Adding and enabling nRF driver to a project in SEGGER through CMSIS configuration wizard
Hi DevZone,
I am new to nRF SoC and SEGGER. After installing all tools, I can build and run examples.
I run into a problem to add and enable a nRF driver, like "UARTE peripheral driver", what are the procedure and step to do that?
I try to use the CMSIS configuration wizard to do that, but I found the followings in different examples as:
where I can enable the device I want to use, but on some example I found:
I even can not see "NRFX_UARTE_ENABLED - nrfx_uarte - UARTE peripheral driver" overthere.
So anybody can help me on two questions:
1. how to add and enable a nRF driver to a project under SEGGER?
2. how to add those missing modules, nRF driver on CMSIS configuration wizard?
HRB
  • Hi HRB,
    • For "Importing files and drivers" please check out this tutorial.
    • For "How to use the CMSIS Configuration Wizard" please check out this tutorial.
  • Did this get sorted out? I'm having the same problem and neither of the provided references says how to get a driver to show up in CMSIS Wizard if it's not already there...
  • Hi Ron,
    The CMIS Wizard is just a graphical representation of what's in the sdk_config.h file.
    If something that you need is not in there, you have to add it to the sdk_config.h file first.
    The easiest solution would be to copy from a project what already have what you need in the sdk_config.h.
    (example on how to add something that's missing in sdk_config is listed here)
    //cheers
  • Hi Martin,
    The tutorial to "CMSIS Configuration Wizard" worked to a certain extent.
    Prior to inserting the additional line of code below, the option to open CMSIS Config Wizard was not even available. However after inserting the code, I could see the option and click on it.
    Here's the problem. Upon clicking the option, no wizard/window pops out for me to enable RTT & Logging.
    I am following this tutorial here:
    https://youtu.be/uP8RYgYGRvI?t=168
    Thank you for your help and support in advanced!!
    Kin Sern
  • Hi Kin,
    Please make a new ticket since this case is over 2 years old and then also specify which segger version you are using in the new ticket.
1 2
