I'm newbie with BLE and nrf52382.
I was looking in other questions but couldn't find an answer for my problem.
Our board contains 2 external crystals: one of 32.768KHz connected to XL1 and XL2, and the other of 32MHz connected to XC1 and XC2.
The scenario of initializations is:
nrf_sdh_enable_request();
Before adding these lines (and other code related to these macros):
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
SW didn't stucked.
But after adding the above 2 lines (and other code related to these macros), then,
when calling nrf_sdh_enable_request() function, SW get stucked when getting this line:
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
ret_code_t nrf_sdh_enable_request(void) { ret_code_t ret_code; if (m_nrf_sdh_enabled) { return NRF_ERROR_INVALID_STATE; } m_nrf_sdh_continue = true; // Notify observers about SoftDevice enable request. if (sdh_request_observer_notify(NRF_SDH_EVT_ENABLE_REQUEST) == NRF_ERROR_BUSY) { // Enable process was stopped. return NRF_SUCCESS; } // Notify observers about starting SoftDevice enable process. sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLE_PREPARE); nrf_clock_lf_cfg_t const clock_lf_cfg = { .source = NRF_SDH_CLOCK_LF_SRC, .rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV, .rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV, #ifdef S140 .xtal_accuracy = NRF_SDH_CLOCK_LF_XTAL_ACCURACY #else .accuracy = NRF_SDH_CLOCK_LF_XTAL_ACCURACY #endif }; #ifdef ANT_LICENSE_KEY ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler, ANT_LICENSE_KEY); #else ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler); #endif if (ret_code != NRF_SUCCESS) { return ret_code; } m_nrf_sdh_enabled = true; m_nrf_sdh_continue = false; m_nrf_sdh_suspended = false; #ifndef S140 // Set the interrupt priority after enabling the SoftDevice, since // sd_softdevice_enable() sets the SoftDevice interrupt priority. swi_interrupt_priority_workaround(); #endif // Enable event interrupt. // Interrupt priority has already been set by the stack. softdevices_evt_irq_enable(); // Notify observers about a finished SoftDevice enable process. sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLED); return NRF_SUCCESS; }
My settings in sdk_config.h file are as bellow:
// <e> NRF_SDH_ENABLED - nrf_sdh - SoftDevice handler //========================================================== #ifndef NRF_SDH_ENABLED #define NRF_SDH_ENABLED 1 #endif // <h> Dispatch model // <i> This setting configures how Stack events are dispatched to the application. //========================================================== // <o> NRF_SDH_DISPATCH_MODEL // <i> NRF_SDH_DISPATCH_MODEL_INTERRUPT: SoftDevice events are passed to the application from the interrupt context. // <i> NRF_SDH_DISPATCH_MODEL_APPSH: SoftDevice events are scheduled using @ref app_scheduler. // <i> NRF_SDH_DISPATCH_MODEL_POLLING: SoftDevice events are to be fetched manually. // <0=> NRF_SDH_DISPATCH_MODEL_INTERRUPT // <1=> NRF_SDH_DISPATCH_MODEL_APPSH // <2=> NRF_SDH_DISPATCH_MODEL_POLLING #ifndef NRF_SDH_DISPATCH_MODEL #define NRF_SDH_DISPATCH_MODEL 0 #endif // </h> //========================================================== // <h> Clock - SoftDevice clock configuration //========================================================== // <o> NRF_SDH_CLOCK_LF_SRC - SoftDevice clock source. // <0=> NRF_CLOCK_LF_SRC_RC // <1=> NRF_CLOCK_LF_SRC_XTAL // <2=> NRF_CLOCK_LF_SRC_SYNTH #ifndef NRF_SDH_CLOCK_LF_SRC #define NRF_SDH_CLOCK_LF_SRC 1 #endif // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval. #ifndef NRF_SDH_CLOCK_LF_RC_CTIV #define NRF_SDH_CLOCK_LF_RC_CTIV 0 #endif // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature. // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated // <i> if the temperature has not changed. #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0 #endif // <o> NRF_SDH_CLOCK_LF_XTAL_ACCURACY - External crystal clock accuracy used in the LL to compute timing windows. // <0=> NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM // <1=> NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM // <2=> NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM // <3=> NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM // <4=> NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM // <5=> NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM // <6=> NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM // <7=> NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM #ifndef NRF_SDH_CLOCK_LF_XTAL_ACCURACY #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7 #endif
Please help me with this issue.
