NO BSP CALLBACK ON NRF52810
I init the bsp for button, but there is no callback in handler when press on button.
The board is NRF52810, and there are so many problems when I test this borad.
It's software is really bad.
These are my code.
#include <string.h>
#include "hal_nfc7963.h"
#include "hal_spi.h"
#include "nordic_common.h"
#include "hal_user.h"
#include "boards.h"
#include "bsp.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "hal_nfc_task.h"
#include "hal_uart.h"
#include "math.h"
#include "app_timer.h"
#include "app_scheduler.h"
#define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE             /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE                20                                          /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE                10                                          /**< Maximum number of events in the scheduler queue. */
uint8_t eve_data = 0;
static void idle_state_handle(void);
static void scheduler_init(void);
static void bsp_evt_handler(bsp_event_t evt);
static void app_sched_event_handle(void * p_event_data, uint16_t event_size);
				bsp_board_led_invert(BSP_BOARD_LED_0);
//				hal_beep_enable();
	//			HAL_NFC_SPI_Read(0x00,1);
	switch(evt)
		case BSP_BOARD_BUTTON_0:
			app_sched_event_put(&eve_data,sizeof(eve_data),app_sched_event_handle);
void bsp_configuration()
    uint32_t err_code;
    err_code = bsp_init(BSP_INIT_BUTTONS | BSP_INIT_LEDS, bsp_evt_handler);
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    app_sched_execute();
//    if (NRF_LOG_PROCESS() == false)
//        nrf_pwr_mgmt_run();
	hal_user_init();
//	hal_uart_init();
	bsp_configuration();
//	hal_spi_init();
//	hal_nfc_init();
//	hal_nfc_enable();
	scheduler_init();
	for (;;)
        idle_state_handle();
#include <stdbool.h>
#include "boards.h"
#include "app_error.h"
#include "app_button.h"
#include "bsp.h"
#include "nrf_drv_clock.h"
#include "sdk_errors.h"
#include "nrf_drv_systick.h"
#include "nrf_drv_pwm.h"
#include "nrf_gpiote.h"
#include "nrf_gpio.h"
#include "nrf_drv_gpiote.h"
static nrf_drv_pwm_t pwm0 = NRF_DRV_PWM_INSTANCE(0);
static uint16_t const              pwm0_top  = 150;
static uint16_t const              pwm0_step = 200;
static nrf_pwm_values_common_t /*const*/ seq_values[] =
             0,
        0x8000,
             0,
        0x8000,
static nrf_pwm_sequence_t const    pwm0_seq =
    .values.p_common     = seq_values,
    .length              = NRF_PWM_VALUES_LENGTH(seq_values),
    .repeats             = 0,
    .end_delay           = 0
static void pwm_init(void);
static void pwm0_handler(nrf_drv_pwm_evt_type_t event_type);
static void	clock_init(void);
static void timer_init(void);
static void system_clock_init(void);
static void	log_init(void);
static void drv_clock_init();
static void leds_init(void)
	if(event_type == NRFX_PWM_EVT_FINISHED || event_type == NRFX_PWM_EVT_STOPPED)
		hal_beep_disable();
static void pwm_init()
//	nrf_drv_gpiote_out_config_t pwm_pin_config = GPIOTE_CONFIG_OUT_SIMPLE(true);
//	APP_ERROR_CHECK(nrf_drv_gpiote_out_init(BEEP, &pwm_pin_config));
	nrf_drv_pwm_config_t const config0 =
		.output_pins =
			BEEP | NRF_DRV_PWM_PIN_INVERTED, // channel 0
			NRF_DRV_PWM_PIN_NOT_USED,
		.irq_priority = APP_IRQ_PRIORITY_LOWEST,
		.base_clock   = NRF_PWM_CLK_1MHz,
		.count_mode   = NRF_PWM_MODE_UP,
		.top_value	  = pwm0_top,
		.load_mode	  = NRF_PWM_LOAD_COMMON,
		.step_mode	  = NRF_PWM_STEP_AUTO
	APP_ERROR_CHECK(nrf_drv_pwm_init(&pwm0, &config0, pwm0_handler));
void timer_init()
	uint32_t err_code;
    err_code = app_timer_init();
static void clock_init()
    NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
	ret_code_t err_code;
	err_code = nrf_drv_clock_init();
static void system_clock_init()
	nrf_drv_systick_init();
static void log_init()
void hal_user_init()
//	hal_user_log_init();
  drv_clock_init();
	clock_init();
	system_clock_init();
	timer_init();
void hal_beep_enable()
	pwm_init();
	(void)nrf_drv_pwm_simple_playback(&pwm0, &pwm0_seq, 1000, NRFX_PWM_FLAG_STOP);
void hal_beep_disable()
	nrfx_pwm_stop(&pwm0,false);
	nrfx_pwm_uninit(&pwm0);
	nrfx_gpiote_out_toggle(BEEP);
// <q> BUTTON_ENABLED  - Enables Button module
#ifndef BUTTON_ENABLED
#define BUTTON_ENABLED 1
// <q> BUTTON_HIGH_ACCURACY_ENABLED  - Enables GPIOTE high accuracy for buttons
#ifndef BUTTON_HIGH_ACCURACY_ENABLED
#define BUTTON_HIGH_ACCURACY_ENABLED 0
// <e> APP_TIMER_ENABLED - app_timer - Application timer functionality
#ifndef APP_TIMER_ENABLED
#define APP_TIMER_ENABLED 1
// <o> APP_TIMER_CONFIG_RTC_FREQUENCY  - Configure RTC prescaler.
// <0=> 32768 Hz
// <1=> 16384 Hz
// <3=> 8192 Hz
// <7=> 4096 Hz
// <15=> 2048 Hz
// <31=> 1024 Hz
#ifndef APP_TIMER_CONFIG_RTC_FREQUENCY
#define APP_TIMER_CONFIG_RTC_FREQUENCY 0
// <o> APP_TIMER_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef APP_TIMER_CONFIG_IRQ_PRIORITY
#define APP_TIMER_CONFIG_IRQ_PRIORITY 7
// <o> APP_TIMER_CONFIG_OP_QUEUE_SIZE - Capacity of timer requests queue.
// <i> Size of the queue depends on how many timers are used
// <i> in the system, how often timers are started and overall
// <i> system latency. If queue size is too small app_timer calls
// <i> will fail.
#ifndef APP_TIMER_CONFIG_OP_QUEUE_SIZE
#define APP_TIMER_CONFIG_OP_QUEUE_SIZE 10
// <q> APP_TIMER_CONFIG_USE_SCHEDULER  - Enable scheduling app_timer events to app_scheduler
#ifndef APP_TIMER_CONFIG_USE_SCHEDULER
#define APP_TIMER_CONFIG_USE_SCHEDULER 0
// <q> APP_TIMER_KEEPS_RTC_ACTIVE  - Enable RTC always on
// <i> If option is enabled RTC is kept running even if there is no active timers.
// <i> This option can be used when app_timer is used for timestamping.
#ifndef APP_TIMER_KEEPS_RTC_ACTIVE
#define APP_TIMER_KEEPS_RTC_ACTIVE 0
// <h> App Timer Legacy configuration - Legacy configuration.
// <q> APP_TIMER_WITH_PROFILER  - Enable app_timer profiling
#ifndef APP_TIMER_WITH_PROFILER
#define APP_TIMER_WITH_PROFILER 0
// <q> APP_TIMER_CONFIG_SWI_NUMBER  - Configure SWI instance used.
#ifndef APP_TIMER_CONFIG_SWI_NUMBER
#define APP_TIMER_CONFIG_SWI_NUMBER 0
// </h>
// <e> RTC_ENABLED - nrf_drv_rtc - RTC peripheral driver - legacy layer
#ifndef RTC_ENABLED
#define RTC_ENABLED 0
// <o> RTC_DEFAULT_CONFIG_FREQUENCY - Frequency  <16-32768>
#ifndef RTC_DEFAULT_CONFIG_FREQUENCY
#define RTC_DEFAULT_CONFIG_FREQUENCY 32768
// <q> RTC_DEFAULT_CONFIG_RELIABLE  - Ensures safe compare event triggering
#ifndef RTC_DEFAULT_CONFIG_RELIABLE
#define RTC_DEFAULT_CONFIG_RELIABLE 0
// <o> RTC_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef RTC_DEFAULT_CONFIG_IRQ_PRIORITY
#define RTC_DEFAULT_CONFIG_IRQ_PRIORITY 7
// <q> RTC0_ENABLED  - Enable RTC0 instance
#ifndef RTC0_ENABLED
#define RTC0_ENABLED 1
// <q> RTC1_ENABLED  - Enable RTC1 instance
#ifndef RTC1_ENABLED
#define RTC1_ENABLED 1
// <q> RTC2_ENABLED  - Enable RTC2 instance
#ifndef RTC2_ENABLED
#define RTC2_ENABLED 1
// </e>
// <e> NRFX_RTC_ENABLED - nrfx_rtc - RTC peripheral driver
#ifndef NRFX_RTC_ENABLED
#define NRFX_RTC_ENABLED 0
// <q> NRFX_RTC0_ENABLED  - Enable RTC0 instance
#ifndef NRFX_RTC0_ENABLED
#define NRFX_RTC0_ENABLED 1
// <q> NRFX_RTC1_ENABLED  - Enable RTC1 instance
#ifndef NRFX_RTC1_ENABLED
#define NRFX_RTC1_ENABLED 1
// <o> NRFX_RTC_MAXIMUM_LATENCY_US - Maximum possible time[us] in highest priority interrupt
#ifndef NRFX_RTC_MAXIMUM_LATENCY_US
#define NRFX_RTC_MAXIMUM_LATENCY_US 2000
// <o> NRFX_RTC_DEFAULT_CONFIG_FREQUENCY - Frequency  <16-32768>
#ifndef NRFX_RTC_DEFAULT_CONFIG_FREQUENCY
#define NRFX_RTC_DEFAULT_CONFIG_FREQUENCY 32768
// <q> NRFX_RTC_DEFAULT_CONFIG_RELIABLE  - Ensures safe compare event triggering
#ifndef NRFX_RTC_DEFAULT_CONFIG_RELIABLE
#define NRFX_RTC_DEFAULT_CONFIG_RELIABLE 0
// <o> NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY 7
// <e> NRFX_RTC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_RTC_CONFIG_LOG_ENABLED
#define NRFX_RTC_CONFIG_LOG_ENABLED 0
// <o> NRFX_RTC_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef NRFX_RTC_CONFIG_LOG_LEVEL
#define NRFX_RTC_CONFIG_LOG_LEVEL 3
// <o> NRFX_RTC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_RTC_CONFIG_INFO_COLOR
#define NRFX_RTC_CONFIG_INFO_COLOR 0
// <o> NRFX_RTC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_RTC_CONFIG_DEBUG_COLOR
#define NRFX_RTC_CONFIG_DEBUG_COLOR 0
// </e>
//these are my symbol.
BOARD_CUSTOM CONFIG_GPIO_AS_PINRESET DEVELOP_IN_NRF52832 FLOAT_ABI_SOFT NRF52810_XXAA NRF52_PAN_74 __HEAP_SIZE=2048 __STACK_SIZE=2048 USE_APP_CONFIG SWI_DISABLE0
Thanks.
Best Regards.
