Problem programming custom PCBs on nrf51822
Hi, I tried my best to solve my problem via forum but unfortunately no success. I got nrf51 DK and played with it a lot. successfully program the samples and tweak them a bit. using SDK 5.1 and s110 v6.
The problem starts when I try custom boards. I have made one based on QFAAC0 for which:
I have same problem with a board I purchased online, PTR5528 which is based on CEAA . Can program blinky but no BLE.
Is there something that I am doing wrong. I did connect the board to 3 V and connected the segger programmer pins as explained in the forum (That's how I program without an error)
Thanks in advanced for your help, Ali
  • OK, since you didn't explicitly mention it, have you loaded the Soft Device into your custom board using nRFgo Studio? You'll need to do that (at least once) as a separate step for your custom device.
  • Sorry if was not clear enough, Yes. I did load the soft device. I programmed the hex file for the soft device and the output hex file of the keil through nRFgo. This worked fine with DK breakout boards and EK board. I sucessfully loaded Blinky, Hrs and proximity examples on these boards using SDK 5.1 and s110 v6.
    When I try my own pcbs, I know that I should go to lower versions of SDK and soft device, I installed SDK 4.4.2 (and 4.4.1) and compiled the examples through keil. Flashed s110 v5 (and then v5.2) and the keil output through nRFgo studio, but unfortunately the BLE examples does not run on my boards while the blinky works just fine.
  • OK, good. Since blinky runs your custom board hardware is generally OK & this could be a Soft Device resource issue. I got bit at first because the custom board I was working with didn't have a 32 KHz crystal, so no BLE (SD-dependent) stuff worked until I changed the clock designation in ble_stack_init(). Since the advertising LED isn't even blinking (assuming you redefined the pin selection for your board) I'd guess that one of your SD stack calls is failing. You might want to modify the app_error_handler() & see if you can break there & get a stack trace. Good luck!
  • Thanks for the suggestion, I did add the proper lines for internal 32 kHz . NRF_CLOCK->XTALFREQ = CLOCK_XTALFREQ_XTALFREQ_16MHz; NRF_CLOCK->EVENTS_HFCLKSTARTED = 0; NRF_CLOCK->TASKS_HFCLKSTART = 1; while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) {} nrf_gpio_pin_set(ALERT_PIN_NO); //use this pin to check if program halts BLE_STACK_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_8000MS_CALIBRATION, BLE_L2CAP_MTU_DEF, ble_evt_dispatch, false);
    The program runs smoothly on PCA10006 when I disconnect the external 32khz oscillator but when I test the same hex file and stack on my custom board, it stops in the while loop, i.e. the HF Clock does not start. any Idea? (The PCA10006 uses a QFAAG0 chip while mine is QFAAC0, use s110 v5.2.1 and SDK 4.4.2 that are supposed to be compatible with both chips according to the compatibility table of RM)
  • I'm having similar trouble with QFAAC0, it basically hangs on the SOFTDEVICE_HANDLER_INIT code... same sequence of loading works fine on the DK board (newer/diff rev chip)...
    I'm running s110 v6 ..... bit annoying as I've just picked up 10 of these little boards to use and dead in the water with them at the mo.
    Did you have any resolution to this problem?
