Unable to debug with Hardfault_Handler
nrf52832
SDK 14.2
My application is locking up, and finding the cause is proving to be difficult. I've enabled DEBUG and DEBUG_NRF and included the hardfault library from the SDK including the file for the compiler I'm using (GCC, hardfault_handler_gcc.c). I was hopeful seeing the calls to NRF_LOG_ERROR in Hardfault_c_handler() that I might get some information about what is happening, but best I can tell this function is never executed.
Using Segger's Ozone debugger, I can tell that the call stack halts on <Hardfault_Exception> but no error messages are provided. I've attempted trying to override Hardfault_process() and explicitly generate hardfaults using hardfault_genhf.h functions, but no information is ever provided in RTT. Any ideas on what I'm missing?
    We have a known issue with GCC in SDK v14.2, where the define "NRF_BREAKPOINT_COND" expands to __builtin_trap(), which fails with newlib-nano.
    Here's the section in app_util_platform.h:
    #if defined(__GNUC__)
    #define NRF_BREAKPOINT __builtin_trap() // Expands to _exit()
    Define this to a __NOP() or an actual breakpoint "__asm__("BKPT 0");", and the "app_error" assert handler (and the SDK hardfault handler library) should work normally with GCC.
    Could you try this, and report back the fault-details?
    Cheers,
    Håkon
  • Hi Hakon,
    Thanks for your response. I've tried changing NRF_BREAKPOINT to either __NOP() or __asm__("BKPT 0"); but neither changes the behavior.
    Also, curiously, despite hardfault_implementation.c and hardfault_handler_gcc.c being included in the build and being compiled, it does not show up in the list of sources in Ozone's analysis of the .elf. This keeps me from putting a breakpoint in those files.
    *Addition*
    I've enabled -frecord-gcc-switches to verify the following:
    * hardfault and hardfault/nrf52/handler are being included (-I)
    * -0g and -g3 GCC flags are set
    * DEBUG and DEBUG_NRF are set
    Do you have the .c files included in your makefile, or just the include path?
    $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
    $(SDK_ROOT)/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c \
    After adding these, and setting sdk_config.h::HARDFAULT_HANDLER_ENABLED 1, I was stuck in the fault handler, and able to set breakpoints:
    (gdb) b HardFault_Handler
    Note: breakpoint 2 also set at pc 0x25fbc.
    Breakpoint 3 at 0x25fbc: file ../../../../../../components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c, line 51.
    (gdb) b HardFault_c_handler
    Breakpoint 4 at 0x25eac: file ../../../../../../components/libraries/hardfault/hardfault_implementation.c, line 73.
    (gdb) c
    Continuing.
    Breakpoint 2, HardFault_Handler ()
        at ../../../../../../components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c:51
    51          __ASM volatile(
    (gdb) c
    Continuing.
    Breakpoint 4, HardFault_c_handler (p_stack_address=0x2000ffd0)
        at ../../../../../../components/libraries/hardfault/hardfault_implementation.c:73
    73      {
    (gdb)
    Did you remember to enable the hardfault handler in your sdk_config.h?
    Håkon
  • Hi Hakon,
    Yes, I have #define HARDFAULT_HANDLER_ENABLED 1 in my sdk_config.h.
    I am using CMake and compile the SDK as a library as follows (this is inspired by the Mesh SDK):
    *EDIT* Cleaned up things I wasn't using.
    set(SDK_ROOT ${CMAKE_CURRENT_SOURCE_DIR})
    set(SDK_COMPONENTS "${SDK_ROOT}/components")
    set(SDK_LIBRARY "${SDK_COMPONENTS}/libraries")
    set(SDK_EXTERNAL "${SDK_ROOT}/external")
    set(SDK_DRIVER "${SDK_COMPONENTS}/drivers_nrf")
    set(SDK_SOFTDEVICE "${SDK_COMPONENTS}/softdevice")
    set(SDK_BLE "${SDK_COMPONENTS}/ble")
    set(SDK_SOURCE_FILES
        ${SDK_COMPONENTS}/boards/boards.c
        ${SDK_COMPONENTS}/toolchain/system_nrf52.c
        ${SDK_BLE}/ble_advertising/ble_advertising.c
        ${SDK_BLE}/common/ble_advdata.c
        ${SDK_BLE}/common/ble_conn_params.c
        ${SDK_BLE}/common/ble_conn_state.c
        ${SDK_BLE}/common/ble_srv_common.c
        ${SDK_BLE}/nrf_ble_gatt/nrf_ble_gatt.c
        ${SDK_BLE}/peer_manager/gatt_cache_manager.c
        ${SDK_BLE}/peer_manager/gatts_cache_manager.c
        ${SDK_BLE}/peer_manager/id_manager.c
        ${SDK_BLE}/peer_manager/peer_data_storage.c
        ${SDK_BLE}/peer_manager/peer_database.c
        ${SDK_BLE}/peer_manager/peer_id.c
        ${SDK_BLE}/peer_manager/peer_manager.c
        ${SDK_BLE}/peer_manager/pm_buffer.c
        ${SDK_BLE}/peer_manager/pm_mutex.c
        ${SDK_BLE}/peer_manager/security_dispatcher.c
        ${SDK_BLE}/peer_manager/security_manager.c
        ${SDK_BLE}/ble_services/ble_nus/ble_nus.c
        ${SDK_DRIVER}/clock/nrf_drv_clock.c
        ${SDK_DRIVER}/common/nrf_drv_common.c
        ${SDK_DRIVER}/gpiote/nrf_drv_gpiote.c
        ${SDK_DRIVER}/i2s/nrf_drv_i2s.c
        ${SDK_DRIVER}/spi_master/nrf_drv_spi.c
        ${SDK_DRIVER}/twi_master/nrf_drv_twi.c
        ${SDK_DRIVER}/uart/nrf_drv_uart.c
        ${SDK_DRIVER}/ppi/nrf_drv_ppi.c
        ${SDK_DRIVER}/timer/nrf_drv_timer.c
        ${SDK_LIBRARY}/atomic_fifo/nrf_atfifo.c
        ${SDK_LIBRARY}/uart/app_uart_fifo.c
        ${SDK_LIBRARY}/balloc/nrf_balloc.c
        ${SDK_LIBRARY}/bsp/bsp.c
        ${SDK_LIBRARY}/bsp/bsp_btn_ble.c
        ${SDK_LIBRARY}/bsp/bsp_nfc.c
        ${SDK_LIBRARY}/button/app_button.c
        ${SDK_LIBRARY}/fds/fds.c
        ${SDK_LIBRARY}/fifo/app_fifo.c
        ${SDK_LIBRARY}/fstorage/nrf_fstorage.c
        ${SDK_LIBRARY}/hardfault/hardfault_implementation.c
        ${SDK_LIBRARY}/hardfault/nrf52/handler/hardfault_handler_gcc.c
        ${SDK_LIBRARY}/experimental_memobj/nrf_memobj.c
        ${SDK_LIBRARY}/experimental_log/src/nrf_log_backend_rtt.c
        ${SDK_LIBRARY}/experimental_log/src/nrf_log_backend_serial.c
        ${SDK_LIBRARY}/experimental_log/src/nrf_log_backend_uart.c
        ${SDK_LIBRARY}/experimental_log/src/nrf_log_default_backends.c
        ${SDK_LIBRARY}/experimental_log/src/nrf_log_frontend.c
        ${SDK_LIBRARY}/experimental_log/src/nrf_log_str_formatter.c
        ${SDK_LIBRARY}/experimental_section_vars/nrf_section_iter.c
        ${SDK_LIBRARY}/pwr_mgmt/nrf_pwr_mgmt.c
        ${SDK_LIBRARY}/queue/nrf_queue.c
        ${SDK_LIBRARY}/scheduler/app_scheduler.c
        ${SDK_LIBRARY}/spi_mngr/nrf_spi_mngr.c
        ${SDK_LIBRARY}/strerror/nrf_strerror.c
        ${SDK_LIBRARY}/timer/app_timer.c
        ${SDK_LIBRARY}/twi_mngr/nrf_twi_mngr.c
        ${SDK_LIBRARY}/util/app_error.c
        ${SDK_LIBRARY}/util/app_error_weak.c
        ${SDK_LIBRARY}/util/app_util_platform.c
        ${SDK_LIBRARY}/util/nrf_assert.c
        ${SDK_LIBRARY}/util/sdk_mapped_flags.c
        ${SDK_SOFTDEVICE}/common/nrf_sdh.c
        ${SDK_SOFTDEVICE}/common/nrf_sdh_ble.c
        ${SDK_SOFTDEVICE}/common/nrf_sdh_soc.c
        ${SDK_EXTERNAL}/fprintf/nrf_fprintf.c
        ${SDK_EXTERNAL}/fprintf/nrf_fprintf_format.c
        ${SDK_EXTERNAL}/segger_rtt/SEGGER_RTT_Syscalls_GCC.c
        ${SDK_EXTERNAL}/segger_rtt/SEGGER_RTT.c
        ${SDK_EXTERNAL}/segger_rtt/SEGGER_RTT_printf.c)
    #set(SDK_SOURCE_FILES ${SDK_SOURCE_FILES} CACHE INTERNAL "")
    set(SDK_INCLUDE_DIRS
        ${CMAKE_SOURCE_DIR}/config
        ${SDK_COMPONENTS}
        ${SDK_COMPONENTS}/device
        ${SDK_COMPONENTS}/toolchain/cmsis/include
        ${SDK_SOFTDEVICE}/${SOFTDEVICE_TYPE}/headers
        ${SDK_BLE}/ble_dtm
        ${SDK_BLE}/ble_racp
        ${SDK_BLE}/ble_services/ble_ancs_c
        ${SDK_BLE}/ble_services/ble_ans_c
        ${SDK_BLE}/ble_services/ble_bas
        ${SDK_BLE}/ble_services/ble_bas_c
        ${SDK_BLE}/ble_services/ble_cscs
        ${SDK_BLE}/ble_services/ble_cts_c
        ${SDK_BLE}/ble_services/ble_dfu
        ${SDK_BLE}/ble_services/ble_dis
        ${SDK_BLE}/ble_services/ble_gls
        ${SDK_BLE}/ble_services/ble_hids
        ${SDK_BLE}/ble_services/ble_hrs
        ${SDK_BLE}/ble_services/ble_hrs_c
        ${SDK_BLE}/ble_services/ble_hts
        ${SDK_BLE}/ble_services/ble_ias
        ${SDK_BLE}/ble_services/ble_ias_c
        ${SDK_BLE}/ble_services/ble_lbs
        ${SDK_BLE}/ble_services/ble_lbs_c
        ${SDK_BLE}/ble_services/ble_lls
        ${SDK_BLE}/ble_services/ble_nus_c
        ${SDK_BLE}/ble_services/ble_rscs
        ${SDK_BLE}/ble_services/ble_rscs_c
        ${SDK_BLE}/ble_services/ble_tps
        ${SDK_BLE}/common
        ${SDK_BLE}/nrf_ble_qwr
        ${SDK_DRIVER}/clock
        ${SDK_DRIVER}/delay
        ${SDK_DRIVER}/hal
        ${SDK_DRIVER}/i2s
        ${SDK_DRIVER}/ppi
        ${SDK_DRIVER}/rtc
        ${SDK_DRIVER}/timer
        ${SDK_DRIVER}/uart
        ${SDK_DRIVER}/wdt
        ${SDK_LIBRARY}/uart
        ${SDK_LIBRARY}/bsp
        ${SDK_LIBRARY}/fds
        ${SDK_LIBRARY}/fifo
        ${SDK_LIBRARY}/gpiote
        ${SDK_LIBRARY}/mem_manager
        ${SDK_LIBRARY}/mutex
        ${SDK_LIBRARY}/uart
        ${SDK_LIBRARY}/util
    add_library(NRF5_SDK_${nRF5_SDK_VERSION}_${PLATFORM} STATIC ${SDK_SOURCE_FILES})
    set_target_link_options_nosection(NRF5_SDK_${nRF5_SDK_VERSION}_${PLATFORM})
    target_include_directories(NRF5_SDK_${nRF5_SDK_VERSION}_${PLATFORM} PUBLIC
            ${SDK_INCLUDE_DIRS})
    target_compile_options(NRF5_SDK_${nRF5_SDK_VERSION}_${PLATFORM} PUBLIC
            ${${ARCH}_DEFINES})
    message(${${ARCH}_DEFINES})
    target_compile_definitions(NRF5_SDK_${nRF5_SDK_VERSION}_${PLATFORM} PUBLIC
            ${USER_DEFINITIONS}
            ${${PLATFORM}_DEFINES}
            ${${BOARD}_DEFINES}
            ${${SOFTDEVICE}_DEFINES})
    #get_property(core_include_dirs TARGET NRF5_SDK_${nRF5_SDK_VERSION}_${PLATFORM} PROPERTY INCLUDE_DIRECTORIES)
    message(STATUS "NRF5 SDK ${nRF5_SDK_VERSION}")
    Other SDK libraries work correctly (such as TWI Manager, NRF Log, etc).
    When I compile the project, I see the following messages suggesting the hardfault sources are being compiled:
    [ 42%] Building C object nrf5_sdk/14.2.0/CMakeFiles/NRF5_SDK_14.2.0_vka1.dir/components/libraries/hardfault/hardfault_implementation.c.obj
    [ 42%] Building C object nrf5_sdk/14.2.0/CMakeFiles/NRF5_SDK_14.2.0_vka1.dir/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c.obj
    *EDIT* Here's my toolchain gccarmemb.cmake inspired from the Mesh SDK CMake files:
    set(CMAKE_C_COMPILER arm-none-eabi-gcc)
    set(CMAKE_CXX_COMPILER arm-none-eabi-g++)
    set(CMAKE_SIZE_UTIL arm-none-eabi-size)
    set(CMAKE_TRY_COMPILE_TARGET_TYPE STATIC_LIBRARY)
    set(data_flags "-ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums")
    set(warning_flags "-Wall -Wno-attributes -Wno-format")
    set(CMAKE_C_FLAGS_INIT "--std=gnu11 ${warning_flags} ${data_flags}")
    set(CMAKE_C_FLAGS_DEBUG "-Og -g3 -frecord-gcc-switches" CACHE STRING "")
    set(CMAKE_C_FLAGS_MINSIZEREL "-Os -g" CACHE STRING "")
    set(CMAKE_C_FLAGS_RELWITHDEBINFO "-O3 -g" CACHE STRING "")
    set(CMAKE_C_FLAGS_RELEASE "-O3" CACHE STRING "")
    # removed -fstack-protector-strong  because of lssp linker error?
    set(cxx_flags "-fno-exceptions -fno-non-call-exceptions -fno-rtti -fno-use-cxa-atexit -ffreestanding -fno-common -fno-threadsafe-statics")
    set(CMAKE_CXX_FLAGS_INIT "${warning_flags} ${data_flags} ${cxx_flags}")
    set(CMAKE_CXX_FLAGS_DEBUG "-Og -g3 -frecord-gcc-switches" CACHE STRING "")
    set(CMAKE_CXX_FLAGS_MINSIZEREL "-Os -g" CACHE STRING "")
    set(CMAKE_CXX_FLAGS_RELWITHDEBINFO "-O3 -g" CACHE STRING "")
    set(CMAKE_CXX_FLAGS_RELEASE "-O3" CACHE STRING "")
    set(cortex-m4f_DEFINES
        -mcpu=cortex-m4
        -mthumb
        -mabi=aapcs
        -mfloat-abi=hard
        -mfpu=fpv4-sp-d16)
    function (set_target_link_options target_name linker_file)
        set(link_flags
            ${${ARCH}_DEFINES}
            "-Wl,--gc-sections --specs=nano.specs -L\"${${PLATFORM}_LINK_INCLUDE_DIR}\" \"-L${CMAKE_CURRENT_SOURCE_DIR}/linker\""
            "-Xlinker -Map=\"${CMAKE_CURRENT_BINARY_DIR}/${target_name}.map\""
            "-T\"${linker_file}.ld\"")
        string(REGEX REPLACE ";" " " link_flags "${link_flags}")
        set_target_properties(${target_name} PROPERTIES LINK_FLAGS ${link_flags})
    endfunction (set_target_link_options)
    function (set_target_link_options_nosection target_name)
        set(link_flags
                ${${ARCH}_DEFINES}
    endfunction (set_target_link_options_nosection)
    function (create_hex executable)
        add_custom_command(
            TARGET ${executable}
            POST_BUILD
            COMMAND arm-none-eabi-objcopy -O ihex ${CMAKE_CURRENT_BINARY_DIR}/${executable}.elf ${CMAKE_CURRENT_BINARY_DIR}/${executable}.hex
            COMMENT "Merging ${executable}.hex.."
    endfunction(create_hex)
    My "platform" vka1.cmake:
    set(vka1_ARCH "cortex-m4f")
    set(vka1_SOURCE_FILES
            "${SDK_ROOT}/components/toolchain/system_nrf52.c")
    set(vka1_INCLUDE_DIRS
            "${SDK_ROOT}/components/device"
            "${SDK_ROOT}/components/toolchain"
            "${SDK_ROOT}/components/toolchain/cmsis/include")
    if (TOOLCHAIN MATCHES "gcc" OR TOOLCHAIN STREQUAL "clang")
                ${vka1_SOURCE_FILES}
                "${SDK_ROOT}/components/toolchain/gcc/gcc_startup_nrf52.S")
                ${vka1_INCLUDE_DIRS}
                "${SDK_ROOT}/components/toolchain/gcc"
                "${SDK_ROOT}/components/toolchain/dsp/GCC")
        set(vka1_LINK_INCLUDE_DIR
                "${SDK_ROOT}/components/toolchain/gcc")
    elseif (TOOLCHAIN STREQUAL "armcc")
                "${SDK_ROOT}/components/toolchain/arm/arm_startup_nrf52.s")
                "${SDK_ROOT}/components/toolchain/arm"
                "${SDK_R OOT}/components/toolchain/dsp/ARM")
    else ()
        message(FATAL_ERROR "Unknown toolchain ${TOOLCHAIN}")
    endif ()
    set(vka1_DEFINES
            -DNRF52
            -DNRF52_SERIES
            -DNRF52832
            -DNRF52832_XXAA
            -DDCONFIG_NFCT_PINS_AS_GPIOS
            -DDEBUG      # explicitly set for debugging hardfault issue
            -DDEBUG_NRF  # explicitly set for debugging hardfault issue
    set(vka1_FAMILY "NRF52")
    set(vka1_FLASH_SIZE "524288")
    set(vka1_RAM_SIZE "65536")
    Utilizing APP_CONFIG (USE_APP_CONFIG) I have the following for my app_config.h:
    #pragma once
    #define DEVICE_NAME "HardFaultMeGently"
    #define DEBUG 1
    #define DEBUG_NRF 1
    #define HARDFAULT_HANDLER_GDB_PSP_BACKTRACE 1
    // </h>
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_XTAL_ACCURACY  - External crystal clock accuracy used in the LL to compute timing windows.
    // <0=> NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
    #ifndef NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 0
    #define NRF_LOG_ENABLED 1
    #define NRF_LOG_BACKEND_RTT_ENABLED 1
    #define NRF_LOG_USES_COLORS 1
    #define NRF_LOG_USES_MODULE_NAME 1
    #define NRF_PWR_MGMT_CONFIG_LOG_ENABLED 1
    #define NRF_PWR_MGMT_CONFIG_CPU_USAGE_MONITOR_ENABLED 1
    #define NRF_PWR_MGMT_CONFIG_USE_SCHEDULER 1
    // <e> CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver
    #define CLOCK_ENABLED 1
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    #define CLOCK_CONFIG_LF_SRC 0
    // <e> PPI_ENABLED - nrf_drv_ppi - PPI peripheral driver
    #define PPI_ENABLED 1
    // <e> SPI_ENABLED - nrf_drv_spi - SPI/SPIM peripheral driver
    #define SPI_ENABLED 1
    // <e> SPI1_ENABLED - Enable SPI1 instance
    #define SPI1_ENABLED 1
    #if  SPI1_ENABLED
    // <q> SPI1_USE_EASY_DMA  - Use EasyDMA
    #define SPI1_USE_EASY_DMA 1
    // <o> SPI1_DEFAULT_FREQUENCY  - SPI frequency
    // <33554432=> 125 kHz
    // <67108864=> 250 kHz
    // <134217728=> 500 kHz
    // <268435456=> 1 MHz
    // <536870912=> 2 MHz
    // <1073741824=> 4 MHz
    // <2147483648=> 8 MHz
    #define SPI1_DEFAULT_FREQUENCY 536870912
    #endif //SPI1_ENABLED
    // </e>
    // <e> TIMER_ENABLED - nrf_drv_timer - TIMER periperal driver
    #define TIMER_ENABLED 1
    // <q> TIMER1_ENABLED  - Enable TIMER1 instance
    #define TIMER0_ENABLED 1
    #define TIMER1_ENABLED 1
    #define TIMER2_ENABLED 1
    #define TIMER3_ENABLED 1
    #define TIMER4_ENABLED 1
    // <e> TWI_ENABLED - nrf_drv_twi - TWI/TWIM peripheral driver
    #define TWI_ENABLED 1
    #if  TWI_ENABLED
    // <o> TWI_DEFAULT_CONFIG_FREQUENCY  - Frequency
    // <26738688=> 100k
    // <67108864=> 250k
    // <104857600=> 400k
    #define TWI_DEFAULT_CONFIG_FREQUENCY 104857600
    // <q> TWI_DEFAULT_CONFIG_CLR_BUS_INIT  - Enables bus clearing procedure during init
    #define TWI_DEFAULT_CONFIG_CLR_BUS_INIT 1
    // <e> TWI0_ENABLED - Enable TWI0 instance
    #define TWI0_ENABLED 1
    #if  TWI0_ENABLED
    // <q> TWI0_USE_EASY_DMA  - Use EasyDMA (if present)
    #define TWI0_USE_EASY_DMA 0
    #endif //TWI0_ENABLED
    // </e>
    #define TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED 0
    #endif //TWI_ENABLED
    // </e>
    // <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver
    #define UART_ENABLED 1
    #if  UART_ENABLED
    // <o> UART_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
    // <0=> Disabled
    // <1=> Enabled
    #define UART_DEFAULT_CONFIG_HWFC 0
    // <o> UART_DEFAULT_CONFIG_PARITY  - Parity
    // <0=> Excluded
    // <14=> Included
    #define UART_DEFAULT_CONFIG_PARITY 0
    // <o> UART_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
    // <323584=> 1200 baud
    // <643072=> 2400 baud
    // <1290240=> 4800 baud
    // <2576384=> 9600 baud
    // <3862528=> 14400 baud
    // <5152768=> 19200 baud
    // <7716864=> 28800 baud
    // <10289152=> 38400 baud
    // <15400960=> 57600 baud
    // <20615168=> 76800 baud
    // <30801920=> 115200 baud
    // <61865984=> 230400 baud
    // <67108864=> 250000 baud
    // <121634816=> 460800 baud
    // <251658240=> 921600 baud
    // <268435456=> 57600 baud
    #define UART_DEFAULT_CONFIG_BAUDRATE 2576384
    // <o> UART_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 7
    // <q> UART_EASY_DMA_SUPPORT  - Driver supporting EasyDMA
    #define UART_EASY_DMA_SUPPORT 1
    // <q> UART_LEGACY_SUPPORT  - Driver supporting Legacy mode
    #define UART_LEGACY_SUPPORT 0
    // <e> UART0_ENABLED - Enable UART0 instance
    #define UART0_ENABLED 1
    #if  UART0_ENABLED
    // <q> UART0_CONFIG_USE_EASY_DMA  - Default setting for using EasyDMA
    #define UART0_CONFIG_USE_EASY_DMA 1
    #endif //UART0_ENABLED
    // </e>
    #endif //UART_ENABLED
    // </e>
    // <h> nRF_Libraries
    #define APP_FIFO_ENABLED 1
    #define APP_UART_ENABLED 1
    #define APP_GPIOTE_ENABLED 1
    #define APP_SCHEDULER_ENABLED 1
    #define APP_TIMER_ENABLED 1
    #define APP_TIMER_CONFIG_USE_SCHEDULER 1
    #define APP_TIMER_KEEPS_RTC_ACTIVE 1  // Keep RTC1 active even when there are no timers (we need this for millis and micros)
    // <o> APP_TIMER_CONFIG_RTC_FREQUENCY  - Configure RTC prescaler.
    // <0=> 32768 Hz
    // <1=> 16384 Hz
    // <3=> 8192 Hz
    // <7=> 4096 Hz
    // <15=> 2048 Hz
    // <31=> 1024 Hz
    #define APP_TIMER_CONFIG_RTC_FREQUENCY 7
    #define NRF_TWI_MNGR_ENABLED 1
    #define BUTTON_ENABLED 0
    #define NRF_QUEUE_ENABLED 1
    #define NRF_SERIAL_ENABLED 0
    #define NRF_STRERROR_ENABLED 1
    My main.cpp to test this is:
    #include <libraries/hardfault/hardfault_genhf.h>
    #include <libraries/hardfault/hardfault.h>
    #include <VK_HAL.h>
    #include <libraries/timer/app_timer.h>
    const VK_HAL::HAL& hal = VK_HAL::get_HAL();
    APP_TIMER_DEF(test_hardfault_timer);
    extern "C" {
    void test_hardfault_timer_handler(void * p_context) {
    	NRF_LOG_INFO("Force a hardfault (undefined instruction)");
    	hardfault_genhf_undefined_instr();
    void setup() {
    	// Create a 5 second timer to generate a hardfault
    	APP_ERROR_CHECK(app_timer_create(&test_hardfault_timer, APP_TIMER_MODE_REPEATED, test_hardfault_timer_handler));
    	APP_ERROR_CHECK(app_timer_start(test_hardfault_timer, APP_TIMER_TICKS(5000), NULL));
    void loop() {
    VK_HAL_MAIN()  // Sets up a normal look with app_sched_execute() and nrf_pwr_mgmt_run
    My RTT Log is the following:
    ➜  ~ JLinkRTTClient
    ###RTT Client: ************************************************************
    ###RTT Client: *           SEGGER MICROCONTROLLER GmbH & Co KG            *
    ###RTT Client: *   Solutions for real time microcontroller applications   *
    ###RTT Client: *                                                          *
    ###RTT Client: *  (c) 2012 - 2016  SEGGER Microcontroller GmbH & Co KG    *
    ###RTT Client: *                                                          *
    ###RTT Client: *     www.segger.com     Support: [email protected]       *
    ###RTT Client: *                                                          *
    ###RTT Client: *                                                          *
    ###RTT Client: * SEGGER J-Link RTT Client   Compiled Dec 14 2017 18:33:57 *
    ###RTT Client: *                                                          *
    ###RTT Client: -----------------------------------------------
    ###RTT Client: Connecting to J-Link RTT Server via localhost:19021  Connected.
    SEGGER J-Link V6.22d - Real time terminal output
    J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 24 2017 17:30:12 V1.0, SN=682228671
    Process: JLinkExe
    <info> BLE: BLE Stack Init
    <info> pwr_mgmt: Init
    <info> I2C: I2C Init
    <info> DRV_NCP1855: State:CHARGE DONE
    <info> DRV_KMX62: Init and detected
    <info> DRV_LSM6DSM: Init and detected
    <info> app: run()
    <info> pwr_mgmt: CPU Usage: 1%
    <info> pwr_mgmt: CPU Usage: 0%
    (Here the application freezes and no further information is provided)
  • Bringing HardFault_Handler() into my main.cpp makes it work as expected. I must be doing something wrong in how it gets linked from my SDK lib?
    main.cpp:
    #include <VK_HAL.h>
    extern "C" {
    extern void HardFault_c_handler(uint32_t *);
    void HardFault_Handler(void) __attribute__(( naked ));
    	__ASM volatile(
    	"   .syntax unified                        \n"
    			"   ldr   r0, =0xFFFFFFFD                  \n"
    			"   cmp   r0, lr                           \n"
    			"   bne   HardFault_Handler_ChooseMSP      \n"
    			/* Reading PSP into R0 */
    			"   mrs   r0, PSP                          \n"
    			"   b     HardFault_Handler_Continue       \n"
    			"HardFault_Handler_ChooseMSP:              \n"
    			/* Reading MSP into R0 */
    			"   mrs   r0, MSP                          \n"
    			 * If we have selected MSP check if we may use stack safetly.
    			 * If not - reset the stack to the initial value. */
    			"   ldr   r1, =__StackTop                  \n"
    			"   ldr   r2, =__StackLimit                \n"
    			/* MSP is in the range of the stack area */
    			"   cmp   r0, r1                           \n"
    			"   bhi   HardFault_MoveSP                 \n"
    			"   cmp   r0, r2                           \n"
    			"   bhi   HardFault_Handler_Continue       \n"
    			"HardFault_MoveSP:                         \n"
    			"   mov   SP, r1                           \n"
    			"   movs  r0, #0                           \n"
    			"HardFault_Handler_Continue:               \n"
    			"   ldr r3, =%0                            \n"
    			"   bx r3                                  \n"
    			"   .ltorg                                 \n"
    	: : "X"(HardFault_c_handler)
    } // Extern C
    void setup() {
    void loop() {
    VK_HAL_MAIN()  // Sets up a normal look with app_sched_execute() and nrf_pwr_mgmt_run()
    RTT:
    Process: JLinkExe
    <info> app: run()
    <info> app: Force a hardfault (undefined instruction)
    <error> hardfault: HARD FAULT at 0x000232CA
    <error> hardfault:   R0:  0x0000000C  R1:  0x00000001  R2:  0x200023C8  R3:  0x00000000
    <error> hardfault:   R12: 0x00000000  LR:  0x00023FF7  PSR: 0x01000000
    <error> hardfault: Cause: The processor has attempted to execute an undefined instruction.
