PASSKEY
 I’ve downloaded     nRF5_SDK_11.0.0_89a8197 and starting with examples from \examples\ble_peripheral\???\pca10040\s132\arm5_no_packs\
 I would like the other device to request a passkey (constant) at pairing (the passkey on my side is constant - no display needed)
After   gap_params_init();I’ve added the following code:
 static ble_opt_t optS;
   static uint8_t passw[]="123456";
 optS.gap_opt.passkey.p_passkey=passw;
   err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &optS);
err_code returned :  0
Still the module will pair and communicate without requesting a passkey.
I've tried to find an answer in Q&A . in some answers there was a reference to fields : io_caps,mitm. cant make out what does it mean.
(these fields belong to structs relevant to services, not pairing)
Thanks for any help
   Yona
  • Hi Yona,
    Looks like I forgot to mention that you need to enable MITM and set IO capability in device_manager_init(). See diff file below for necessary changes:
    diff --git a/examples/ble_peripheral/ble_app_hrs/main.c b/examples/ble_peripheral/ble_app_hrs/main.c
    index 6facd54..b7bf916 100644
    --- a/examples/ble_peripheral/ble_app_hrs/main.c
    +++ b/examples/ble_peripheral/ble_app_hrs/main.c
    @@ -87,10 +87,10 @@
     #define MAX_CONN_PARAMS_UPDATE_COUNT     3                                          /**< Number of attempts before giving up the connection parameter negotiation. */
     #define SEC_PARAM_BOND                   1                                          /**< Perform bonding. */
    -#define SEC_PARAM_MITM                   0                                          /**< Man In The Middle protection not required. */
    +#define SEC_PARAM_MITM                   1                                          /**< Man In The Middle protection not required. */
     #define SEC_PARAM_LESC                   0                                          /**< LE Secure Connections not enabled. */
     #define SEC_PARAM_KEYPRESS               0                                          /**< Keypress notifications not enabled. */
    -#define SEC_PARAM_IO_CAPABILITIES        BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
    +#define SEC_PARAM_IO_CAPABILITIES        BLE_GAP_IO_CAPS_DISPLAY_ONLY               /**< No I/O capabilities. */
     #define SEC_PARAM_OOB                    0                                          /**< Out Of Band data not available. */
     #define SEC_PARAM_MIN_KEY_SIZE           7                                          /**< Minimum encryption key size. */
     #define SEC_PARAM_MAX_KEY_SIZE           16                                         /**< Maximum encryption key size. */
    @@ -327,6 +327,15 @@ static void gap_params_init(void)
    +    static ble_opt_t optS;
    +    static uint8_t passw[]="123456";
    +    optS.gap_opt.passkey.p_passkey=passw;
    +    err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &optS);
    +    APP_ERROR_CHECK(err_code);
    @@ -455,7 +464,7 @@ static void services_init(void)
         BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
         BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
    -    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
    +    BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&hrs_init.hrs_bsl_attr_md.read_perm);
         BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
         err_code = ble_hrs_init(&m_hrs, &hrs_init);
    Vidar
  • Hi again
    although all works, still I have a small issue.
    no problem to force read,write  to demand a PASSKEY,
    BUT cant make "notify" demand it.
    if       char_md.p_cccd_md  = &cccd_md;
    and I write
        BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.write_perm);
    then  sd_ble_gatts_characteristic_add   returns error=7 (NRF_ERROR_INVALID_PARAM)
    if I dont write it  then even if "read" demands PASSKEY, its "notify" dosnt
    maby the problem is in the way I "make" read,notify:
    if read without notify then I use      sd_ble_gatts_value_set
    if notify is involved then                  sd_ble_gatts_hvx   (same call covers read & notify)
    (at the time- it didnt work any other way)
    what do you think ?
    thanks again and again
    Yona
  • Leave the cccd_md open, apply the BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM to the attr_md only.
  • doing so- makes the "notify" answer without requesting a passkey
