BLE disconnection does not finish
Hi, I am working on the latest version of SDK (v14) and SoftDevice(v5) on nRF52382. When I call the sd_gap_disconnect it returns NRF_SUCCESS. However the BLE_GAP_DISCONNECT event is not called and the system resets. I checked the reset reason in the power registers and it returns a 4. i.e. a soft reset. The issue here is the disconnection process starts but does not finish, The disconnect event occurs if the nrf_connect app is turned off from the phone. Any reasons for the odd behavior in the first case ?
  • Have you tried to put a breakpoint in the error handler? If yo get an error it will reset the device.
  • The cause for the reset was an Internal error. This error came from the ble_conn_params.c file. The function which returned this error is ble_conn_params_init. The timer at the end is initialized once at the beginning and fails the next time we call the params_init function. Handling the internal error fixed the problem.
  • Could you give any clarification as to why the params_init function should be only called once. The re-initialization worked in the previous SDK.
  • I'm sorry, I don't know the details behind this change. Could you explain a bit more about what you want to achieve by calling it twice?
  • It is a part of a series of steps such as re-enabling the stack, initializing the gap parameters, advertising data etc. which are performed when the board wakes up or when it enters pairing mode. So the parameters were re-initialized every time when the board entered pairing mode. As I said earlier, this worked in the previous SDK, however the new one doesn't allow so because the change in the new SDK is that the timer in ble_conns_params_init is being called inside a loop.
