Power Off mode
Can you explain what differences (if any) there are between using sd_power_system_off() function versus NRF_POWER->POWEROFF = 1 to put the device into power off mode?
I have an application where I check the battery voltage upon power up and don't let the device fully boot up if the battery is too low. Since the soft device isn't init'd I think I am forced to use the NRF_POWER->POWEROFF register to enter power off mode.
I also monitor the battery voltage under normal operation and if it goes too low I put the device into power off mode. In this case, the soft device is init'd and I'm still just using the NRF_POWER register. Is there any downside to entering power off mode in this way? What differences are there between these two methods?
This is with an NRF51822 and S110.
Thanks
