Use of Command Line Tools in production
Hi Nordic,
    In order to program our boards with nRF52832 devices in production, we need a stand-alone, command line programming tool.
I believe that the command line tools will do this?
There are a number of question I have about this:
(1) What is the name of the command line tool .exe that will program the device (via J-Link or Nordic DK dev board)?
(2) What environment does it require? Does it require 32 bit or 64 bit (or can work with both)?
(3) What version(s) of Windows will it run under? Will it run on Windows XP, for example?
(4) Is the programming tool stand-alone, or does it require other files?  If so, what files does it need?
(5) Can you give an example of a command line instruction to program a nRF52832 device?
Thanks for your attention...
Declan Traill
