The computer and the 52832 are connected through a serial port. I want to send 2Kb data to my computer. But my computer can only receive 256b data. What should I do?
Can you explain a little bit more about your setup please
Thank you for your answer. I'm a newbie and I hope you can read my code. I can only receive part of the data. what should I do? Thanks again!
* Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "atcmd.h"
#include "es_battery_voltage.h"
#include "app_fifo.h"
#include "nrf_delay.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define SCAN_INTERVAL 0x4000 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x4000 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_TIMEOUT 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define UUID16_SIZE 2 /**< Size of 16 bit UUID */
#define UUID32_SIZE 4 /**< Size of 32 bit UUID */
#define UUID128_SIZE 16 /**< Size of 128 bit UUID */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
#define SCAN_RES_MAX 300
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
APP_TIMER_DEF(m_scan_timer_id1);
APP_TIMER_DEF(m_scan_timer_id2);
uint8_t num = 0;
bool isScanning = false;
uint16_t scanTime1 = 2000;
#define SCAN_TIMER_INTERVAL1 APP_TIMER_TICKS(scanTime1)
#define SCAN_TIMER_WINDOW APP_TIMER_TICKS(3000)
void printfScan(void);
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud9600
typedef struct Data
char name[20];
char mac[12];
char rssi;
int major;
int minor;
}Data;
Data scanData[SCAN_RES_MAX];
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param1 =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
(uint16_t)SLAVE_LATENCY, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
.active = 1,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_TIMEOUT,
#if (NRF_SD_BLE_API_VERSION <= 2)
.selective = 0,
.p_whitelist = NULL,
#if (NRF_SD_BLE_API_VERSION >= 3)
.use_whitelist = 0,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
void scan_start(void)
ret_code_t ret;
ret = sd_ble_gap_scan_start(&m_scan_params);
APP_ERROR_CHECK(ret);
isScanning = true;
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service.
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
static uint8_t data_array[UART_RX_BUF_SIZE];
static uint16_t index = 0;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') )
if(UAart_Command(data_array) == 0)
printf("command error!\r\n");
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling NUS Client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
* @param[in] p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
ret_code_t err_code;
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
* @brief Function for shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Reads an advertising report and checks if a UUID is present in the service list.
* @details The function is able to search for 16-bit, 32-bit and 128-bit service UUIDs.
* To see the format of a advertisement packet, see
* https://www.bluetooth.org/Technical/AssignedNumbers/generic_access_profile.htm
* @param[in] p_target_uuid The UUID to search for.
* @param[in] p_adv_report Pointer to the advertisement report.
* @retval true if the UUID is present in the advertisement report. Otherwise false
static bool is_uuid_present(ble_uuid_t const * p_target_uuid,
ble_gap_evt_adv_report_t const * p_adv_report)
ble_uuid_t extracted_uuid;
uint16_t index = 0;
uint8_t * p_data = (uint8_t *)p_adv_report->data;
while (index < p_adv_report->dlen)
uint8_t field_length = p_data[index];
uint8_t field_type = p_data[index + 1];
if ( (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
|| (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE))
for (uint32_t i = 0; i < (field_length / UUID16_SIZE); i++)
err_code = sd_ble_uuid_decode(UUID16_SIZE,
&p_data[i * UUID16_SIZE + index + 2],
&extracted_uuid);
if (err_code == NRF_SUCCESS)
if (extracted_uuid.uuid == p_target_uuid->uuid)
return true;
else if ( (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_MORE_AVAILABLE)
|| (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_COMPLETE))
for (uint32_t i = 0; i < (field_length / UUID32_SIZE); i++)
err_code = sd_ble_uuid_decode(UUID32_SIZE,
&p_data[i * UUID32_SIZE + index + 2],
&extracted_uuid);
if ( (extracted_uuid.uuid == p_target_uuid->uuid)
&& (extracted_uuid.type == p_target_uuid->type))
return true;
else if ( (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
|| (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE))
err_code = sd_ble_uuid_decode(UUID128_SIZE, &p_data[index + 2], &extracted_uuid);
return true;
index += field_length + 1;
return false;
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_ADV_REPORT:
uint8_t index = 0;
bool flag = false;
ble_gap_evt_adv_report_t const * p_adv_report = &p_gap_evt->params.adv_report;
if(p_adv_report->scan_rsp == 0)
for(int i = 0; i < num; i ++)
if(strcmp(scanData[i].mac,p_adv_report->peer_addr.addr) == 0)
flag = true;
scanData[i].rssi = (uint8_t)(-p_adv_report->rssi);
if(flag == false)
while(index < (p_adv_report->dlen) )
if(((uint8_t)(p_adv_report->data[index+1])) != 0x09 )
index = index + (p_adv_report->data[index]) + 1;
uint8_t a = 0;
for(a = 0; a < ((uint8_t)(p_adv_report->data[index]) - 1); a++)
scanData[num].name[a] = p_adv_report->data[index + 2 + a];
scanData[num].rssi = (uint8_t)(-p_adv_report->rssi);
scanData[num].major = p_adv_report->data[25]*10+p_adv_report->data[26];
scanData[num].minor = p_adv_report->data[27]*10+p_adv_report->data[28];
strcpy(scanData[num++].mac,p_adv_report->peer_addr.addr);
}break; // BLE_GAP_EVT_ADV_REPORT
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected to target");
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
NRF_LOG_INFO("Scan timed out.");
scan_start();
else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
#ifndef S140
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
void uart_init(void)
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LED, bsp_event_handler);
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/**@brief Function for initializing the Power manager. */
static void power_init(void)
ret_code_t err_code = nrf_pwr_mgmt_init();
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
void Sorting()
uint8_t i = 0;
uint8_t j = 0;
Data temp;
for(i = 0; i < num; i ++)
for(j = i + 1; j < num; j ++)
if(scanData[i].rssi > scanData[j].rssi)
temp = scanData[i];
scanData[i] = scanData[j];
scanData[j] = temp;
void printfScan()
uint8_t i = 0;
while(i < num)
// while((app_uart_getSize()>=160&&app_uart_getSize()<=256));
printf("NUM:%d\t",i);
// printf("Name:%s\t",scanData[i].name);
printf("MAC:%02X%02X%02X%02X%02X%02X\t",
scanData[i].mac[5],
scanData[i].mac[4],
scanData[i].mac[3],
scanData[i].mac[2],
scanData[i].mac[1],
scanData[i].mac[0]
printf("major:%04X minor:%04X ",scanData[i].major,scanData[i].minor);
printf("RSSI:-%02d\r\n",scanData[i++].rssi);
num = 0;
memset(scanData,0,sizeof(Data)*SCAN_RES_MAX);
void application1_timers_start(void)
uint32_t err_code;
err_code = app_timer_start(m_scan_timer_id1, SCAN_TIMER_INTERVAL1, NULL);
void application1_timers_stop(void)
uint32_t err_code;
err_code = app_timer_stop(m_scan_timer_id1);
void application2_timers_start(void)
uint32_t err_code;
err_code = app_timer_start(m_scan_timer_id2, SCAN_TIMER_WINDOW, NULL);
isScanning = false;
void application2_timers_stop(void)
uint32_t err_code;
err_code = app_timer_stop(m_scan_timer_id2);
static void scan_timeout_handler1(void * p_context)
sd_ble_gap_scan_stop();
Sorting();
isScanning = false;
application2_timers_start();
printfScan();
static void scan_timeout_handler2(void * p_context)
application1_timers_start();
scan_start();
isScanning = true;
static void timer_init(void)
err_code = app_timer_create(&m_scan_timer_id1,
APP_TIMER_MODE_SINGLE_SHOT,
scan_timeout_handler1);
err_code = app_timer_create(&m_scan_timer_id2,
scan_timeout_handler2);
log_init();
timer_init();
power_init();
uart_init();
buttons_leds_init();
db_discovery_init();
ble_stack_init();
es_battery_voltage_init();
bsp_board_leds_init();
printf("------------------------------------------\r\n");
for (;;)
//es_battery_voltage_get();
// if(isScanning == false && num != 0)
// printfScan();
nrf_pwr_mgmt_run();
The first thing you need to determine is whether the problem lies with your computer, or with your nRF52 system.
What "computer" is it?
What type of "serial port" is it?
How are you receiving the data at the computer?
I have a 2kb data. How to use nrf52832's serial port to send this data to WiFi module? Now I can only receive data with the same length as the uart buffer. Thank you.
Now you've just changed "computer" to "WiFi module".
So the answer remains basically the same:
The first thing you need to determine is whether the problem lies with your WiFi module (in receiving the data), or with your nRF52 system (in sending the data).
What "UART buffer":
Or is the "computer" receiving the data via the "WiFi module" ?
