nRF52840 TWIM
First try to create a TWIM driver from scratch without any DMA. Following the steps in the OPS I get mixed behavior and only the chapter with DMA generates any clock and data on the interface. Without setting Master enable bit nothing will start and there is no reference in the non DMA flow diagram. Anyhow when using Master bit I get all TXD data on the bus but not RXD.
I use Prev-DK board with SDOF Stick connected to P0.27/P0.26 at 100kHz.
This is my flow right now:
// ***** INIT *****
#define USED_I2C_BLOCK 0x40003000
output_32( USED_I2C_BLOCK+I2C_TXD_MAXCNT_REG, 2 );
// enable master mode
output_32( USED_I2C_BLOCK+I2C_ENABLE_REG, 1 );
// ***** TRANSMITT *****
// send start condition
output_32( USED_I2C_BLOCK+I2C_STARTTX_REG, 1  );
// wait for int
// write data (slave address)
output_32( USED_I2C_BLOCK+I2C_TXD_REG, (SlaveAddress<<1) );
// wait for int
// write data (register address)
output_32( USED_I2C_BLOCK+I2C_TXD_REG, RegAddr );
// wait for int
// send stop bit
output_32( USED_I2C_BLOCK+I2C_STOP_REG, 1 );
// wait for int
// ***** RECEIVE *****
output_32( USED_I2C_BLOCK+I2C_RXD_MAXCNT_REG, DataBufferSize );
output_32( USED_I2C_BLOCK+I2C_STARTRX_REG, 1 );
// wait for int
// send read slave address
output_32( USED_I2C_BLOCK+I2C_TXD_REG, (SlaveAddress<<1)+1 );
// wait for int
while ( DataBufferSize-- )
	if ( DataBufferSize == 0 )
		// send stop bit
	// wait for int
	// read data
	*DataByte++ = input_32( USED_I2C_BLOCK+I2C_RXD_REG );
    Assuming that your output_32() function is bug free;
    1. Are you sure it is necessary to left shift the slave address?
    2. Do you really need to add 1 to the address when reading from a slave? The TWI module takes care of that.
    3. Where do you set the TX and RX buffer?
    Here is one way to use do a "bare bone" TX/RX transfer:
    static void twi_transfer()
        NRF_TWIM0->ENABLE = TWIM_ENABLE_ENABLE_Disabled << TWIM_ENABLE_ENABLE_Pos;
        NRF_TWIM0->SHORTS = (TWIM_SHORTS_LASTTX_STOP_Enabled << TWIM_SHORTS_LASTTX_STOP_Pos) |
                            (TWIM_SHORTS_LASTRX_STOP_Enabled << TWIM_SHORTS_LASTRX_STOP_Pos);
        NRF_TWIM0->PSEL.SCL = MPU_TWI_SCL_PIN;
        NRF_TWIM0->PSEL.SDA = MPU_TWI_SDA_PIN;
        NRF_TWIM0->FREQUENCY = TWI_FREQUENCY_FREQUENCY_K400;
        NRF_TWIM0->ADDRESS = MPU_ADDRESS;
        NRF_TWIM0->TXD.PTR = (uint32_t)&p_tx_buffer;
        NRF_TWIM0->TXD.MAXCNT = 1;
        NRF_TWIM0->RXD.PTR = (uint32_t)&p_rx_buffer;
        NRF_TWIM0->RXD.MAXCNT = 1;
        NRF_TWIM0->ENABLE = TWIM_ENABLE_ENABLE_Enabled << TWIM_ENABLE_ENABLE_Pos;
        NRF_TWIM0->EVENTS_LASTTX = 0;
        NRF_TWIM0->TASKS_STARTTX = 1;
        // Wait for TX to complete
        nrf_delay_us(100);
        NRF_TWIM0->TASKS_STARTRX = 1;
    You can also use:
    NRF_TWIM0->SHORTS = (TWIM_SHORTS_LASTTX_STARTRX_Enabled << TWIM_SHORTS_LASTTX_STARTRX_Pos)
    To start an RX immediately after the TX is completed.
    I don't know what is going on inside output_32(), but you seem to know how to use register base addresses and register offsets, so I think the above code should be easy for you to port.
    EDIT: The above code will produce the following action on the TWI bus: image description
    You can see that the TWI module takes care of left shifting of your 7-bit address and adds the READ bit automatically.
    EDIT 2: I have reviewed the case again and noticed a few more things that I didn't see initially:
    Since you talk about DMA and use the I2C_TXD_MAXCNT_REG register, but at the same time also talk about using TRD/TXD registers directly it sounds like you are cherry picking features from the legacy TWI module and the new TWIM module.
    • The legacy TWI module is basically "copy-pasted" hardware from the nRF51. It has a lot less features than the new module in nRF52. It does not have any DMA features for example. If you want to use the legacy module and use TXD/RXD registers directly you can only use the features available in this particular module. Legacy TWI documentation. With the legacy module you will have to update the TXD register for every byte you want to send.
    • The new module in nRF52 is an extension of the legacy module and hence shares some of the same registers. If you want to use DMA you will have to use the features documented here and you cannot use RXD/TXD directly.
  • Yes the output/input works (used for 20 years, no change ;)
    I’m not using DMA and I guess that you do not need to set the pointer to TX/RX and directly read from the TXD/RXD. Also the chapter without DMA do not describe this part.
    No the controller do not add the READ bit so I have to add it. I shift the slave address because it’s an 7-bit address.
    I will try your approach because it’s more simple then my more complex implementation. If everything are handle in hardware I do not have to do it manually that I’m currently doing now.
    If you need more info or missing defines I can add them to the thread.
  • It did not work. The interface pins goes low when master mode is enabled and that’s it, nothing more.
    Just to make sure I did it right I give you the change below including the defines.
    // register map
    #define I2C_STARTRX_REG		0x0000
    #define I2C_STARTTX_REG		0x0008
    #define I2C_STOP_REG		0x0014
    #define I2C_SUSPEND_REG		0x001C
    #define I2C_RESUME_REG		0x0020
    #define I2C_STOPPED_REG		0x0104
    #define I2C_RXDREADY_REG	0x0108
    #define I2C_TXSENT_REG		0x010C
    #define I2C_ERROR_REG		0x0124
    #define I2C_BB_REG			0x0138
    #define I2C_SUSPENDED_REG	0x0148
    #define I2C_RXSTARTED_REG	0x014C
    #define I2C_TXSTARTED_REG	0x0150
    #define I2C_LASTRX_REG		0x015C
    #define I2C_LASTTX_REG		0x0160
    #define I2C_SHORT_REG		0x0200
    #define I2C_INTENSET_REG	0x0304
    #define I2C_INTENCLR_REG	0x0308
    #define I2C_ERRORSRC_REG	0x04C4
    #define I2C_ENABLE_REG		0x0500
    #define I2C_PSEL_SCL_REG	0x0508
    #define I2C_PSEL_SDA_REG	0x050C
    #define I2C_RXD_REG		0x0518
    #define I2C_TXD_REG		0x051C
    #define I2C_FREQUENCY_REG	0x0524
    #define I2C_RXD_PTR_REG		0x0534
    #define I2C_RXD_MAXCNT_REG	0x0538
    #define I2C_RXD_AMOUNT_REG	0x053C
    #define I2C_RXD_LIST_REG	0x0540
    #define I2C_TXD_PTR_REG		0x0544
    #define I2C_TXD_MAXCNT_REG	0x0548
    #define I2C_TXD_AMOUNT_REG	0x054C
    #define I2C_TXD_LIST_REG	0x0550
    #define I2C_ADDRESS_REG		0x0588
    output_32( USED_I2C_BLOCK+I2C_ENABLE_REG, 0 );
    output_32( USED_I2C_BLOCK+I2C_SHORT_REG, (1<<12) | (1<<9) );
    output_32( USED_I2C_BLOCK+I2C_ADDRESS_REG, (SlaveAddress<<1) );
    output_32( USED_I2C_BLOCK+I2C_TXD_PTR_REG, 0x20021000 );
    output_32( USED_I2C_BLOCK+I2C_TXD_MAXCNT_REG, 1 );
    output_32( USED_I2C_BLOCK+I2C_RXD_PTR_REG, 0x20020000 );
    output_32( USED_I2C_BLOCK+I2C_LASTTX_REG, 1 );
    TIMER_Timer_Delay( 100000 );
  • Please see the edit in my previous answer. Also, have you tried the twi_scanner example in the SDK? It is useful for making sure that everything is wired correctly and working properly. It will also show you what address to use in your code.
  • Yes I did test the setup with a I2C-USB cable connected to the SDOF stick, so I know that I have the right device address. I have not setup any Nordic environment so I cannot test your test code.
    In my case with your code converted to my source I do not get anything more then low pins.
    I will try to change the drive strength but in my first code example TXD worked!?
