Dear sir,
The twi sensor code in SDK14 is getting stuck at NRF_BREAKPOINT_COND. Also, on the uart terminal it is showing FATAL ERROR. Please help me out of this.I am using NRF52832 Development kit.
Manoj Hiwarkar.
Dear sir,
Manoj Hiwarkar.
I'm guessing that it gets stuck inside app_error_fault_handler()?
You can try to change your code to something like this to make the error handler print some more informative messages:
__WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
static error_info_t * p_error_info;
p_error_info = (error_info_t*)info;
NRF_LOG_ERROR("Error: ID: %d, PC: 0x%X\n\r", id, pc);
NRF_LOG_ERROR("Error: Code: 0x%04X (%d), Line: %d, File: %s\n\r", p_error_info->err_code, p_error_info->err_code, p_error_info->line_num, (uint32_t)p_error_info->p_file_name);
NRF_LOG_FINAL_FLUSH();
// NRF_BREAKPOINT_COND;
// On assert, the system can only recover with a reset.
#ifndef DEBUG
NRF_LOG_INFO("Hit weak handler");
NVIC_SystemReset();
#else
app_error_save_and_stop(id, pc, info);
#endif // DEBUG
After that you can examine the error info to pinpoint where and what failed.
I facing the same issue, when using nrf_drv_twi_tx. May I know what does app_error_fault_handler means?
Please refer to this documentation concerning app_error_fault_handler(): Error module
Hi MartinBL
I managed to resolve the app error issue I faced, the method is by adding delay in between 2 different I2c slaves function which shared the same TWI Instance. Any idea why shared I2c slaves without delay in TWI instance will cause hang?
Thanks.
the problem is with the hardware,change it. Your i2c slave is must not be responding.
