best practice - delay between setting pin as input with pull up/pull down and reading the pin
We are seeing a potential issue with a product. on start up a pin is read and the read value determines if we go in to a test mode. Pretty standard.
Our failure is during normal operation when there is nothing connected to this pin and the firmware is reading a low instead of a high. (On test a test fixture will take the pin to ground)
  1. During normal operation there will be nothing connected to the pin so it is init ally floating floating.
  2. When the firmware starts we set the pin to input and immediately read the value of the pin on the next line
nrf_gpio_cfg_input(TEST_PIN, NRF_GPIO_PIN_PULLUP);
if (!nrf_gpio_pin_read(TEST_PIN))
	runTestMode();
So the question is should I put a delay in between setting the pin as an input with a pull up and reading the pin?
Is it good practice to put a delay in?
(i could of course add an external pull up)
Essentially I will need to look:
  1. The time between the pull up being connected internally to the pin, to when the pin state is read.
  2. the capacitance of the line and the time it takes for the line to go "high" once the pull up has been connected.
27/7/2018: extra info/questions
Extra marks for considering issues on power up. I.e. assume this code is one of the first things to run.
Nrf51. Pull up values in section 8.23 of the datasheet.
Additional Information:
Please read this post here: https://devzone.nordicsemi.com/f/nordic-q-a/25873/internal-pull-up-resistance-on-gpio-of-nrf51822
It has a interesting reply on the pull up value with respect the supply voltage on power up. This might depend on how you have the brownout settings configured and when the code is triggered as the voltage rises on power up. equally we may never see this if the code never gets run on supply voltages <1.8V
  • I didn't reply  because I had nothing more to add. I agree with the last post from the OP that you need to consider the rise time on the line, that's the only thing you need to consider however.
    There is no need for an extra 'wait' condition with the nRF51. The pullup is activated on the edge of the clock cycle on which you write, if you do a read on the next cycle it's sampled just around the next edge, there is no extra clock cycle latch in there you need to compensate for. You have most of one full 16MHz cycle for the signal to rise.Unless you have a slow rise/lots of capacitance you have enough setup time.
    On the nRF52 you only need to ensure that the write to the status register has been committed and the pullup enabled before you read the value. As register writes are cached that just requires reading back the status register after you write it because the read will stall until the status write commits. Reading the value is another APB cycle later and so you're back where you were with the nRF51, nothing extra required.
    So with nRF51, write status then read value on the next cycle is fine and with nRF52 write status, read status then read value is enough.
    All that is contingent on having reasonable rise times on the signal itself, you need to calculate it, but at 16MHz it would not usually be an issue.
  • All good info.
    Can you provide a link to the register spec that states it sets and latches state on the same clock?
    I couldn't find anything in the Nordic docs and was loathe to start combing through generic ARM documentation. The information could prove useful for later questions.
