Problem with nrf51-ble-app-temp
Goodmorning
I have few problem with this project. I took the source file from github.com/.../nrf51-ble-app-temp and I modified the main.c to use with S110 6.0.0, nRF51 SDK version 6.0.0 and nRF51822 Evaluation Kit (PCA10001) version 2.2.0. For temperature with the function sd_temp_get(&temp), I have an error code = 15 (forbidden operation-> Tried to write to or read from protected location). Furthermore, after I have put errorcode = 0, in the place of sd_temp_get(&temp) function and temp = 0, the PCA10001 seems to work, but I can not connect the EK to nRF Temp 2.0 app on my smart phone. So, there is something that I don't understand. Can you help me, please?
I remember you that I use Keil uVision 5.0 for compiling the project. Is there any setup to do in this development tool?
Thanks
P.A.
  • The 6.0.0 version of the S110 stack is compatible with version 5.2.0 of the SDK. Version 6.0.0 of the SDK is compatible with version 7.0.0 of the stack. I recommend you either upgrade your stack or downgrade your SDK.
  • Thank you for your answer. I upgrade to S110 del. 7.0.0 stack, and 6.0.0 SDK but now I have an error code 0x3001 in sd_ble_gap_device_name_set function. What happens?
  • I have not performed the upgrade to S110 7.0.0 and SDK 6.0.0 but I was able to poke around in the SDK code base. It appears that a 0x3001 error is BLE_ERROR_NOT_ENABLED. Although the comment where sd_ble_gap_device_name_set is defined does not list that as one of the possible return codes. You probably want to look at this question and answer: devzone.nordicsemi.com/.../
  • Hi John your suggestion was very helpful. With SDK 7.0.0 is necessary enable BLE with sd_ble_enable in ble_stack_init() function. I put below the code snippet:
    // Enable BLE stack
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    where IS_SRVC_CHANGED_CHARACT_PRESENT is defined in main.c like:
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0
    Now the EK device works fine with app nRF temp 2.0. on my smart phone
    Thank you very much
  • hi What do I do to make it work with SDK 6.1 and 7.1 soft device? Thank you for your attention Best regards
