nrf52832 pcb design issue with GND
Im currently designing a custom pcb using nrf52 reference design available here. In my design, I have to connect the ground of two analog signals to VSS of nrf52832. It's clear from the reference design that the VSS is connected to ground. So connecting the analog signals' ground to it makes sense, meaning that both the grounds are connected to the same ground(VSS). However, while I was working with the nrf52 development board, when I try to connect two analog pins to the same ground, the device doesn't work. How do I make sure that my custom pcb will work fine?
