Trying to setup a simple Ble beacon on a PCA10040 and a sniffer on another PCA10040
Hi.
I am trying to set up a simple Ble beacon on a PCA10040 and a sniffer on another PCA10040.
IDE = Segger Embedded Studio for ARM (This works fine)
The beacon uses 'nrf5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_beacon'. This appears to compile, download and run o.k. The indicator Led flashes as expected.
The sniffer uses 'nrf5_SDK_for_mesh_v1.0.1_src\examples\beaconing'. This compiles and downloads o.k. However when running in debug mode I expected the 'rx-callback' function to intercept Ble adverts and to see a LOG report in the debug window giving the entire beacon payload. I have also tried it with other advertising Ble beacons and nothing ever gets reported in the debug window.
Regards Chris Harley (U.K.)
    I just tested the example and find it not to report any advertisements. Further, I cannot see any advertisements beaconed from it either. I do get the following logs, but nothing more:
    <t:          0>, main.c,  161, ----- Bluetooth Mesh Beacon Example -----
    <t:        288>, main.c,  135, Initializing and adding models
    <t:       5175>, main.c,  189, Initialization complete!
    Can you confirm that this is the same as what you experience?
    I did not manage to find other reports of the same issue, which is a bit strange given that 1.0.1 has been out for some time now. Perhaps we have both missed some detail somewhere. In any case I have sent a request to the Mesh team to look into this issue. Hopefully they will be able to give us an answer quite quickly.
    Terje
  • hello Chris,
    It looks like you may want to follow the advice from Rick Chung over on this thread... after experiencing the same issue, Rick's fix worked for me but with the following caveats:
    1- although I started seeing ble adverts, the __LOG_XB(..) call displayed the following:
    <t:          0>, main.c,  162, ----- Bluetooth Mesh Beacon Example -----
    <t:      56256>, main.c,  135, Initializing and adding models
    <t:      61115>, main.c,  190, Initialization complete!
    <t:      62138>, main.c,   85, RX [@179836]: RSSI: d ADV TYPE: ffffffba ADDR: [2x:2x:2x:2x:2x:2x]: 1EFF06000109200036283F707E3EE9AE3C35044EAD0DE498BD2822DBB8A4CB
    <t:      62846>, main.c,   85, RX [@201435]: RSSI: d ADV TYPE: ffffffc2 ADDR: [2x:2x:2x:2x:2x:2x]: 031900000201061107ABD0F555EB40E7B2AC49DDEB83D32BA205FF04001B80
    <t:      63667>, main.c,   85, RX [@226503]: RSSI: d ADV TYPE: ffffffe0 ADDR: [2x:2x:2x:2x:2x:2x]: 0201041AFF590002150112233445566778899AABBCCDDEEFF001020304C3
    <t:      64920>, main.c,   85, RX [@264847]: RSSI: d ADV TYPE: ffffffa4 ADDR: [2x:2x:2x:2x:2x:2x]: 02011A0BFF4C000906026A0A000049
    with incorrect values for the rssi, adv type and dev addr.
    2- By implementing the following patch:
        (void) sprintf(msg, "Rx: [@%u] - rssi: %d - Adv Type: %d - Channel: %d - Addr: [0x%p:%p:%p:%p:%p:%p] - ",
                       p_rx_data->p_metadata->params.scanner.timestamp,
                       p_rx_data->p_metadata->params.scanner.rssi,
                       p_rx_data->adv_type,
                       p_rx_data->p_metadata->params.scanner.channel,
                       (void*)p_rx_data->p_metadata->params.scanner.adv_addr.addr[5],
                       (void*)p_rx_data->p_metadata->params.scanner.adv_addr.addr[4],
                       (void*)p_rx_data->p_metadata->params.scanner.adv_addr.addr[3],
                       (void*)p_rx_data->p_metadata->params.scanner.adv_addr.addr[2],
                       (void*)p_rx_data->p_metadata->params.scanner.adv_addr.addr[1],
                       (void*)p_rx_data->p_metadata->params.scanner.adv_addr.addr[0]);
    The log is then displayed as follows:
    <t:          0>, main.c,  179, ----- Bluetooth Mesh Beacon Example -----
    <t:        296>, main.c,  152, Initializing and adding models
    <t:       5193>, main.c,  207, Initialization complete!
    <t:       5546>, main.c,  102, Rx: [@158134] - rssi: -62 - Adv Type: 0 - Channel: 38 - Addr: [0xe9:b4:0e:bd:ac:7b] - : 031900000201061107ABD0F555EB40E7B2AC49DDEB83D32BA205FF04001B80
    <t:       6191>, main.c,  102, Rx: [@177828] - rssi: -73 - Adv Type: 2 - Channel: 38 - Addr: [0x05:76:32:40:e1:cd] - : 1EFF0600010920001D8F3249D07FC70A7D52891320E44AA6F4E5ACB1683B20
    <t:       7591>, main.c,  102, Rx: [@220565] - rssi: -32 - Adv Type: 2 - Channel: 38 - Addr: [0x3d:9e:21:4b:73:c9] - : 0201041AFF590002150112233445566778899AABBCCDDEEFF001020304C3
    <t:       9591>, main.c,  102, Rx: [@281579] - rssi: -74 - Adv Type: 2 - Channel: 38 - Addr: [0x05:76:32:40:e1:cd] - : 1EFF0600010920001D8F3249D07FC70A7D52891320E44AA6F4E5ACB1683B20
    <t:       9815>, main.c,  102, Rx: [@288443] - rssi: -62 - Adv Type: 0 - Channel: 38 - Addr: [0xf8:8f:01:7a:e4:8e] - : 0201061AFF4C0002150112233445566778899AABBCCDDEEFF026682C6EC3
    <t:      11008>, main.c,  102, Rx: [@324838] - rssi: -32 - Adv Type: 2 - Channel: 38 - Addr: [0x3d:9e:21:4b:73:c9] - : 0201041AFF590002150112233445566778899AABBCCDDEEFF001020304C3
    <t:      12482>, main.c,  102, Rx: [@369825] - rssi: -60 - Adv Type: 0 - Channel: 38 - Addr: [0xe9:b4:0e:bd:ac:7b] - : 031900000201061107ABD0F555EB40E7B2AC49DDEB83D32BA205FF04001B80
    <t:      12949>, main.c,  102, Rx: [@384081] - rssi: -74 - Adv Type: 2 - Channel: 38 - Addr: [0x05:76:32:40:e1:cd] - : 1EFF0600010920001D8F3249D07FC70A7D52891320E44AA6F4E5ACB1683B20
    <t:      14315>, main.c,  102, Rx: [@425766] - rssi: -31 - Adv Type: 2 - Channel: 38 - Addr: [0x3d:9e:21:4b:73:c9] - : 0201041AFF590002150112233445566778899AABBCCDDEEFF001020304C3
    You should also be able to detect the beacons for Nordic Semi Mesh & the nRF Beacon via the nRF Connect app.
    Thanks for pointing us to that other thread!
    Terje
