PCA20014 solar beacon fimware and HW questions
Hi, I'm deeply interested about the Nordic's PCA20014; a.k.a solar beacon.
This HW uses
PCA20014Schematic
My main concern is using the solar cell with the nRF52 MCU.
In my case, I was thinking of combining the PCA20014 with an I2S Amplifier (MAX98357A).
These are my questions for my investigation before purchasing the PCA20014;
0.Is there a reason for drawing the solar cell as an LED?
LEDSchematic
At first glance while looking at U2 and the solder bridge, I thought there was an LED that was connected backward.
1.Calculating the voltage dividing resistors, I think the solar cell needs to be charged up to 3V to exceed each gate threshold voltages.
Is there a reverse polarity issue while using the solar cell?
Using my shallow knowledge, I learned that PFETs are mostly used for reverse polarity protection.
I'm curious of the purpose for using 2 PFETs and a NFET.
2.Do these MOSFET works as a voltage regulator?
After opening PFET's gate 2, the divided voltage, 1.5~1.8V will be fed to VDD_nRF, I guess.
I don't see any DC-DC converter or voltage regulators in the schematic.
Does this mean that the voltage provided to the nRF MCU and the pressure fluctuates if the light level changes?
If so, I'm curious whether the MCU can do the job.
3.Since I will be adding an I2S amp, using a bigger solar cell and adding a buck converter will be better for me instead of using the above MOSFETs, right?
4.Switch on/off the external crystal.
The aforementioned statements are written in the Nordic's Infocenter.
Does this mean that this firmware doesn't use the Nordic's SoftDevice and turns on and off the 32MHz, the high-frequency clock, for power saving in the application?
I did check that the GitHub code uses RADIO_IRQHandler.
-Best Regards, MANGO
  • Hi Mango,
    Still slightly uncertain why the solar cell is being drawn as a diode. I will get back to you on that. From what I've seen, solar cells tend to be drawn like a battery, but with an arrow pointing towards them to signify that it is a solar cell & is dependent on sunlight, unlike a normal battery.
    As for the reverse polarity issue, it seems this can become an issue, especially when multiple solar cells are connected in series (see this forum & this link). Since you are only using one solar cell (am I correct?), I am still a bit uncertain whether you will require a bypass diode.
  • Figured out why the solar cell is drawn as a diode. Have a look at this wikipedia article on photodiodes. A solar cell is just a large area photodiode!
  • Hi, Bjørn Kvaale. That's really interesting! I have learned a lot from the devteam.
    Can you check other things such as
    • is PCA20014 using one or multi-solar cell(s)
    • need for DC-DC converter for nRF MCU and I2S amp
    • PCA20014 firmware code
    If this is a multi-cell solar cell, I think I should consider the reverse polarity.
    -Best Regards
  • I am pretty sure the Amorton AM-1417CA is one solar cell, so reverse polarity might not be such a big issue. In the description, it says solar cell and not solar cells. But you could send digikey, another supplier or the manufacturer a quick message to be certain. The PCA20014 firmware code can be found here. Since the nrf52832 has an integrated DC-DC converter, you will not need any power management for the PCA20014. As for the I2S amp, you might need a DC-DC converter (the I2s amp you refer to can handle 2.5-5.5 V input supply, see here). Consider sending Adafruit tech support a quick message to confirm. What are you planning to do if there is no sunlight, i.e. no input voltage from solar cell? Do you want to hook up a battery or will no sound play?
  • As for your question regarding not seeing any DC-DC converters in the schematic, the nrf52832 chip has an integrated DC-DC converter (see here, under section "Flexible Power Management".) So therefore I do not think that the Mosfets work as voltage regulators. Due to the integrated DC-DC converter in the nrf52832, the voltage level will not fluctuate if light intensity fluctuates (make sure the input voltage is within supply voltage of nrf52832, see here)
