When I use keil to download the software to the chip, there are two questions:
- like attached. 2.NRFGO CAN'T SEE J-LINK LITE CORTEXM BOARD Is there any way to solve these problem? Many thanks
Which project are you working with? It seems the debugger configuration is wrong, since it's complaining that it can't find a ULINK device. The SDK projects should be set up to use J-Link by default. If you still have problems with this, I'd recommend you to reinstall Keil, the Segger drivers and finally the SDK.
Thank you for your kindly reply. I have solved the problem.
Good! For future reference, it would have been nice if you could either accept this answer if it was helpful, or post what you did to solve it separately, and then accept your own answer. :-)
