Eddystone & DFU Buttonless
Hi, I just started working with NRF52-DK and SDK 15.0.
I tried to test the ble_peripheral examples and they work properly.
Then I tried to add the buttonless dfu inside the Blinky example and this works too.
Now I would need to add the DFU buttonless service within the Eddystone application. The Secure DFU Service appears among those available but when I try to load a new code (a .zip file with the secure bootloader) I get an error ("Fatal error"). I believe it is a conflict or something similar but I can not solve it.
Can someone help me?
I have attached the main file, the configuration file (sdk_config.h), log by smartphone and the log that shows the moment when the error occurs
Thank you
sdk_config.h
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf5_sdk_for_eddystone main.c
 * @ingroup nrf5_sdk_for_eddystone
 * @brief Eddystone Beacon GATT Configuration Service + EID/eTLM sample application main file.
 * This file contains the source code for an Eddystone
 * Beacon GATT Configuration Service + EID/eTLM sample application.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "bsp.h"
#include "ble_conn_params.h"
#include "ble_advertising.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "es_app_config.h"
#include "app_scheduler.h"
#include "nrf_ble_es.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "es_adv.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "nrf_sdh_soc.h"
#include "fds.h"
#include "peer_manager.h"
#include "ble_dfu.h"
#include "ble_conn_state.h"
#include "nrf_ble_qwr.h"
//#include "SEGGER_RTT.h"
#include "nrf_log.h" //aggiunto da Simone
#include "nrf_log_ctrl.h" //aggiunto da Simone
#include "nrf_log_default_backends.h" //aggiunto da Simone
#define DEAD_BEEF                       0xDEADBEEF          //!< Value used as error code on stack dump, can be used to identify stack location on stack unwind.
#define NON_CONNECTABLE_ADV_LED_PIN     BSP_BOARD_LED_0     //!< Toggles when non-connectable advertisement is sent.
#define CONNECTED_LED_PIN               BSP_BOARD_LED_1     //!< Is on when device has connected.
#define CONNECTABLE_ADV_LED_PIN         BSP_BOARD_LED_2     //!< Is on when device is advertising connectable advertisements.
/**@brief   Priority of the application BLE event handler.
 * @note    You shouldn't need to modify this value.
#define APP_BLE_OBSERVER_PRIO 3
NRF_BLE_QWR_DEF(m_qwr);
NRF_BLE_GATT_DEF(m_gatt); //!< GATT module instance.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
    ret_code_t err_code;
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.common_evt.conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            err_code = sd_ble_gatts_sys_attr_set(p_ble_evt->evt.common_evt.conn_handle, NULL, 0, 0);
        case BLE_GAP_EVT_CONNECTED:
            bsp_board_led_on(CONNECTED_LED_PIN);
            bsp_board_led_off(CONNECTABLE_ADV_LED_PIN);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // No implementation needed.
*          the device. It also sets the permissions and appearance.
   uint8_t                 device_name[] = APP_DEVICE_NAME;
                                         device_name,
                                         strlen((const char *)device_name));
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    uint32_t ram_start = 0;
    err_code = nrf_sdh_ble_app_ram_start_get(&ram_start);
    // Overwrite some of the default configurations for the BLE stack.
    ble_cfg_t ble_cfg;
    // Configure the maximum number of connections.
    memset(&ble_cfg, 0, sizeof(ble_cfg));
    ble_cfg.gap_cfg.role_count_cfg.periph_role_count  = 1;
#if !defined (S112)
    ble_cfg.gap_cfg.role_count_cfg.central_role_count = 0;
    ble_cfg.gap_cfg.role_count_cfg.central_sec_count  = 0;
#endif // !defined (S112)
    err_code = sd_ble_cfg_set(BLE_GAP_CFG_ROLE_COUNT, &ble_cfg, ram_start);
    // Enable BLE stack.
    app_sched_execute();
    nrf_pwr_mgmt_run();
/**@brief Function for handling Eddystone events.
 * @param[in] evt Eddystone event to handle.
static void on_es_evt(nrf_ble_es_evt_t evt)
    switch (evt)
        case NRF_BLE_ES_EVT_ADVERTISEMENT_SENT:
            NRF_LOG_INFO("ADVERTISEMENT_SENT.");
            bsp_board_led_invert(NON_CONNECTABLE_ADV_LED_PIN);
        case NRF_BLE_ES_EVT_CONNECTABLE_ADV_STARTED:
            NRF_LOG_INFO("CONNECTABLE_ADV_STARTED.");
            bsp_board_led_on(CONNECTABLE_ADV_LED_PIN);
        case NRF_BLE_ES_EVT_CONNECTABLE_ADV_STOPPED:
            NRF_LOG_INFO("CONNECTABLE_ADV_STOPPED");
/**@brief Function for handling button events from app_button IRQ
 * @param[in] pin_no        Pin of the button for which an event has occured
 * @param[in] button_action Press or Release
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
    if (button_action == APP_BUTTON_PUSH && pin_no == BUTTON_1)
        nrf_ble_es_on_start_connectable_advertising();
 * @brief Function for initializing the registation button
 * @retval Values returned by @ref app_button_init
 * @retval Values returned by @ref app_button_enable
static void button_init(void)
    const uint8_t           buttons_cnt  = 1;
    static app_button_cfg_t buttons_cfgs =
        .pin_no         = BUTTON_REGISTRATION,
        .active_state   = APP_BUTTON_ACTIVE_LOW,
        .pull_cfg       = NRF_GPIO_PIN_PULLUP,
        .button_handler = button_evt_handler
    err_code = app_button_init(&buttons_cfgs, buttons_cnt, APP_TIMER_TICKS(100));
    err_code = app_button_enable();
static void timers_init(void)
static void leds_init(void)
    ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
static void log_init(void)
    APP_ERROR_HANDLER(nrf_error);
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
 * @param[in]   event   Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
        case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
            NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
            // YOUR_JOB: Disconnect all bonded devices that currently are connected.
            //           This is required to receive a service changed indication
            //           on bootup after a successful (or aborted) Device Firmware Update.
        case BLE_DFU_EVT_BOOTLOADER_ENTER:
            // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
            // by delaying reset by reporting false in app_shutdown_handler
            NRF_LOG_INFO("Device will enter bootloader mode.");
        case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
            NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
            // YOUR_JOB: Take corrective measures to resolve the issue
            //           like calling APP_ERROR_CHECK to reset the device.
        case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
            NRF_LOG_ERROR("Request to send a response to client failed.");
            APP_ERROR_CHECK(false);
            NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
    //ble_lbs_init_t     init     = {0};
    ble_dfu_buttonless_init_t dfus_init = {0};
    // Initialize LBS.
    //init.led_write_handler = led_write_handler;
    //err_code = ble_lbs_init(&m_lbs, &init);
    //APP_ERROR_CHECK(err_code);
    // Initialize the async SVCI interface to bootloader.
    err_code = ble_dfu_buttonless_async_svci_init();
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
 * @brief Function for application main entry.
    // Initialize.
    log_init();//aggiunto da Simone per log sulla Uart
    timers_init();
    leds_init();
    button_init();
    scheduler_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();//aggiunto da simone per buttonless dfu
    conn_params_init();
    nrf_ble_es_init(on_es_evt);
    NRF_LOG_INFO("Eddystone Simone example started: %i",1);
    //printf("ssss");
    // Enter main loop.
    for (;;)
        idle_state_handle();
<info> app: Setting vector table to bootloader: 0x00078000
<info> app: Setting vector table to main app: 0x00026000
<info> app: Eddystone Simone example started: 1
<info> app: ADVERTISEMENT_SENT.
<info> app: CONNECTABLE_ADV_STARTED.
<info> app: BLE_GAP_EVT_CONNECTED
<info> app: BLE_GATTS_EVT_WRITE
<info> app: on_write
<info> app: BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
<info> app: ADVERTISEMENT<info> app: BLE_GATTS_EVT_WRITE
<info> app: Received indication state 1
<error> app: Fatal error
<warning> app: System reset
nRF Connect, 2018-06-28
nRF5x_Eddys (D1:29:6A:15:9B:CB)
V	16:18:53.408	Connecting to D1:29:6A:15:9B:CB...
D	16:18:53.408	gatt = device.connectGatt(autoConnect = false)
D	16:18:54.374	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	16:18:54.374	Connected to D1:29:6A:15:9B:CB
D	16:18:54.388	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
V	16:18:54.390	Discovering services...
D	16:18:54.390	gatt.discoverServices()
D	16:18:57.416	[Callback] Services discovered with status: 0
I	16:18:57.416	Services discovered
V	16:18:57.461	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
Secure DFU Service (0xFE59)
- Buttonless DFU [I W] (8ec90003-f315-4f60-9fb8-838830daea50)
Eddystone Configuration Service (a3c87500-8ed3-4bdf-8a39-a01bebede295)
- Capabilities [R] (a3c87501-8ed3-4bdf-8a39-a01bebede295)
- Active Slot [R W] (a3c87502-8ed3-4bdf-8a39-a01bebede295)
- Advertising Interval [R W] (a3c87503-8ed3-4bdf-8a39-a01bebede295)
- Radio Tx Power [R W] (a3c87504-8ed3-4bdf-8a39-a01bebede295)
- (Advanced) Advertised Tx Power [R W] (a3c87505-8ed3-4bdf-8a39-a01bebede295)
- Lock State [R W] (a3c87506-8ed3-4bdf-8a39-a01bebede295)
- Unlock [R W] (a3c87507-8ed3-4bdf-8a39-a01bebede295)
- Public ECDH Key [R] (a3c87508-8ed3-4bdf-8a39-a01bebede295)
- EID Identity Key [R] (a3c87509-8ed3-4bdf-8a39-a01bebede295)
- ADV Slot Data [R W] (a3c8750a-8ed3-4bdf-8a39-a01bebede295)
- (Advanced) Factory Reset [W] (a3c8750b-8ed3-4bdf-8a39-a01bebede295)
- (Advanced) Remain Connectable [R W] (a3c8750c-8ed3-4bdf-8a39-a01bebede295)
D	16:18:57.461	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D	16:18:57.467	gatt.setCharacteristicNotification(8ec90003-f315-4f60-9fb8-838830daea50, true)
V	16:19:01.022	Starting pairing...
D	16:19:01.022	device.createBond()
D	16:19:01.161	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	16:19:01.277	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_NONE (10)
I	16:19:01.277	Bonding failed
D	16:19:01.367	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	16:19:01.367	Disconnected
D	16:19:01.369	gatt.refresh() (hidden)
D	16:19:01.625	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
D	16:19:04.659	gatt.close()
D	16:19:04.661	wait(200)
V	16:19:04.870	Connecting to D1:29:6A:15:9B:CB...
D	16:19:04.870	gatt = device.connectGatt(autoConnect = false)
D	16:19:07.317	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	16:19:07.317	Connected to D1:29:6A:15:9B:CB
D	16:19:07.346	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
V	16:19:07.351	Discovering services...
D	16:19:07.351	gatt.discoverServices()
D	16:19:07.618	[Callback] Services discovered with status: 129
E	16:19:07.618	Error 129 (0x81): GATT INTERNAL ERROR
D	16:19:07.619	[Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
E	16:19:07.619	Error 133 (0x85): GATT ERROR
I	16:19:07.619	Disconnected
D	16:19:07.726	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
D	16:19:07.864	gatt.close()
D	16:19:07.865	wait(200)
V	16:19:08.066	Connecting to D1:29:6A:15:9B:CB...
D	16:19:08.066	gatt = device.connectGatt(autoConnect = false)
I	16:19:08.069	Disconnected
D	16:19:08.537	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	16:19:08.537	Connected to D1:29:6A:15:9B:CB
D	16:19:08.559	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
V	16:19:08.560	Discovering services...
D	16:19:08.560	gatt.discoverServices()
D	16:19:11.618	[Callback] Services discovered with status: 0
I	16:19:11.618	Services discovered
V	16:19:11.673	Generic Access (0x1800)
D	16:19:11.674	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D	16:19:11.675	gatt.setCharacteristicNotification(8ec90003-f315-4f60-9fb8-838830daea50, true)
A	16:19:23.292	Checking Lock state...
V	16:19:23.292	Reading characteristic a3c87506-8ed3-4bdf-8a39-a01bebede295
D	16:19:23.292	gatt.readCharacteristic(a3c87506-8ed3-4bdf-8a39-a01bebede295)
I	16:19:23.410	Read Response received from a3c87506-8ed3-4bdf-8a39-a01bebede295, value: (0x) 00
A	16:19:23.410	"Locked" received
A	16:19:23.410	Service is locked. Unlocking...
V	16:19:23.410	Reading characteristic a3c87507-8ed3-4bdf-8a39-a01bebede295
D	16:19:23.410	gatt.readCharacteristic(a3c87507-8ed3-4bdf-8a39-a01bebede295)
I	16:19:23.590	Read Response received from a3c87507-8ed3-4bdf-8a39-a01bebede295, value: (0x) 0D-A1-F1-61-69-3F-76-DA-CA-AC-EB-0B-48-7D-83-9F
A	16:19:23.590	"(0x) 0D-A1-F1-61-69-3F-76-DA-CA-AC-EB-0B-48-7D-83-9F" received
V	16:19:23.590	Writing request to characteristic a3c87507-8ed3-4bdf-8a39-a01bebede295
D	16:19:23.590	gatt.writeCharacteristic(a3c87507-8ed3-4bdf-8a39-a01bebede295, value=0x543090622C08C11E86F0C59CD06A322D)
I	16:19:23.770	Data written to a3c87507-8ed3-4bdf-8a39-a01bebede295, value: (0x) 54-30-90-62-2C-08-C1-1E-86-F0-C5-9C-D0-6A-32-2D
A	16:19:23.770	"(0x) 54-30-90-62-2C-08-C1-1E-86-F0-C5-9C-D0-6A-32-2D" sent
V	16:19:23.770	Reading characteristic a3c87506-8ed3-4bdf-8a39-a01bebede295
D	16:19:23.770	gatt.readCharacteristic(a3c87506-8ed3-4bdf-8a39-a01bebede295)
A	16:19:23.950	Eddystone Configuration Service unlocked
A	16:19:23.950	Reading active slot number...
I	16:19:23.950	Read Response received from a3c87506-8ed3-4bdf-8a39-a01bebede295, value: (0x) 01
V	16:19:23.950	Reading characteristic a3c87502-8ed3-4bdf-8a39-a01bebede295
A	16:19:23.950	"Unlocked" received
D	16:19:23.950	gatt.readCharacteristic(a3c87502-8ed3-4bdf-8a39-a01bebede295)
I	16:19:24.220	Read Response received from a3c87502-8ed3-4bdf-8a39-a01bebede295, value: (0x) 00
A	16:19:24.220	"0" received
A	16:19:24.220	Reading slot 0 advertising data...
V	16:19:24.220	Reading characteristic a3c8750a-8ed3-4bdf-8a39-a01bebede295
D	16:19:24.220	gatt.readCharacteristic(a3c8750a-8ed3-4bdf-8a39-a01bebede295)
W	16:19:24.400	Slot is not configured as EID
I	16:19:24.400	Read Response received from a3c8750a-8ed3-4bdf-8a39-a01bebede295, value: (0x) 10-00-01-6E-6F-72-64-69-63-73-65-6D-69-00
A	16:19:24.400	"Frame type: URL <0x10>
Tx power at 0m: 0 dBm
URL: https://www.nordicsemi.com/" received
V	16:19:27.155	Reading characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:27.155	gatt.readCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295)
I	16:19:27.280	Read Response received from a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 01
A	16:19:27.280	"(0x) 01" received
V	16:19:33.868	Writing request to characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:33.869	gatt.writeCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295, value=0x00)
I	16:19:34.030	Data written to a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 00
A	16:19:34.030	"(0x) 00" sent
V	16:19:35.643	Reading characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:35.643	gatt.readCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295)
I	16:19:35.740	Read Response received from a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 01
A	16:19:35.740	"(0x) 01" received
V	16:19:36.772	Reading characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:36.772	gatt.readCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295)
I	16:19:36.910	Read Response received from a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 01
A	16:19:36.910	"(0x) 01" received
V	16:19:42.784	Changing write type for a3c8750c-8ed3-4bdf-8a39-a01bebede295 to WRITE COMMAND
D	16:19:42.784	characteristic.setWriteType(WRITE COMMAND)
V	16:19:42.790	Writing command to characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:42.790	gatt.writeCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295, value=0x00)
I	16:19:42.793	Data written to a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 00
A	16:19:42.793	"(0x) 00" sent
V	16:19:47.818	Reading characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:47.818	gatt.readCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295)
I	16:19:47.980	Read Response received from a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 01
A	16:19:47.980	"(0x) 01" received
V	16:19:56.052	Writing command to characteristic a3c8750c-8ed3-4bdf-8a39-a01bebede295
D	16:19:56.052	gatt.writeCharacteristic(a3c8750c-8ed3-4bdf-8a39-a01bebede295, value=0x00)
I	16:19:56.054	Data written to a3c8750c-8ed3-4bdf-8a39-a01bebede295, value: (0x) 00
A	16:19:56.054	"(0x) 00" sent
V	16:21:01.268	[DFU] DFU service started
V	16:21:01.268	[DFU] Opening file...
I	16:21:02.144	[DFU] Firmware file opened successfully
V	16:21:02.144	[DFU] Connecting to DFU target...
D	16:21:02.144	[DFU] gatt = device.connectGatt(autoConnect = false)
I	16:21:02.160	[DFU] Connected to D1:29:6A:15:9B:CB
V	16:21:02.160	[DFU] Discovering services...
D	16:21:02.160	[DFU] gatt.discoverServices()
I	16:21:02.176	[DFU] Services discovered
D	16:21:02.210	[DFU] wait(1000)
W	16:21:03.208	[DFU] Application with buttonless update found
V	16:21:03.209	[DFU] Jumping to the DFU Bootloader...
V	16:21:03.209	[DFU] Enabling indications for 8ec90003-f315-4f60-9fb8-838830daea50
D	16:21:03.209	[DFU] gatt.setCharacteristicNotification(8ec90003-f315-4f60-9fb8-838830daea50, true)
D	16:21:03.221	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	16:21:03.321	[DFU] Data written to descr.8ec90003-f315-4f60-9fb8-838830daea50, value (0x): 02-00
V	16:21:03.321	[DFU] Notifications enabled for 8ec90003-f315-4f60-9fb8-838830daea50
A	16:21:03.321	[DFU] Indications enabled
D	16:21:03.321	[DFU] wait(1000)
V	16:21:04.381	[DFU] Writing to characteristic 8ec90003-f315-4f60-9fb8-838830daea50
D	16:21:04.381	[DFU] gatt.writeCharacteristic(8ec90003-f315-4f60-9fb8-838830daea50)
D	16:21:08.403	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	16:21:08.403	Disconnected
D	16:21:08.407	gatt.refresh() (hidden)
A	16:21:08.420	[DFU] Enter bootloader sent (Op Code = 1)
I	16:21:08.481	[DFU] Disconnected by the remote device
D	16:21:08.481	[DFU] gatt.refresh() (hidden)
D	16:21:08.481	[DFU] gatt.close()
V	16:21:08.481	[DFU] Scanning for the DFU Bootloader...
D	16:21:08.513	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
D	16:21:08.516	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
I	16:21:08.800	[DFU] DFU Bootloader found with address D1:29:6A:15:9B:CB
V	16:21:08.816	[DFU] DFU service started
I	16:21:08.816	[DFU] Firmware file opened successfully
D	16:21:08.816	[DFU] wait(1000)
D	16:21:09.821	[DFU] wait(1000)
V	16:21:10.867	[DFU] Connecting to DFU target...
D	16:21:10.868	[DFU] gatt = device.connectGatt(autoConnect = false)
E	16:21:15.912	[DFU] Connection failed (0x85): GATT ERROR
W	16:21:15.912	[DFU] Retrying...
V	16:21:15.912	[DFU] Disconnecting...
D	16:21:15.994	[DFU] gatt.disconnect()
I	16:21:15.994	[DFU] Disconnected
D	16:21:15.994	[DFU] gatt.refresh() (hidden)
D	16:21:15.994	[DFU] gatt.close()
V	16:21:16.026	[DFU] DFU service started
I	16:21:16.026	[DFU] Firmware file opened successfully
D	16:21:16.026	[DFU] wait(1000)
D	16:21:17.041	[DFU] wait(1000)
V	16:21:18.028	[DFU] Connecting to DFU target...
D	16:21:18.126	[DFU] gatt = device.connectGatt(autoConnect = false)
E	16:21:23.135	[DFU] Connection failed (0x85): GATT ERROR
V	16:21:23.135	[DFU] Disconnecting...
D	16:21:23.202	[DFU] gatt.disconnect()
I	16:21:23.203	[DFU] Disconnected
D	16:21:23.204	[DFU] gatt.refresh() (hidden)
D	16:21:23.206	[DFU] gatt.close()
D	16:21:23.213	[DFU] wait(600)
D	16:21:23.822	gatt.close()
D	16:21:23.825	wait(200)
V	16:21:24.027	Connecting to D1:29:6A:15:9B:CB...
D	16:21:24.027	gatt = device.connectGatt(autoConnect = false)
D	16:21:29.042	[Callback] Connection state changed with status: 133 and new state: CONNECTED (2)
E	16:21:29.042	Error 133 (0x85): GATT ERROR
V	16:21:58.413	Cancelling connection...
D	16:21:58.413	gatt.disconnect()
I	16:21:58.414	Disconnected
D	16:21:58.414	gatt.close()
D	16:21:58.416	wait(200)
