DFU reconnect problem
Hi!
I am having trouble with DFU. When I try to send new application via NrfConnect, device goes to bootloader, but file transfer is not starting. Only when I reconnect and try again, while device is in bootloader, transfer goes through. DFU code for bootloader and main application is taken from ble_app_hrs.
I have seen similar errors on forums all around, but it was not helpful.
Processor is nrf51822QFAA Softdevice: s130 v2.0.1 nrfConnect: v4.11.0 for Android Phone/Android: Nexus 6p, 7.1.2
This is log file of nrfConnect before entering bootloader: before_bootloader.txt
And this is log file of nrfConnect after reconnecting while device is in bootloader: while_in_bootloader.txt
I will appreciate any suggestion. Thank you in advance.
Best regards
  • Ok. I have tried, but with no success. I guess problem is somewhere in code.
    I am using UICR_ADDR_0x84 and 0x88 for holding info about device serial number; do you thing this could mess things with DFU?
    Another thing is - DFU procedure correctly starts bootloader, and bootloader correctly carries on DFU update. Only thing missing is detection of active bootloader from the nrfConnect side. Somwhere I have read that this is maybe due to different address of bluetooth device while in bootloader. How can I send info to DFU to expect different device address?
  • I found it. Problem was in bootloader. File dfu_ble_svc.c has to be configured in Keil in following manner: Right click on file, select "options for dfu_ble_svc.c" and set IRAM2 for Zero Initialized Data.
    Hopefully, someone will find this helpful :)
    Bjorn, thank you again for patience! Have a beautiful weekend!
    Best regards, Sejl
