hi i am using nrf52 dk wiht IAR embedded workbench IDE ARM 8.20.1 i want to disable the attach to running target from my device HZX-52832-S01A. which bit i have to turn off to disable the attach to a running target?
thank you,
Amer
thank you,
Amer
Hi Amer, Could you clarify, do you want to debug and flash the module HZX-52832-S01A instead of flashing the nRF52DK , correct ?
If you connect SWD interface on the HZX-52832-S01A to either the debug out port P19 or the Shield port P20. The programmer on the DK will automatic redirect the link to the module instead of the nRF52 on board. Make sure you connect the VTG (target VDD) pin so the programmer can detect the port.
