Help for a voltage regulator
I need a voltage regulator to power a microphone at 1.3V from a 3V coin cell battery and I was looking for a regulator like the lm317, but with this one the minimum output voltage is 2.5V+input voltage, so it's not suitable for my application. Do you know other voltage regulatorthat fits with this?
Thank You
  • You could look at LP5951, but pay attention to the Vdo (the dropout voltage). But then the power dissipated is (Vin-Vout)*(Iout) which would be (3-1.3)*Iout which would be dependent on the microphone current consumption. There is quiescent current of 30nA which would be the constant drain due to this part. Or you could use a DCDC converter like the MAX1556/7 which would be more efficient when operating the microphone but has a higher quiescent and shutdown current. You should do the average battery consumption calculations for both scenarios (LDO vs DCDC) over the lifetime of the battery (as its voltage drops from 3V) to decide
  • I use the micrel LDOs for almost everything, they're cheap and reliable and did I say cheap?
    The 1.3 one is MIC5365-1.3YC5-TR, mouser has them here but you can get them anywhere.
    As guruprasad says you need to watch the power dissipated to make sure you don't overheat the regulator. The thermal resistance of those micrels is about 250W/C, the max junction temperature 150C. So if you're running at 25C you have 125C of headroom. That gives you 1/2W you can drop through the LDO which means a current of about 300mA max. That series is designed for 150mA output although the only actual limitation I've seen is the junction temperature.
    From the regulator you mention in the original question it looks like you want < 100mA anyway so you're fine with this regulator. Oh and did I mention .. it's really cheap.
  • Thank you for the reply. Is this available only in smd package? I was looking for a tht one.
  • That one is SMD only - sorry I took the plunge a few years ago and never went back. There's a microchip one which comes in different packages including TO, I've used the SMD version of that one and it works also fine (I switched to micrel for cost reasons).
    this is it but it seems hard to find.
