending 2 bytes (one for the command and one for the register number) and receive 4 bytes as a response. So main loop is looking like that:
uint8_t block = 0x00;
static uint8_t       m_tx_buf[] = {0x7f, 0x02, 0,0,0,0};           /**< TX buffer. */
static uint8_t       m_rx_buf[7];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0x55, m_length);
        spi_xfer_done = false;
        m_tx_buf[1] = block;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, 6));
        NRF_LOG_DEBUG("Received :");
        NRF_LOG_HEXDUMP_DEBUG(m_rx_buf, 6);
        while (!spi_xfer_done)
            __WFE();
        block += 2;
        block %= 16;
        NRF_LOG_FLUSH();
        LEDS_INVERT(BSP_LED_0_MASK);
        nrf_delay_ms(200);
I filled the reception buffer with 0x55 on purpose to be sure that I am not reading some 0x00 by mistake or misinterpretation of the MISO line. And by the following RTT log I can confirm that no data has been written in the rx buffer after SPI transaction:
SPI:DEBUG:Tx data:
SPI:DEBUG:
7F 00 00 00 00 00                                ......
SPI:DEBUG:Disabling list for RX
APP:DEBUG:Received :APP:DEBUG:
55 55 55 55 55 55                                UUUUUU
APP:INFO:Transfer completed.
SPI:INFO:Transfer tx_len:6, rx_len:6
SPI:DEBUG:Tx data:
SPI:DEBUG:
7F 02 00 00 00 00                                ......
However, if I trace what happens indeed on the lines, I see the response :
image description
I cannot find what I did wrong. The LIST is not enabled but I don't see the point as I only have few bytes to exchange. I was not able to find where this RX buffer is supposed to be filled.
I tried different frequencies from 1M to 125K, nothing is changing. I tried the blocking mode by not providing the handler during the init, no better result. I tried to change SPI instance to 2 to be inline with PIN definitions... nothing helps...
What can I do to find my error?
Thank you for your help
  • The data is supposed to go into the rx buffer just as you have set it up there. Simplest option, single step through the code to find out what's being written to the SPI registers and ensure it's where your buffer actually is.
    Also, after the transfer is done, check the registers on the SPI to see where the pointer was set, what length was set and how many bytes it received. Go look at the memory.
    I don't see anything wrong with the code, if the pin wasn't specified properly you'd just clock in 0x00 so having 0x55 remaining in the buffer afterwards doesn't appear to be possible.
  • Ok, so I found my problem.
    Actually the first reception was OK, but the rest of them during the loop run were not. Probing a longer time indicate me that the MISO line was not driven properly, so nothing could be red...
    Problem was on my NFC chip.
    Sorry to be bothering for nothing. Thank you anyway.
