pstorage store issue
HI,all!
I recently using pstorage to store data
and the pstorage_store(); funtion always returns NRF_SUCCESS, but never triggle the cb_handler, is that normal?
by the way, i just sucessfully store the data once and never success again.(the loaded data is 0xff)
Can someone points out the problems? Thank you very much!
here is my code:
void mypstorage_init(void)
	uint16_t block=0;
	uint8_t flash2[16]={16,15,14,13,12,11,10,9,8,7,6,5,4,3,2,1};
	uint16_t size=16;
	uint16_t offset=0;
	pstorage_handle_t p_block_id;
	cb_init mycbinit;
	pstorage_module_param_t p_example_param;
	    // Setup pstorage with 60blocks of 16byte in each.
            p_example_param.block_size  = 0x10; // recommended to be >= 4 byte
            p_example_param.block_count = 60;//60
            p_example_param.cb          = mycbinit.example_cb_handler;
	pstorage_init();
	pstorage_register(&p_example_param, &m_p_example_id);
	pstorage_block_identifier_get(&m_p_example_id, block, &p_block_id);
	pstorage_store(&p_block_id,flash2,size,offset);
	pstorage_load(myflash2,&p_block_id,size,offset);
 typedef struct
      pstorage_ntf_cb_t   example_cb_handler;
} cb_init;
void example_cb_handler(pstorage_handle_t *  p_handle,
                              uint8_t              op_code,
                              uint32_t             result,
                              uint8_t *            p_data,
                              uint32_t             data_len)
  • pstorage_store(); funtion always returns NRF_SUCCESS, but never triggle the cb_handler, is that normal?
    You need to init pstorage callback like this:
                p_example_param.cb          = example_cb_handler;
        pstorage_init();
                                  uint8_t              op_code,
                                  uint32_t             result,
                                  uint8_t *            p_data,
                                  uint32_t             data_len)
    You are doing it wrong, if you do it like this:
    Then when you call pstorage_store you just send request to store your data to pstorage and when this function will return with NRF_SUCCESS your data won't be stored in flash yet. It will be stored after a while and then pstorage will report this in callback example_cb_handler. And only after this you can try to load this stored data.
    Read this.
    UPD:
    What do you mean by running out of control?
    For the proper pstorage functioning you need to set sys events handler like this:
    static void sys_evt_dispatch(uint32_t sys_evt)
        pstorage_sys_event_handler(sys_evt);
        // Register with the SoftDevice handler module for SYS events.
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
  • Thanks again. Just as what you have said, I didn't store data successfully once because I never get into the example_cb_handler. Actually I didn't open the system_eve_handler in ble_stack_init();, does this cause the problem? But once I open it ,my code will run out of control, I really don't konw why.
  • I tried use the original example project "ble_app_template" and try again, and I successfully get into the cb_handler and load the data successfully, I think it might just because I modified the schedluer or something else in my project to cause the problem. Thank you very much!
