Hello All,
Please find the attached schematic , please review the same and give your valuable feed back , we are using NFC functionality in the same . earliest reply will be much appriciated.
Thanks in advance
pktronNRF52832_SCH.pdf
Hello All,
Thanks in advance
The idea is probably to populate only one of the caps to be able to change the antenna without a PCB re-spin.
Even so they would still need to do the layout correctly or they will get a open stub on the line.
Their antenna measurements stated that both elements were active at the same time. Due to the poor match their antenna efficiency was -8dB which is 6dB down from the antenna spec. Or another way to look at it is, they just halved their range.
I think they really think they can put two antennae together like that. Earlier they referred to it as a splitter.
Little do they know!
