We are seeing a potential issue with a product. on start up a pin is read and the read value determines if we go in to a test mode. Pretty standard.
Our failure is during normal operation when there is nothing connected to this pin and the firmware is reading a low instead of a high. (On test a test fixture will take the pin to ground)
- During normal operation there will be nothing connected to the pin so it is init ally floating floating.
- When the firmware starts we set the pin to input and immediately read the value of the pin on the next line
nrf_gpio_cfg_input(TEST_PIN, NRF_GPIO_PIN_PULLUP);
if (!nrf_gpio_pin_read(TEST_PIN))
runTestMode();
So the question is should I put a delay in between setting the pin as an input with a pull up and reading the pin?
Is it good practice to put a delay in?
(i could of course add an external pull up)
Essentially I will need to look:
- The time between the pull up being connected internally to the pin, to when the pin state is read.
- the capacitance of the line and the time it takes for the line to go "high" once the pull up has been connected.
27/7/2018: extra info/questions
Extra marks for considering issues on power up. I.e. assume this code is one of the first things to run.
Nrf51. Pull up values in section 8.23 of the datasheet.
Additional Information:
Please read this post here: https://devzone.nordicsemi.com/f/nordic-q-a/25873/internal-pull-up-resistance-on-gpio-of-nrf51822
It has a interesting reply on the pull up value with respect the supply voltage on power up. This might depend on how you have the brownout settings configured and when the code is triggered as the voltage rises on power up. equally we may never see this if the code never gets run on supply voltages <1.8V
