I have some troubles using TWI easy DMA. I set EASY_DMA flag to 1, but I can't see any results in my performance tests. Can anyone explain me the required steps?
Thanks!
Thanks!
Hi Roei,
I would like you to take a look at the TWI master documentation and then go through this thread and the links posted on how to use TWI eDMA.
Hi Martin, thanks for the response!
I went through your links, and I still have the same questions:
I'm using SDK15.00, with nrfx_twim interface. Do I need to do anything else besides changing EASY_DMA flag to 1, in order to use easy DMA?
Thanks!
Hi Roei,
If you look at the TWI sensor example you can see that the:
// <q> TWI0_USE_EASY_DMA - Use EasyDMA (if present) #ifndef TWI0_USE_EASY_DMA #define TWI0_USE_EASY_DMA 1 #endif
is set. Please use that example as reference on how you can use eDMA with TWI.
Hi Martin,
Thank you! I tried to work by the example, but I didn't see any performance changes. Do I have a way to see if Easy DMA is now activated?
Thanks!
