I can't run the light switch successfully. The log of Client and Server is as follows. I didn't modify the example.
What mesh SDK version are you using?
How is your setup?
Could you describe more about your issue?
Hello Martin!
thank you for your reply. The SDK is mesh 1.0.1. I run the demo of light_switch, but the discovery did not work properly. the Client and server. 4 LEDs are always on and they are not blinking. There should be no mesh network! So how do I operate this demo to work properly?
have you followed the Documentation respectively?
And debug your code to see where you fail and what errors you get.
I'm facing the same problem, did you find a solution ?
Have you updated to the newest Mesh SDK v2.0.1?
