I have been reading the nRF52840 product specification guide and find the PPI an interesting feature potential to use in my application. I'm would like if possible to connect an RTC and 2nd timer in count mode to be triggered by the same GPIO input. I'm new to the nRF52840 and not quite in productive programming it yet. Need the help from outside resources and example code that helps me.
So...
I want to count fault pulses from a very reliable pulse train (it has very accurate timing from a system MCU). The fault pulse train has fault patterns ranging from one pulse to ten pulses in each train when a system fault LED lights from a separate MCU in our system. Want to use the nRF52840 to not only light one of two possible fault icon LED (much like the example of a check engine lite to a car), but I also want to broadcast it out BLE (a later priority to solve in code).
Previous help from the Nordic Zone mentioned the the use of an RTC that times out during the pause in the pulse train two allow the count from a 2nd timer in count mode to be fetched. The same GPIO used to sense the system LED fault pulses will trigger both timers through the configuration of the PPI.
The image below shows 3 waveforms taken from my white board. The D2 Fault LED shown is showing a 5 pulse fault code that has meaning in the system for a type of fault. The fault pulse pattern is active low for 250mS duration pulses with 250mS delay before more fault pulses. There is a 1.25 second pause before a repeat pattern of the fault code takes place again. The overall goal is to translate this fault pattern to an accurate count value, determine from count as to what fault icon to light and transmit via BLE the fixture ID number and type of fault translated from the fault.
The 2nd waveform below shows an RTC timer that triggered by the active low edge of the fault pattern. The time out for the RTC is 550mS. Since the repeat active low edges of the fault pulse happens every 500ms, the RTC never times out. However; when there is no active low during the 1.25sec pause the RTC times out and is the perfect time to get the count from the timer in count mode.
The last waveform shown is the timer in count mode that is triggered by the same active low falling edge fault pulse signal that triggers the RTC. This timer once triggered "I assume" can time out in 100mS and keep a count of one on every trigger input from the fault pulse GPIO input. The count will be fetched when the RTC times out only during the time it sees no active low falling edge from the fault pulse input during the 1.25sec pause.
See the image below for a better visual of what I want to do. Need help on code that I can take further. I have viewed example code similar to what I need to achieve and found nothing.
Thanks for your help,
Allen
