Hi!
Please, help me! Maybe someone knows the answer. Is there any smartphone with supporting of Bluetooth 5 Long Range feature?
Best Regards,
Pavel
Hi!
Best Regards,
Pavel
It just that these phones are locked down. You cannot install any apps on them (store mode it's called I think)
But I think that the point I am trying to make here is that my experience with an actual iPhone 11 and a BLE LR device would mean that the list above is incorrect.
I am wondering on what information this list is made, just specs or actual tests?
Thanks for the input. There is of course a possibility that the list is wrong.
Most of the list is based on the BT SIG listing for the specific phone models.
That you are not able to discover the device on the mentioned iPhone models could be related to the fact that BLE devices are generally not discovered in the Bluetooth settings on iOS. There are some BLE services with native support but most BLE devices needs an third-party application.
I haven't done any tests with the iPhone models you mentioned, but I don't think we can rule them out just yet, either. I will try to get some tests done with some of the phones in the list in order to verify.
Br,
Joakim
Great!
Maybe there is some weirdness in the sense that devices that advertise using the BLE Coded PHY channels are not discovered and that you must advertise using standard PHY's and switch to coded PHY's afterward.
Having said that, it just worked with the Samsung Galaxy S10, but a Xiaomi Pocophone F1 claiming LR compatibility fails to detect it with Bluetooth browsing.
So I guess there is a gap between claiming compatibility and actually working.
Dear Joakim,
In this thread you mentioned there is also several other devices, such as different tablets, smartwatches etc. which also supports BLE Long Range.
Please, may you confirm if the following Android tablets support BLE Long Range:
Samsung |
Huawei |
Xiaomi |
Mi Pad 4 |
Lenovo |
Thanks for your feedback
