Buttonless DFU with bond not working
I'm struggling to get Buttonless DFU with bond enabled working.
Setup details:
1) SDK 14.2
2) DK board - nrf52832
3) nrfconnect app on Android phone (8.0) :
DFU settings = Pkts receipt notification procedure : ON
Number of packets : 10
MBR : 4096
Keep bond information: ON
External MCU DFU : OFF
4) Custom app with bond enabled, BLE_GAP_ADDR_TYPE_RANDOM_STATIC(C1:C1:C1:C1:C1:C1), MITM enabled,
Followed the steps to generate bootloader keys and everything seems to be fine. Flashed SD, BL, APP onto DK board and I can see the app running.
Connected nrfconnect to my custom app, paired succesfully. I can see secure DFU service with Secure buttonless DFU.
After enabling the indication, I write value "0x01" and send to switch to DFU mode. I see device moved to DFU mode but with BD addr = EA:F8:73:D2:B8:CC.
Connected nrfconnect to DfuTarg and if I try to DFU, I think device switches to my custom app and I don't see DFU happening any more.
I'm wondering what would be wrong and I believe encryption fails due to different BD address used in DFU and app mode. What am I missing?
Tried looking into Nordic blogs, dev support but could not move forward. Also, I tried to see the DFU NRF log but I don't see any log messages
All I see on power ON is
<info> µ˜°: Setting vector table to bootloader: 0x00066000
<info> µ˜°: Setting vector table to main app: 0x00023000
<info> µ˜°: Record ID:    0x0001
<info> µ˜°: File ID:    0xF020
<info> µ˜°: Record key:    0x7010
I did used \nRF5_SDK_14.2.0_17b948a\examples\dfu\bootloader_secure_ble\pca10040_debug\armgcc\Makefile with logger enabled and optimization is -O0 in makefile. I'm not sure DFU logger does not show up in RTT viewer.
Attached are the config,make files for reference.
Your help is highly appreciated.
dfu.rarapp.rar
  • I did tested Buttonless DFU without bond and it works like charm.
  • The full Log messages in app while moving to DFU mode are below
    <info> µ˜°: Power strip initialisation done.
    <info> µ˜°: Connected
    <info> µ˜°: Connection secured: role: 1, conn_handle: 0x0, procedure: 0.
    <info> µ˜°: Disconnected
    <info> µ˜°: Connection secured: role: 1, conn_handle: 0x0, procedure: 1.
    <info> µ˜°: Received indication state 1
    <error> µ˜°: Request to enter bootloader mode failed asynchroneously.
    <info> µ˜°: Writing peer data to the bootloader
    <info> µ˜°: ---------------system attribute table: 8--------------
    <info> µ˜°: BD address type : 0
    <info> µ˜°: BD address : 0xF4
    <info> µ˜°: BD address : 0xAE
    <info> µ˜°: BD address : 0x1F
    <info> µ˜°: BD address : 0xA6
    <info> µ˜°: BD address : 0xB4
    <info> µ˜°: BD address : 0x88
    <info> µ˜°: Set peer data request accepted
    <info> µ˜°: Device is preparing to enter bootloader mode.
    <info> µ˜°: Device will enter bootloader mode.
    By default, the SoftDevice will use DEVICEADDR[0] and (half of) DEVICEADDR[1] as the MAC address. This will be used by both the bootloader and application unless you explicitly set some other address. If you set another address in your application (why?), then you must do so in the bootloader as well.
    The example without bond sharing however, does not rely on having the same address. In fact, it needs to have a different address and will therefore typically be the default mac address (from  DEVICEADDR) incremented by one.
    To have unique address for different products. After doing as per your suggestion, I could progress little bit but now I get dfu error "Remote DFU error: INVALID OBJECT". I believe it is for Execute Opcode i.e. dfu_decode_commmand() returning false. I see log message in the dfu code as "Handler: Invalid protocol buffer stream". Not sure what I'm missing.
    Attached log file captured.
    Appreciate your help
    nRF Connect, 2018-06-25
    Aquapark_N (C0:C0:C0:C0:C0:C0)
    V	20:24:34.320	Connecting to C0:C0:C0:C0:C0:C0...
    D	20:24:34.321	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	20:24:34.394	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	20:24:34.394	Connected to C0:C0:C0:C0:C0:C0
    D	20:24:34.398	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	20:24:34.431	Discovering services...
    D	20:24:34.431	gatt.discoverServices()
    I	20:24:35.204	PHY updated (TX: LE 2M, RX: LE 2M)
    I	20:24:35.657	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	20:24:35.909	[Callback] Services discovered with status: 0
    I	20:24:35.909	Services discovered
    V	20:24:35.943	Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    - Central Address Resolution [R] (0x2AA6)
    Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    Secure DFU Service (0xFE59)
    - Secure Buttonless DFU [I W] (8ec90004-f315-4f60-9fb8-838830daea50)
    Unknown Service (003c1520-0000-1000-8000-00805f9b0141)
    - Unknown Characteristic [N R W] (003c1521-0000-1000-8000-00805f9b0141)
       Characteristic User Description (0x2901)
    - Unknown Characteristic [N R W] (003c1522-0000-1000-8000-00805f9b0141)
    - Unknown Characteristic [N R] (003c1523-0000-1000-8000-00805f9b0141)
    - Unknown Characteristic [R] (003c1524-0000-1000-8000-00805f9b0141)
    - Unknown Characteristic [W] (003c1525-0000-1000-8000-00805f9b0141)
    - Unknown Characteristic [R] (003c1526-0000-1000-8000-00805f9b0141)
    D	20:24:35.943	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	20:24:35.946	gatt.setCharacteristicNotification(8ec90004-f315-4f60-9fb8-838830daea50, true)
    D	20:24:35.949	gatt.setCharacteristicNotification(003c1521-0000-1000-8000-00805f9b0141, true)
    D	20:24:35.952	gatt.setCharacteristicNotification(003c1522-0000-1000-8000-00805f9b0141, true)
    D	20:24:35.956	gatt.setCharacteristicNotification(003c1523-0000-1000-8000-00805f9b0141, true)
    I	20:24:35.986	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    I	20:24:54.922	Connection parameters updated (interval: 195.0ms, latency: 0, timeout: 10000ms)
    V	20:29:19.059	Disconnecting...
    D	20:29:19.059	gatt.disconnect()
    D	20:29:19.064	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
    I	20:29:19.064	Disconnected
    D	20:29:19.861	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	20:29:20.173	gatt.close()
    D	20:29:20.175	wait(200)
    V	20:29:20.379	Connecting to C0:C0:C0:C0:C0:C0...
    D	20:29:20.379	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	20:29:22.217	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	20:29:22.219	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	20:29:22.219	Connected to C0:C0:C0:C0:C0:C0
    V	20:29:22.238	Discovering services...
    D	20:29:22.238	gatt.discoverServices()
    I	20:29:22.667	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	20:29:23.032	[Callback] Services discovered with status: 0
    I	20:29:23.032	Services discovered
    V	20:29:23.064	Generic Access (0x1800)
    D	20:29:23.065	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	20:29:23.068	gatt.setCharacteristicNotification(8ec90004-f315-4f60-9fb8-838830daea50, true)
    D	20:29:23.071	gatt.setCharacteristicNotification(003c1521-0000-1000-8000-00805f9b0141, true)
    D	20:29:23.073	gatt.setCharacteristicNotification(003c1522-0000-1000-8000-00805f9b0141, true)
    D	20:29:23.075	gatt.setCharacteristicNotification(003c1523-0000-1000-8000-00805f9b0141, true)
    I	20:29:23.131	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    V	20:29:27.322	Enabling indications for 8ec90004-f315-4f60-9fb8-838830daea50
    D	20:29:27.322	gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x0200)
    D	20:29:27.566	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
    D	20:29:27.582	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_PIN (0)
    I	20:29:27.961	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	20:29:32.795	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:32.795	"(0x) C4-09" received
    I	20:29:32.819	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-1A-00-07
    A	20:29:32.819	"(0x) 30-00-00-00-05-06-1A-00-07" received
    D	20:29:33.228	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
    I	20:29:33.228	Device bonded
    I	20:29:33.239	Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
    A	20:29:33.240	"Indications enabled" sent
    V	20:29:33.250	Indications enabled for 8ec90004-f315-4f60-9fb8-838830daea50
    I	20:29:33.779	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:33.779	"(0x) C4-09" received
    I	20:29:33.780	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    I	20:29:33.821	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-1B-00-07
    A	20:29:33.821	"(0x) 30-00-00-00-05-06-1B-00-07" received
    I	20:29:34.776	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:34.776	"(0x) C4-09" received
    I	20:29:34.777	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-1C-00-07
    A	20:29:34.777	"(0x) 30-00-00-00-05-06-1C-00-07" received
    I	20:29:35.805	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:35.806	"(0x) C4-09" received
    I	20:29:35.806	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-1D-00-07
    A	20:29:35.806	"(0x) 30-00-00-00-05-06-1D-00-07" received
    I	20:29:36.799	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:36.799	"(0x) C4-09" received
    I	20:29:36.799	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-1E-00-07
    A	20:29:36.800	"(0x) 30-00-00-00-05-06-1E-00-07" received
    I	20:29:37.789	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:37.789	"(0x) C4-09" received
    I	20:29:37.790	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-1F-00-07
    A	20:29:37.790	"(0x) 30-00-00-00-05-06-1F-00-07" received
    I	20:29:38.816	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:38.816	"(0x) C4-09" received
    I	20:29:38.816	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-20-00-07
    A	20:29:38.816	"(0x) 30-00-00-00-05-06-20-00-07" received
    I	20:29:39.769	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:39.769	"(0x) C4-09" received
    I	20:29:39.769	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-21-00-07
    A	20:29:39.769	"(0x) 30-00-00-00-05-06-21-00-07" received
    I	20:29:40.797	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:40.797	"(0x) C4-09" received
    I	20:29:40.797	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-22-00-07
    A	20:29:40.797	"(0x) 30-00-00-00-05-06-22-00-07" received
    I	20:29:41.823	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:41.823	"(0x) C4-09" received
    I	20:29:41.866	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-23-00-07
    A	20:29:41.866	"(0x) 30-00-00-00-05-06-23-00-07" received
    I	20:29:42.318	Connection parameters updated (interval: 195.0ms, latency: 0, timeout: 10000ms)
    I	20:29:42.903	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:42.903	"(0x) C4-09" received
    I	20:29:42.903	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-24-00-07
    A	20:29:42.903	"(0x) 30-00-00-00-05-06-24-00-07" received
    I	20:29:43.878	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:43.878	"(0x) C4-09" received
    I	20:29:43.878	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-25-00-07
    A	20:29:43.878	"(0x) 30-00-00-00-05-06-25-00-07" received
    I	20:29:44.852	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:44.852	"(0x) C4-09" received
    I	20:29:44.853	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-26-00-07
    A	20:29:44.853	"(0x) 30-00-00-00-05-06-26-00-07" received
    I	20:29:45.827	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:45.827	"(0x) C4-09" received
    I	20:29:45.828	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-27-00-07
    A	20:29:45.828	"(0x) 30-00-00-00-05-06-27-00-07" received
    V	20:29:46.413	[DFU] DFU service started
    V	20:29:46.413	[DFU] Opening file...
    I	20:29:46.420	[DFU] Firmware file opened successfully
    V	20:29:46.420	[DFU] Connecting to DFU target...
    D	20:29:46.422	[DFU] gatt = device.connectGatt(autoConnect = false)
    I	20:29:46.428	[DFU] Connected to C0:C0:C0:C0:C0:C0
    D	20:29:46.431	[DFU] wait(1600)
    I	20:29:46.805	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:46.805	"(0x) C4-09" received
    I	20:29:46.805	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-28-00-07
    A	20:29:46.805	"(0x) 30-00-00-00-05-06-28-00-07" received
    V	20:29:48.032	[DFU] Discovering services...
    D	20:29:48.032	[DFU] gatt.discoverServices()
    I	20:29:48.045	[DFU] Services discovered
    D	20:29:48.067	[DFU] wait(1000)
    I	20:29:48.173	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:48.173	"(0x) C4-09" received
    I	20:29:48.173	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-29-00-07
    A	20:29:48.173	"(0x) 30-00-00-00-05-06-29-00-07" received
    W	20:29:49.417	[DFU] Application with buttonless update found
    V	20:29:49.417	[DFU] Jumping to the DFU Bootloader...
    V	20:29:49.417	[DFU] Enabling indications for 8ec90004-f315-4f60-9fb8-838830daea50
    D	20:29:49.417	[DFU] gatt.setCharacteristicNotification(8ec90004-f315-4f60-9fb8-838830daea50, true)
    D	20:29:49.417	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
    I	20:29:49.657	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:49.657	"(0x) C4-09" received
    I	20:29:49.657	[DFU] Data written to descr.8ec90004-f315-4f60-9fb8-838830daea50, value (0x): 02-00
    V	20:29:49.657	[DFU] Notifications enabled for 8ec90004-f315-4f60-9fb8-838830daea50
    I	20:29:49.658	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-2A-00-07
    A	20:29:49.658	"(0x) 30-00-00-00-05-06-2A-00-07" received
    A	20:29:49.674	[DFU] Indications enabled
    D	20:29:49.674	[DFU] wait(1000)
    I	20:29:50.241	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:50.241	"(0x) C4-09" received
    I	20:29:50.242	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-2B-00-07
    A	20:29:50.242	"(0x) 30-00-00-00-05-06-2B-00-07" received
    V	20:29:50.691	[DFU] Writing to characteristic 8ec90004-f315-4f60-9fb8-838830daea50
    D	20:29:50.691	[DFU] gatt.writeCharacteristic(8ec90004-f315-4f60-9fb8-838830daea50)
    I	20:29:51.021	Indication received from 8ec90004-f315-4f60-9fb8-838830daea50, value: (0x) 20-01-01
    A	20:29:51.021	"(0x) 20-01-01" received
    I	20:29:51.030	[DFU] Notification received from 8ec90004-f315-4f60-9fb8-838830daea50, value (0x): 20-01-01
    A	20:29:51.030	[DFU] Enter bootloader sent (Op Code = 1)
    A	20:29:51.030	[DFU] Response received (Op Code = 1, Status = 1)
    I	20:29:51.217	Notification received from 003c1523-0000-1000-8000-00805f9b0141, value: (0x) C4-09
    A	20:29:51.217	"(0x) C4-09" received
    I	20:29:51.217	Notification received from 003c1521-0000-1000-8000-00805f9b0141, value: (0x) 30-00-00-00-05-06-2C-00-07
    A	20:29:51.217	"(0x) 30-00-00-00-05-06-2C-00-07" received
    D	20:29:51.609	[Callback] Connection state changed with status: 19 and new state: DISCONNECTED (0)
    W	20:29:51.609	Connection terminated by peer (status 19)
    I	20:29:51.609	Disconnected
    I	20:29:51.656	[DFU] Disconnected by the remote device
    D	20:29:51.656	[DFU] gatt.close()
    D	20:29:51.656	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	20:29:51.657	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    V	20:29:51.667	[DFU] DFU service started
    I	20:29:51.667	[DFU] Firmware file opened successfully
    D	20:29:51.667	[DFU] wait(1000)
    D	20:29:52.665	[DFU] wait(1000)
    V	20:29:53.667	[DFU] Connecting to DFU target...
    D	20:29:53.717	[DFU] gatt = device.connectGatt(autoConnect = false)
    D	20:29:54.815	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	20:29:54.816	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    I	20:29:54.818	[DFU] Connected to C0:C0:C0:C0:C0:C0
    D	20:29:54.825	[DFU] wait(1600)
    V	20:29:56.426	[DFU] Discovering services...
    D	20:29:56.427	[DFU] gatt.discoverServices()
    I	20:29:56.434	[DFU] Services discovered
    D	20:29:56.459	[DFU] wait(1000)
    V	20:29:57.494	[DFU] Requesting new MTU...
    D	20:29:57.494	[DFU] gatt.requestMtu(517)
    I	20:29:57.561	[DFU] MTU changed to: 23
    V	20:29:57.561	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
    D	20:29:57.561	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
    D	20:29:57.561	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I	20:29:57.621	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
    V	20:29:57.621	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
    A	20:29:57.621	[DFU] Notifications enabled
    D	20:29:57.621	[DFU] wait(1000)
    V	20:29:58.664	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	20:29:58.664	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	20:29:58.790	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-01-00-00-00-00-00-00-00-00-00-00
    I	20:29:58.790	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-01-00-00-00-00-00-00-00-00-00-00
    A	20:29:58.790	[DFU] Command object info received (Max size = 256, Offset = 0, CRC = 00000000)
    V	20:29:58.790	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	20:29:58.790	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	20:29:58.880	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01
    I	20:29:58.881	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01
    A	20:29:58.881	[DFU] Packet Receipt Notif disabled (Op Code = 2, Value = 0)
    V	20:29:58.882	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	20:29:58.882	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	20:29:58.968	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-01-87-00-00-00
    I	20:29:58.968	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	20:29:58.968	[DFU] Command object created
    V	20:29:58.969	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.969	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.970	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 12-84-01-0A-3E-08-01-12-3A-08-02-10-34-1A-02-9D-01-20-00-28
    V	20:29:58.970	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.970	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.971	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 00-30-00-38-BC-EA-04-42-24-08-03-12-20-79-59-EA-80-6B-E0-33
    V	20:29:58.971	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.971	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.972	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 2D-33-2F-3B-DD-60-92-A7-0F-52-B7-4B-D8-34-E5-31-CD-06-D2-D3
    V	20:29:58.972	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.972	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.974	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): C7-A5-54-70-B1-48-00-10-00-1A-40-A9-66-C0-27-A3-26-B7-5A-CB
    V	20:29:58.974	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.974	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.981	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 55-78-E0-E7-69-5A-4A-5E-D8-54-DF-A6-23-11-56-40-88-A5-B9-92
    V	20:29:58.981	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.981	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.983	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): EA-43-E1-7A-8E-84-FB-7F-CF-50-B5-8C-E2-B9-A5-11-94-F4-CF-C9
    V	20:29:58.983	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	20:29:58.983	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	20:29:58.988	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): B5-79-4B-19-28-4D-9D-16-4B-D4-BF-72-EE-15-60
    A	20:29:58.989	[DFU] Command object sent (CRC = 2D2E7274)
    V	20:29:58.989	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	20:29:58.989	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	20:29:59.106	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-87-00-00-00-74-72-2E-2D
    I	20:29:59.106	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-87-00-00-00-74-72-2E-2D
    A	20:29:59.106	[DFU] Checksum received (Offset = 135, CRC = 2D2E7274)
    V	20:29:59.106	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	20:29:59.106	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	20:29:59.197	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	20:29:59.418	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-05
    E	20:29:59.422	[DFU] Remote DFU error: INVALID OBJECT
    V	20:29:59.422	[DFU] Disconnecting...
    D	20:29:59.463	[DFU] gatt.disconnect()
    I	20:29:59.463	[DFU] Disconnected
    D	20:29:59.463	[DFU] gatt.close()
    D	20:29:59.463	[DFU] wait(600)
    D	20:30:00.040	gatt.close()
    D	20:30:00.044	wait(200)
    V	20:30:00.246	Connecting to C0:C0:C0:C0:C0:C0...
    D	20:30:00.246	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	20:30:00.258	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	20:30:00.258	Connected to C0:C0:C0:C0:C0:C0
    D	20:30:00.259	wait(1600ms)
    V	20:30:01.860	Discovering services...
    D	20:30:01.860	gatt.discoverServices()
    D	20:30:01.864	[Callback] Services discovered with status: 0
    I	20:30:01.864	Services discovered
    V	20:30:01.880	Generic Access (0x1800)
    - DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
    - DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
    D	20:30:01.880	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	20:30:01.883	gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
    D	20:32:03.596	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E	20:32:03.596	Error 8 (0x8): GATT CONN TIMEOUT
    I	20:32:03.596	Disconnected
    D	20:32:03.610	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    Einar is out of office, so I will handle your case.
    Having the same address for all products seems a bit strange, as it may cause some issues separating several devices if there are multiple devices in the same area. The standard way of doing this is to use the DEVICEADDR[0] and DEVICEADDR[1], and use the advertising data to find the device that you are looking for.
    INVALID OBJECT usually means that the DFU packet is not accepted. How did you generate your DFU packet? Did you set the correct HW version, SD-version and application version? Note that the application version has to be incremented by at least 1 from the application that is currently running. So if you already uploaded the packet, you need to create a new DFU packet with application-version += 1 for the bootloader to accept it.
    Edvin
