in 52832,if only use 32M oscillator the power dissipation is about 600uA,if use both 32M and 32.768khz,the power dissipation is about 2.2uA. why?
I do not think this is possible with any SoC technology we have or will have in the near future. I am pretty sure that you do not have 32M clock running when you get 2.2uA reading.
The 32M osc will only be turned on when needed - usually only when the radio is used. BTLE (and ANT) require a 32768Hz clock source that uses the low power crystal if present but can use the 32M divided down if not.
This is the reason for the 600uA - the 32M crystal will not be turned off if the low frequency crystal is not present.
