On the nRF51822 Is it possible to check the battery level using the on-board AD, software connected internally, avoiding external resistor divider. If not what is the best method, hardware and software? Jim
I use CR2032 coin cell, the same question from me.
If you have a battery that has a nominal voltage above the maximum supply current of 3.6V, then you will have to add an external voltage divider in order to measure the battery voltage, as described in this blog post.
If the batter has a nominal voltage below 3.6V then you can use the ADC measure the battery voltage directly, see this github repo for ADC examples for the nRF51 series.
Best regards
Bjørn
But note that measuring the battery voltage may not give any useful indication of the remaining battery life!
Take a look at the graphs in this post to see why!
OK thanks for the responses, is there an alternative then awneil?
