dim led to minimize current consumption
Hello, I am using nrf52832 custom board, with SDK 11.0.0 and s132_nrf52_2.0.0 and trying to dim led. It seems the only suggested solution is to use the pwm driver. I was wondering if there are any other simpler solutions?
My use case is to set led brightness to a min value to save current consumption.
Looking at a similar post I was able to follow the pwm_driver examples as well as suggestion in this link: devzone.nordicsemi.com/.../
  • However, it requires hardcoding the duration or setting the playback in continuous loop, also I do not need to gradually step up or down the brightness via a seq_values array and playback mechanism. Appreciate any suggestions.
  • The other issue I have seen with the example is that during resource intensive operations like flash write the driver doesn't seem to function, as the flash write fails also the playback stops much sooner than the set duration, possibly due to high cpu usage. Please confirm if this is expected.
Thanks in advanced.
#define LED_DIM_VALUE               900                                 /**< Brightness scale: 0->max, 1000->min. >**/
static nrf_drv_pwm_t                m_pwm0 = NRF_DRV_PWM_INSTANCE(0);   /**< Create an instance of PWM driver. >**/
static volatile bool                m_used = false;                     /**< PWM driver initilization status. >**/
void led_pwm(int pb_cnt)
    uint32_t err_code;
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            LED_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 0
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 1
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
        .irq_priority = APP_IRQ_PRIORITY_LOW,
        .base_clock   = NRF_PWM_CLK_125kHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = 1000,
        .load_mode    = NRF_PWM_LOAD_COMMON,
        .step_mode    = NRF_PWM_STEP_AUTO
    if(m_used)
       nrf_drv_pwm_uninit(&m_pwm0);
       m_used = false;
    err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);
    m_used = true;
    // This array cannot be allocated on stack (hence "static") and it must
    // be in RAM (hence no "const", though its content is not changed).
    static nrf_pwm_values_common_t seq_values[] =
       LED_DIM_VALUE
    nrf_pwm_sequence_t const seq =
       .values.p_common = seq_values,
       .length          = NRF_PWM_VALUES_LENGTH(seq_values),
       .repeats         = 100,
       .end_delay       = 0
    nrf_drv_pwm_simple_playback(&m_pwm0, &seq, pb_cnt, NRF_DRV_PWM_FLAG_STOP);
    nrf_gpio_pin_clear(LED_PIN);
The duty cycle above would be 50% and the max playback duration I use is ~10 sec.
  • Thanks for your help endnode, can you please provide more information about: "unless it blocks MCU for longer time then you can "program" in PWM registers". How can I check this? Please see the routine I am using above. I am using one instance of the pwm driver. And do not use handler that could block for a longer period. Would high duty cycle affect programming of registers?
  • Hi Sal, normally in embedded systems you initialize all HW (drivers) first during the boot and then you only run "safe" functions like start/stop. To the RTT tracing: have you ever made it work? If not then it looks like dangerous idea to debug it on custom code which is not known to be stable etc., rather make it work according to tutorials on something stable coming directly from SDK and then carefully port it to your project, step by step.
  • Sorry, I'm not good in imagining just in my head how bunch of code works and I don't have time to test your code so I'm not sure what interrupts you really need to make your ode running continuously. In general all interrupt handling might get delayed if there is some higher priority execution blocking it, which might be the case when you use BLE stack (Soft Device) and it needs to do some radio-related processing. These things typically don't take more than 1-2ms, in extreme cases it can be 5~6ms or even more (if you use PDU extension + high throughput link and "stream" some data through the connection event). But I bet this is not really the problem for you right now so let's first make your code work in basic scenario (= FW boots and LED starts to dim and brighten with given period) and then you can test advanced use cases.
  • My golden rule so far is: if I don't understand how certain HW peripheral works, then I stick to SDK example (because Nordic guys know much better). I'm not sure if your code is not going too far from SDK without controlling the situation.
