Hello, I want to change mode from radio test example from button input. How can I use the gpiote for mode change from button input. I only want to use modulated and unmodulated certain fixed channel. Thank you.
The easiest way to do an action upon a button push is to use the button handling library. Its API reference can be found here.
Yes, it is sufficient to call radio_tx_carrier(..) to transmit an unmodulated carrier. As the documentation shows, the radio will transmit unmodulated carrier when in IDLE. TASKS_START will start modulated carrier.
Yes, the link you linked to is not entirely correct, it is not necessary to call radio_tx_sweep_start.
