difference between tx carrier modulated and not
Hi All,
I need to certificate the nrf52 to Fcc. I understood that the radio test is very useful. I try to clarify what the code permit to do, because i want to adapt it for the test. In particular, i don't understood the difference between the
  • Start TX Carrier and Start Modulated TX carrier.
Instead of The tx sweep permit to change the channel of transmission after a time that we can insert with command d ( Enter time on each channel (1 ms - 99 ms)). The same is for the RX channel, correct?
A last question is about the power. How Can i set the transmission power to max power?
thanks, Anna
