Do i need to cut the trace of the onboard antenna for this to work properly?
ie. not cause an impedance mismatch or compete with the onboard antenna.
The nRF51-DK antenna is tuned for the nRF51-DK PCB. If you replicate it in a different PCB, the size, shape and layout will possibly require it to be tuned a little differently so it is always good practice to check it. It should still work to some degree, just not optimally.
Andreas
the question is not in regard to replicating the antenna on a different PCB....
Please let me attempt to clarify my question.
In order to use an EXTERNAL 2.4g whip antenna utilizing the mmcx connection on the nRF51-dk board, does the integrated PCB board trace antenna require cutting to use the external antenna via the on-board mmcx connector or is there a way to switch the nRF51422 antenna path to the external mmcx connector in code?
Thanks for you reply.
I see now that this is a MM8130-2600 connector that is used for power measurement testing, NOT an external antenna.
