Ble connection drops out on button press
I have a custom board with nrf51422-QFAC, used with SD 130 and SDK 12.3.0. My firmware consist of ble_app_hids_keyboard example modified. Schematics are attached below.
When I connect the board to a central, all four buttons are working fine until I put the pcb in my device body. When the pcb is inside the device body, pressing buttons on pins P0.26 and P0.01 cause a disconnect every 3/5 times. The connection remains stable only when I connect my board with nRF Connect app for Android. Device body is made of 1-2 mm plastic and a rubber keyboard on top. The configuration for the buttons is the default from the examples and they are working fine.
I want to clarify that the board is powered from a 3.7V LiPo battery, which is connected to J3 and J5, which go directly to the chip (the battery is charged to 3.6-3.8 V and skips the power circuit). The reason is that I have a big mistake with the power circuit with the tps61220, which is about to be redesigned. Before I make the new design I want to know if I have to do some hardware changes about the disconnecting issue and what is causing this behaviour.
Thank you!
Hancy_1.pdf
