When i used board 0 extension board to program nRF24LE1 QFN24 OTP/Flash. it notification of error "An error occured when programming the infopage of board 0". What's that meaning ?
Could you read the laser marking on top of the chip ? I guess your chip is not OTP ?
Please answer my questions above. Also which firmware were you trying to flash ? Could you try to test with a very simple example say blinking an LED ? And give me the hex if you still have issue with it.
Hi Hung Bui, The laser marking is "NRF 0 24LE1I 1240BC" Thanks Roderick
Hi Hung Bui, Hex code update on title page called "Test1.hex" Thanks Roderick
Could you click on Advanced Setting and make sure you don't check "Enable hardware debugging" and "Block readback of main memory".
Also please test with simple application such as blinking LED. Note that you are using OTP chip, so it could be wise to test first with normal chip.
Hi Hung Bui, I'm used board 0 > extension - nRF24LE1 QFN24 OTP/Flash to program the chip. This is the simple way to program the code to nRF chip. We don't understand why there is keep notify us the error on programming the infopage of board 0. I also confirm there is no tick on "enable hardware debugging. i try tick the Block read back of main memory and then it can load the code into the chip. Is it any affect the code?
