dim led to minimize current consumption
Hello, I am using nrf52832 custom board, with SDK 11.0.0 and s132_nrf52_2.0.0 and trying to dim led. It seems the only suggested solution is to use the pwm driver. I was wondering if there are any other simpler solutions?
My use case is to set led brightness to a min value to save current consumption.
Looking at a similar post I was able to follow the pwm_driver examples as well as suggestion in this link: devzone.nordicsemi.com/.../
  • However, it requires hardcoding the duration or setting the playback in continuous loop, also I do not need to gradually step up or down the brightness via a seq_values array and playback mechanism. Appreciate any suggestions.
  • The other issue I have seen with the example is that during resource intensive operations like flash write the driver doesn't seem to function, as the flash write fails also the playback stops much sooner than the set duration, possibly due to high cpu usage. Please confirm if this is expected.
Thanks in advanced.
#define LED_DIM_VALUE               900                                 /**< Brightness scale: 0->max, 1000->min. >**/
static nrf_drv_pwm_t                m_pwm0 = NRF_DRV_PWM_INSTANCE(0);   /**< Create an instance of PWM driver. >**/
static volatile bool                m_used = false;                     /**< PWM driver initilization status. >**/
void led_pwm(int pb_cnt)
    uint32_t err_code;
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            LED_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 0
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 1
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
        .irq_priority = APP_IRQ_PRIORITY_LOW,
        .base_clock   = NRF_PWM_CLK_125kHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = 1000,
        .load_mode    = NRF_PWM_LOAD_COMMON,
        .step_mode    = NRF_PWM_STEP_AUTO
    if(m_used)
       nrf_drv_pwm_uninit(&m_pwm0);
       m_used = false;
    err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);
    m_used = true;
    // This array cannot be allocated on stack (hence "static") and it must
    // be in RAM (hence no "const", though its content is not changed).
    static nrf_pwm_values_common_t seq_values[] =
       LED_DIM_VALUE
    nrf_pwm_sequence_t const seq =
       .values.p_common = seq_values,
       .length          = NRF_PWM_VALUES_LENGTH(seq_values),
       .repeats         = 100,
       .end_delay       = 0
    nrf_drv_pwm_simple_playback(&m_pwm0, &seq, pb_cnt, NRF_DRV_PWM_FLAG_STOP);
    nrf_gpio_pin_clear(LED_PIN);
The duty cycle above would be 50% and the max playback duration I use is ~10 sec.
  • No, there is no real "simpler" solution then to alter GPIO high and low on the output line towards LED in time faster then your eye can notice so the effective duty cycle (time when line is HIGH divided by total time of one HIGH/LOW period) will determine how much "dim" it will look like. Now PWM is pretty straight forward solution as it should be able to run autonomously (thanks to things specific for nRF52 such as EasyDMA and PPI Tasks&Events) and thus no other activity should impact it (unless it blocks MCU for longer time then you can "program" in PWM registers). Quote from PWM driver documentation on Infocenter:
    Key features include:
    • Multi-instance support
    • Two kinds of playback:
      • Simple: a single sequence of duty cycle values
      • Complex: two concatenated sequences
    • Sequences are played back a specified number of times
    • Optionally, the whole playback can be repeated in a loop
    • A user-defined event handler can be used to perform additional actions when a sequence or the whole playback is finished
    • If no event handler is used, playbacks can be carried out without involving the CPU
  • My golden rule so far is: if I don't understand how certain HW peripheral works, then I stick to SDK example (because Nordic guys know much better). I'm not sure if your code is not going too far from SDK without controlling the situation.
