PASSKEY
 I’ve downloaded     nRF5_SDK_11.0.0_89a8197 and starting with examples from \examples\ble_peripheral\???\pca10040\s132\arm5_no_packs\
 I would like the other device to request a passkey (constant) at pairing (the passkey on my side is constant - no display needed)
After   gap_params_init();I’ve added the following code:
 static ble_opt_t optS;
   static uint8_t passw[]="123456";
 optS.gap_opt.passkey.p_passkey=passw;
   err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &optS);
err_code returned :  0
Still the module will pair and communicate without requesting a passkey.
I've tried to find an answer in Q&A . in some answers there was a reference to fields : io_caps,mitm. cant make out what does it mean.
(these fields belong to structs relevant to services, not pairing)
Thanks for any help
   Yona
    Do you get invalid param if your remove BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.read_perm);? You only need BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.write_perm); to require authentication for notifications.
  • Hi
    Do you get invalid param?    yes
    if I dont     BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.read_perm)   everything works
    meaning: read+write demand a passkey. notify dosnt.
    for example: my characteristic   is read+notify.
    upon power up + BLE connection/pairing... I will get notifys without any request for PASSKEY.
    then: when trying to read  for the 1st time (notify & read - return the same data)- I'm required to enter a passkey
    (ONLY THEN)
    thats why I tried to mess  with cccd_md.
    Yona
  • maybe there is a work around this  (cant force NOTIFY to demand a passkey - if PASSKEY was not entered yet)
    if I can see at some location - how the pairing+security are doing (MITM+PASSKEY+...)
    then I can NOTIFY / output a READ only if pairing+security are cleared
    Yona
    Notifications are enabled by writing to the 0x2 to the CCCD so it is the write operation that should require authentication. It's not possible  to require authentication for reading of the CCCD, and that is why the softdevice returns the invalid param error. Note that CCCD only contains the configuration value, not the characteristic value. Also worth noting that this configuration is persistent across connections when the devices are bonded.
    The characteristic value permissions are set on attr_md.read_perm  and  attr_md.write_perm if you use ble_hrs.c::heart_rate_measurement_char_add()as reference.
  • Hi again
    eventually I found   the variable    m_connection_table[0].state
    it contains the connection state- so if passkey not cleared - I can avoid notifys.
    now if I may- a new issue:     sd_flash_write,sd_flash_page_erase
    calling sd_flash_write returns (after 20uS)  0x00 (probably NRF_SUCCESS)
    than (after 2870uS) at   sys_evt_dispatch i receive  sys_evt=2    ( probably NRF_EVT_FLASH_OPERATION_SUCCESS)
    STILL nothing is written to flash.
    maybe you have a clue to what I'm doing wrong.
    using nRF5_SDK_11.0.0_89a8197  SW package.
    thanks again
    YONA
