After enabling and starting the watchdog timer (RR0), how can it be disabled?
This following code does not work:
NRF_WDT->RREN &= ~(1 << WDT_RREN_RR0_Pos);
Neither does:
NRF_WDT->POWER = 0;
Edit: I'm using a Rev G0 chip.
Neither does:
NRF_WDT->POWER = 0;
Hi John,
Can you please share the code of DFU with watchdog service
All I did was add a service of the WDT in the wait for events loop and also when the loop exits so that the WDT has its full amount of time while the system restarts. Just put this line in two spots in your wait_for_events function:
NRF_WDT->RR[0] = WDT_RR_RR_Reload;
Yes, it''s a brilliant design they chose to reuse in the nRF52 as well. When doing FW upgrade and switching to the bootloader you can't disable the WD. Of course you can chose to stop feeding the WD and wait for the timeout reset; but then the content of the GPREGRET register is lost and hence can't be used to stop in the bootloader. Hence your best option is to let the bootloader feed all the RR registers.
Now when you enter the upgraded application you may wish to configure the WDT differently - but you can't. So one option is to let the WDT reset the system again. If you are logging WDT resets as anomalies you need some mechanism to remember the latest WDT reset was a disarm reset and shouldn't be logged. You need to describe this, make test cases and demonstrates that i really works.
I'd much appreciate writing code that directly benefits our customers instead.
