Hi - I saw this post and I'm not sure how to add a clarifying question on to it: devzone.nordicsemi.com/.../
We have a similar problem in that we built our boards with the 12k pull-down resistor on SWDCLK. We're using the Dynastream N548 module so I'm still trying to identify exactly which 51422 version chip is in there, but our previous board used the QFAAE0 and I believe based on reading the PAN that based on that version we should NOT have the 12k pull-down resistor, correct?
We're seeing about 350μA draw in System OFF mode with simple code that does nothing other than turn on for a few seconds and then go to System OFF. It seems that 12k resistor should account for about 275μA, but that still leaves another 75μA. Are there other issues that could be attributable to this extra current draw? How low should we be able to get the chip? The Product Spec sheet says that Current in SYSTEM OFF, no RAM retention should be 0.6μA.
Thank you.
