timer seems to stop
The hardware is a custom board with a Rigado BMD300 module (which uses the nRF52832).  I am using Softdevice S132.
My code base started as the ble_app_uart peripheral example.  To this I am trying to add SPI code to communicate with multiple SPI-to-UART bridges on SPI0 and SPI1 although I do not believe the problem is with the SPI code.
After sending a message to a SPI slave my code calls a delay_ms() routine and waits for the SPI to finish.
      // Set LCR to 0x80
      tx_buf[0] = SC16IS7X0_WRITE | (SC16IS7X0_LCR << SC16IS7X0_ADDR_SHIFT);	// R/W and address
      tx_buf[1] = 0x80;			// value
      *busy_flag = SPI_TX_IN_PROGRESS;
      nrf_drv_spi_transfer( spi_instance, tx_buf, 2, NULL, 0 );
      while( *busy_flag != SPI_AVAILABLE )
	 delay_ms( 2 );
void delay_ms( uint32_t count)
   uint32_t			end;
   if( timestamp != 0 )
      end = count + timestamp;
      while( timestamp < end )
	   //NRF_LOG_PROCESS();	// may as well do something useful
	 asm("nop");
   return;
}  // end of delay()
The timestamp variable is updated in my timer callback.  I put a debug statement to toggle an LED n the callback and verified it was both running and running at the expected rate (1 ms).
The busy_flag is updated in the SPI event handler.
The code often gets stuck waiting to the delay_ms() to complete.  The only way I can see that happening is for the app_timer() library to stop running under some circumstance.
When I put a breakpoint (I am using IAR's EWARM and a Segger JLINK) in the timestamp timer's handler routine after a few seconds of the application hanging, the call stack looks like the following:
Stepping through the code (and checking the disassembly) shows the expected result: the global timestamp variable is incremented by one.
I would guess that the timer stopped running except that the breakpoint in the timer service routine was encountered and stopped the debugger.
I realize there is an overflow possibility if the timestamp is close to max but since it starts at zero there shouldn't be a problem.
Any suggestions on what to look at or how to debug this?  Using the debugger breaks the code - I eventually hit a NRF_BREAKPOINT_COND in the app_error_fault_handler().  I am using the Segger RTT Viewer to see printf()'s sprinkled through the code but I'm not getting anywhere fast.
    Can you share more of your code? Is the timestamp variable volatile?
  • The timestamp variable is global.  Making it volatile did not change the assembly code that was generated.
    I think these are the relevant files.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    //#include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "gpio.h"
    //#include "nrf_sdm.h"
    #include "SEGGER_rtt.h"
    #include "spi.h"
    #include "m2k_dsh.h"
    #include "bsp_2000M.h"
    #define MAIN_ALLOC_STORAGE
    #include "main.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "FNIR 2000M"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    APP_TIMER_DEF(m_battery_timer_id);
    APP_TIMER_DEF(m_timestamp_id);
    APP_TIMER_DEF(m_scantimer_id);
    #define TIMESTAMP_INTERVAL		APP_TIMER_TICKS(1)	// 1 ms timer
    #define SCANTIMER_INTERVAL		APP_TIMER_TICKS(100)	// 100 ms timer
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    void battery_level_update( void )
    //    ret_code_t err_code;
    //    uint8_t  battery_level;
    //    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    //    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    //    if ((err_code != NRF_SUCCESS) &&
    //        (err_code != NRF_ERROR_INVALID_STATE) &&
    //        (err_code != NRF_ERROR_RESOURCES) &&
    //        (err_code != NRF_ERROR_BUSY) &&
    //        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
    //        APP_ERROR_HANDLER(err_code);
        return;
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
     *                          app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        battery_level_update();
    void timestamp_timer_handler( void * p_context )
       timestamp++;
       return;
    } // end of timestamp_timer_handler()
    void scantimer_handler( void * p_context )
       static int		led_on = 0;
       // Blink LED
       if( led_on )
          set_activity_led( LED_BLUE_PIN, 0 );
          led_on = 0;
          set_activity_led( LED_BLUE_PIN, 1 );
          led_on = 1;
       // Start a scan
       return;
    } // end of scantimer_handler()
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        err_code = app_timer_init();
        err_code = app_timer_create( &m_battery_timer_id,
                                     APP_TIMER_MODE_REPEATED,
                                     battery_level_meas_timeout_handler);
        err_code = app_timer_create( &m_timestamp_id,
                                     timestamp_timer_handler);
        err_code = app_timer_start( m_timestamp_id,
    			        TIMESTAMP_INTERVAL,
    				NULL);
        err_code = app_timer_create( &m_scantimer_id,
                                     scantimer_handler);
        err_code = app_timer_start( m_scantimer_id,
    			        SCANTIMER_INTERVAL,
    				NULL);
        return;
    } // end of timers_init()
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    //        uint32_t err_code;
            NRF_LOG_INFO("Received data from BLE NUS. Not writing data on UART.");
            NRF_LOG_HEXDUMP_INFO(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
    	spi_send( SPI_LEFT,
    		  (uint8_t *) p_evt->params.rx_data.p_data,
    		  p_evt->params.rx_data.length );
    //        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
    //            do
    //                //err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
    //	        err_code = NRF_SUCCESS;
    //                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
    //                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
    //                    APP_ERROR_CHECK(err_code);
    //            } while (err_code == NRF_ERROR_BUSY);
    //        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    //            //while (app_uart_put('\n') == NRF_ERROR_BUSY);
           NRF_LOG_INFO( "Received unhandled event type %d", p_evt->type );
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    	    NRF_LOG_INFO( "Hit the default case at line %d in %s\r\n",
    			  __LINE__, __FILE__ );
    	    NRF_LOG_INFO( "evt_id = %d (0x%x)",
    			  p_ble_evt->header.evt_id,
    			  p_ble_evt->header.evt_id );
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_INFO( "ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t 		startup_event;
        uint32_t 			err_code;
    static void log_init(void)
    #define DEVELOP_MSG		200
    /**@brief Application main function.
        bool 			erase_bonds;
        long			loop;
        uint8_t			msg[ DEVELOP_MSG ];
        ctlr_zero_len_msg_t		status_req_msg;
        status_msg_t		status_resp_msg;
        // Initialize.
        timestamp = 0;
        log_init();
        timers_init();
        gpio_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        NRF_LOG_INFO("Line %d, After conn_params_init()", __LINE__ );
        gpio_init();
        spi_init();
        NRF_LOG_INFO("Line %d, After spi_init()", __LINE__ );
        BSP_PowerSensorHeadOff( SENSOR_HEAD_1A_INDEX );
        BSP_PowerSensorHeadOff( SENSOR_HEAD_2A_INDEX );
        // nrf_delay_ms( 200 );
        BSP_PowerSensorHeadNormal( SENSOR_HEAD_1A_INDEX );
        //BSP_PowerSensorHeadNormal( SENSOR_HEAD_2A_INDEX );
        status_req_msg.startByte 	= FNIR_CTLR_MSG_START_BYTE;
        status_req_msg.cmd  	= CS_STATUS_REQ_MSG_ID;
        status_req_msg.stopByte  	= FNIR_CTLR_MSG_STOP_BYTE;
        status_req_msg.len 		= FNIR_CTLR_ZERO_LEN_MSG_SIZE;
        status_req_msg.crc 		= status_req_msg.cmd;
        spi_send( SPI_LEFT,
    	      (uint8_t *) &status_req_msg,
    	      FNIR_CTLR_ZERO_LEN_MSG_SIZE );
        NRF_LOG_INFO( "Sent status request msg to DSH" );
        loop = 0;
        // Enter main loop.
        for (;;)
           if( SPI_left_port_busy != SPI_AVAILABLE )
    	  NRF_LOG_INFO("spi_send() not yet complete");
           delay_ms(2000);
           snprintf( (char *)msg, DEVELOP_MSG, "Loop = %d", loop++ );
           NRF_LOG_INFO("%s", msg );
           do
             NRF_LOG_PROCESS();
           } while( NRF_LOG_PROCESS() );
    } // end of main()
    //wtf
    void nrfx_power_irq_handler(void)
      return;
    void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
       __disable_irq();
       NRF_LOG_FINAL_FLUSH();
       NRF_LOG_ERROR("Fatal error at line %d in %s", __LINE__, __FILE__);
       switch (id)
       case NRF_FAULT_ID_SDK_ASSERT:
    	 assert_info_t * p_info = (assert_info_t *)info;
    	 NRF_LOG_ERROR("ASSERTION FAILED at %s:%u",
    		       p_info->p_file_name,
    		       p_info->line_num);
       case NRF_FAULT_ID_SDK_ERROR:
    	 error_info_t * p_info = (error_info_t *)info;
    	 NRF_LOG_ERROR("ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x",
    		       p_info->err_code,
    		       nrf_strerror_get(p_info->err_code),
    		       p_info->line_num,
    		       pc);
    	 NRF_LOG_ERROR("End of error report");
          NRF_LOG_ERROR("UNKNOWN FAULT at 0x%08X", pc);
       NRF_BREAKPOINT_COND;
       // On assert, the system can only recover with a reset.
    #ifndef DEBUG
       NRF_LOG_WARNING("System reset");
       NVIC_SystemReset();
    #else
       app_error_save_and_stop(id, pc, info);
    #endif // DEBUG
       return;
       uint32_t			end;
    	 asm("nop");
       return;
    }  // end of delay_ms()
    #define  SPI_ALLOC_STORAGE
    #include "spi.h"
    #include "gpio.h"
    #include "nrf_gpiote.h"
    #include "main.h"
    #include "sc16is7x0.h"
    static const nrf_drv_spi_t		SPI_left = NRF_DRV_SPI_INSTANCE(0);
    static const nrf_drv_spi_t		SPI_right = NRF_DRV_SPI_INSTANCE(1);
    static const nrf_drv_spi_t		SPI_flash = NRF_DRV_SPI_INSTANCE(2);
    // * @brief SPI user event handler.
     //* @param event
    void
       spi_event_handler(
          nrf_drv_spi_evt_t const * 	p_event,
           void *                    	p_context)
       //NRF_LOG_INFO("line %d in spi_event_handler()", __LINE__ );
       if( p_event->type == NRF_DRV_SPI_EVENT_DONE )
          // A SPI transfer finished but which one?
          if( p_context == (const nrf_drv_spi_t *)&SPI_left )
    	 // It was SPI_LEFT
    	 // Need to manage buffer
    	 if( SPI_left_port_busy == SPI_TX_IN_PROGRESS )
    	    // It was a transmit
    	    SPI_left_tx_buff[ SPI_left_tx_deq_index ].busy = SPI_AVAILABLE;
    	    SPI_left_tx_buff[ SPI_left_tx_deq_index ].bytes = 0;
    	    SPI_left_tx_deq_index++;
    	    if( SPI_left_tx_deq_index >= SPI_TX_BUFFERS )
    	       SPI_left_tx_deq_index = 0;
    	    // Check if there is anything else to be sent
    	    if( SPI_left_tx_buff[ SPI_left_tx_deq_index ].busy == SPI_TX_IN_PROGRESS )
    	       // Buffer waiting to be sent
    	       nrf_drv_spi_transfer( &SPI_left,
    				     SPI_left_tx_buff[ SPI_left_tx_deq_index ].data,	// tx ptr
    				     SPI_left_tx_buff[ SPI_left_tx_deq_index ].bytes,	// tx len
    				     NULL,		// rx ptr
    				     0 );		// rx len
    	       // Set hardware port to available
    	       SPI_left_port_busy = SPI_AVAILABLE;
    	 } // end of if( SPI_left_port_busy == SPI_TX_IN_PROGRESS )
    	 else if( SPI_left_port_busy == SPI_RX_IN_PROGRESS )
    	    // It was a receive
    	    SPI_left_rx_buff[ SPI_left_rx_deq_index ].busy = SPI_RX_DONE;
    	    SPI_left_rx_deq_index++;
    	    if( SPI_left_rx_deq_index >= SPI_RX_BUFFERS )
    	       SPI_left_rx_deq_index = 0;
    	    // Check if there is anything else to be received
    	    if( SPI_left_rx_buff[ SPI_left_rx_deq_index ].busy == SPI_RX_IN_PROGRESS )
    	       // Buffer waiting to be received
    				     NULL,
    				     0,
    				     SPI_left_rx_buff[ SPI_left_rx_deq_index ].data,	// rx ptr
    				     SPI_left_rx_buff[ SPI_left_rx_deq_index ].bytes);	// rx len
    	 } // end of if( SPI_left_port_busy == SPI_RX_IN_PROGRESS )
    	    // Got a SPI Event Done indication but don't know why
    	    NRF_LOG_DEBUG( "Bad state at line %d in %s",
    			   __LINE__,
    			   __FILE__ );
          else if( p_context == (const nrf_drv_spi_t *)&SPI_right )
    	 // It was SPI_LEFT
    				     NULL,		// rx ptr
    				     0 );		// rx len
    	    // It was a receive
    				     NULL,
    				     0,
    			   __LINE__,
    			   __FILE__ );
          } // end of if( p_context == (const nrf_drv_spi_t *)&SPI_right )
          else if( p_context == (const nrf_drv_spi_t *)&SPI_flash  )
    	 // It was SPI_FLASH
    	 SPI_flash_busy = SPI_AVAILABLE;
    	 // It is a mystery
    	 NRF_LOG_INFO( "Unexpected event at line %d in %s", __LINE__, __FILE__ );
          NRF_LOG_INFO( "p_event->type = %d", p_event->type );
        return;
    }  // end of spi_event_handler()
    //**@brief  Function for initializing the SPI module.
    //**@snippet [SPI Initialization] */
    void
       spi_init(
          void )
       nrf_drv_spi_config_t 	config = NRF_DRV_SPI_DEFAULT_CONFIG;
       uint32_t			ret_code;
       uint8_t			loop;
       // Clear the message buffer areas
       SPI_left_rx_enq_index = 0;
       SPI_right_rx_enq_index = 0;
       SPI_left_tx_enq_index = 0;
       SPI_right_tx_enq_index = 0;
       SPI_flash_enq_index = 0;
       SPI_right_rx_deq_index = 0;
       SPI_right_tx_deq_index = 0;
       SPI_flash_deq_index = 0;
       for( loop = 0; loop < SPI_TX_BUFFERS; loop++ )
          SPI_left_tx_buff[loop].busy = SPI_AVAILABLE;
          SPI_left_tx_buff[loop].bytes = 0;
          memset( SPI_left_tx_buff[loop].data,
    	      0,
    	      SPI_TX_BUFFER_LEN );
          SPI_right_tx_buff[loop].busy = SPI_AVAILABLE;
          SPI_right_tx_buff[loop].bytes = 0;
          memset( SPI_right_tx_buff[loop].data,
    	      0,
       for( loop = 0; loop < SPI_RX_BUFFERS; loop++ )
          SPI_left_rx_buff[loop].busy = SPI_AVAILABLE;
          SPI_left_rx_buff[loop].bytes = 0;
          memset( SPI_left_rx_buff[loop].data,
    	      0,
    	      SPI_RX_BUFFER_LEN );
          SPI_right_rx_buff[loop].busy = SPI_AVAILABLE;
          SPI_right_rx_buff[loop].bytes = 0;
          memset( SPI_right_rx_buff[loop].data,
    	      0,
          SPI_flash_buff[loop].busy = SPI_AVAILABLE;
          SPI_flash_buff[loop].bytes = 0;
          memset( SPI_flash_buff[loop].data,
    	      0,
       // Configure SPI0 (Left Port) first
       config.sck_pin =  	SPIM0_SCK_PIN;
       config.mosi_pin = 	SPIM0_MOSI_PIN;
       config.miso_pin = 	SPIM0_MISO_PIN;
       config.ss_pin = 	SPIM0_SS_PIN;	// active low
       config.irq_priority = NRFX_SPI_DEFAULT_CONFIG_IRQ_PRIORITY;
       config.orc = 	0xFF;
    //   config.frequency = 	NRF_SPI_FREQ_4M;
    //   config.mode = 	NRF_SPI_MODE_0;
    //   config.bit_order = 	NRF_SPI_BIT_ORDER_MSB_FIRST;
       ret_code = nrf_drv_spi_init( &SPI_left,
    			        &config,
    			        spi_event_handler,
    				(void *) &SPI_left );	// context pointer
       if( ret_code != NRF_SUCCESS )
          // Handle the error
          NRF_LOG_INFO( "nrf_drv_spi_init() failure at line %d", __LINE__ );
          app_error_fault_handler( 0, 0, 0);
          // Configure the Left port spi-uart bridge
          NRF_LOG_INFO( "nrf_drv_spi_init() success at line %d", __LINE__ );
          spi_configure_chip( &SPI_left );
       // Configure SPI1 (Right Port) next
       config.sck_pin =  	SPIM1_SCK_PIN;
       config.mosi_pin = 	SPIM1_MOSI_PIN;
       config.miso_pin = 	SPIM1_MISO_PIN;
       config.ss_pin = 	SPIM1_SS_PIN;	// active low
       config.orc = 	0xFF;
       ret_code = nrf_drv_spi_init( &SPI_right,
    			       &config,
    			       spi_event_handler,
    			       (void *) &SPI_right );	// context pointer
          // Handle the error
          spi_configure_chip( &SPI_right );
       // Configure SPI2 (SPI Flash) next
       config.sck_pin =  	SPIM2_SCK_PIN;
       config.mosi_pin = 	SPIM2_MOSI_PIN;
       config.miso_pin = 	SPIM2_MISO_PIN;
       config.ss_pin = 	SPIM2_SS_PIN;	// active low
       config.orc = 	0xFF;
       ret_code = nrf_drv_spi_init( &SPI_flash,
    			       &config,
    			       spi_event_handler,
    			       (void *) &SPI_flash );
          // Handle the error
       return;
    }  // end of spi_init()
    void
       lp_irq_handler(
          nrf_drv_gpiote_pin_t 			pin,
          nrf_gpiote_polarity_t 			action)
       spi_interrupt_handler( pin, action );
       return;
    void
       rp_irq_handler(
       return;
    void
       if( action == NRF_GPIOTE_POLARITY_LOTOHI )
          NRF_LOG_INFO("pin = %d, action = LO to HI", pin );
       else if( action == NRF_GPIOTE_POLARITY_HITOLO )
          NRF_LOG_INFO("pin = %d, action = HI to LO", pin );
       else if( action == NRF_GPIOTE_POLARITY_TOGGLE )
          NRF_LOG_INFO("pin = %d, action = Toggle", pin );
          NRF_LOG_INFO("pin = %d, action = unknown", pin );
       return;
    void
       spi_bootloader_enable(
          sensor_head_id_t 			sensorHeadId )
       const nrf_drv_spi_t		*spi_instance;
       uint8_t			tx_buf[ 10 ];
       SPI_STATUS_E			*busy_flag;
       if( sensorHeadId == SENSOR_HEAD_1A_INDEX )
          spi_instance = &SPI_left;
          busy_flag = &SPI_left_port_busy;
       else if( sensorHeadId == SENSOR_HEAD_1B_INDEX )
          spi_instance = &SPI_right;
          busy_flag = &SPI_right_port_busy;
          spi_instance = NULL;
       if( spi_instance != NULL )
          // Set MCR to 0x00 to set RTS output hi (BOOT0=1, boot into bootloader)
          tx_buf[0] = 0x00 | (SC16IS7X0_MCR << SC16IS7X0_ADDR_SHIFT) ;	// R/W and address
          tx_buf[1] = 0x00;			// value
          APP_ERROR_CHECK(nrf_drv_spi_transfer( spi_instance,
                                tx_buf,
                                2,
                                NULL,
                                0 ) );
             delay_ms( 2 );
       return;
    } // end of spi_bootloader_enable()
    void
       spi_bootloader_disable(
          // Set MCR to 0x02 to set RTS output low (BOOT0=0, boot Flash)
          tx_buf[0] = 0x00 | (SC16IS7X0_MCR << SC16IS7X0_ADDR_SHIFT);	// R/W and address
          tx_buf[1] = 0x02;			// value
                                tx_buf,
                                2,
                                NULL,
                                0 );
             delay_ms( 2 );
       return;
    }  // end of spi_bootloader_disable()
    // spi_configure_chip()
    // Configure baud rate generator to 16x480kbps based on 7.680MHz clock
    // which requires a divide by 1.
    // Enable RX FIFO
    // Set RX FIFO interrupt level to 8 characters
    // Enable RX timeout (4 character times since last received character)
    void
       spi_configure_chip(
          const nrf_drv_spi_t		*spi_instance )
       sensor_head_id_t		sensorHeadId;
          if( spi_instance == &SPI_left )
             sensorHeadId = SENSOR_HEAD_1A_INDEX;
             sensorHeadId = SENSOR_HEAD_1B_INDEX;
          // Set LCR to 0x80
    			    tx_buf,
    			    2,
    			    NULL,
    			    0 );
    	 delay_ms( 2 );
          // Set DLL to 1
          tx_buf[0] = SC16IS7X0_WRITE | (SC16IS7X0_DLL << SC16IS7X0_ADDR_SHIFT);	// R/W and address
          tx_buf[1] = 0x1;			// value
    			    tx_buf,
    			    2,
    			    NULL,
    			    0 );
    	 delay_ms( 2 );
          // Set DHL to 0
          tx_buf[0] = SC16IS7X0_WRITE | (SC16IS7X0_DLH << SC16IS7X0_ADDR_SHIFT);	// R/W and address
          tx_buf[1] = 0x0;			// value
    			    tx_buf,
    			    2,
    			    NULL,
    			    0 );
    	 delay_ms( 2 );
          // Set LCR to 0x03
          tx_buf[0] = SC16IS7X0_WRITE | ( SC16IS7X0_LCR << SC16IS7X0_ADDR_SHIFT);	// R/W and address
          tx_buf[1] = 0x03;			// value
    			    tx_buf,
    			    2,
    			    NULL,
    			    0 );
    	 delay_ms( 2 );
          // Set MCR to 0x02 - Set RTS to low
          spi_bootloader_disable( sensorHeadId );
          // Setup FIFO
          //	- Set 0x01 to enable FIFOs
          //	- Set 0x02 to reset RX FIFO
          //	- Set 0x04 to reset TX FIFO
          //	- Set 0x00 to select 8 character level for RX FIFO interrupt
          // Set FCR to 0x07
          tx_buf[0] = SC16IS7X0_WRITE | (SC16IS7X0_FCR << SC16IS7X0_ADDR_SHIFT);	// R/W and address
          tx_buf[1] = 0x07;			// value
    			    tx_buf,
    			    2,
    			    NULL,
    			    0 );
    	 delay_ms( 2 );
          // RX FIFO time-out does not require setup.
       return;
    } // end of spi_configure_chip()
    // spi_send()
    // This routine sends data to a SPI connected device but requires
    // access to local control structures.
    void
       spi_send(
          uint8_t		spi_num,
          uint8_t		*data_p,
          uint8_t		length )
       uint8_t			len;
       int				msg_index;
       SPI_MSG_TX_BUF_T		*buff_p;
       if( spi_num == SPI_LEFT )
          msg_index = spi_get_tx_buff( spi_num );
          if( msg_index < 0 )
    	 NRF_LOG_DEBUG( "no tx buff avail at line %d in %s",
    		        __LINE__,
    			__FILE__ );
          buff_p = &(SPI_left_tx_buff[msg_index]);
          NRF_LOG_INFO( "spi_send() for Left port" );
       else if( spi_num == SPI_RIGHT )
          if( msg_index < 0 )
    		        __LINE__,
    			__FILE__ );
          buff_p = &(SPI_right_tx_buff[msg_index]);
          NRF_LOG_INFO( "spi_send() for Right port" );
       else if( spi_num == SPI_FLASH )
          busy_flag = &SPI_flash_busy;
          if( msg_index < 0 )
    		        __LINE__,
    			__FILE__ );
          buff_p = &(SPI_flash_buff[msg_index]);
          NRF_LOG_INFO( "spi_send() for Flash" );
          busy_flag = NULL;
       if( spi_instance )
          // No guarentee the passed in address is not on a stack
          if( length > SPI_TX_BUFFER_LEN )
    	 len = SPI_TX_BUFFER_LEN;
    	 len = length;
          memcpy( ((uint8_t *)(buff_p->data)+1), data_p, len );
          buff_p->data[0] = SC16IS7X0_THR;	// set transmit holding register address
          len++;				// account for the THR address
          buff_p->bytes = len;
          buff_p->busy = SPI_TX_IN_PROGRESS;	// mark descriptor
          *busy_flag = SPI_TX_IN_PROGRESS;		// mark hardware
    			    buff_p->data,	// tx ptr
    			    len,		// tx len
    			    NULL,		// rx ptr
    			    0 );		// rx len
        return;
     } // end of spi_send()
    // spi_get_tx_buff()
    // Return the index of a buffer descriptor or -1 if no descriptors are
    // available on the specified port
    int
       spi_get_tx_buff( uint8_t port )
       int		ret_index;
       if( port == SPI_LEFT )
          if( SPI_left_tx_buff[SPI_left_tx_enq_index].busy != SPI_AVAILABLE )
    	 ret_index = -1;
    	 ret_index = ++SPI_left_tx_enq_index;
    	 if( SPI_left_tx_enq_index > SPI_TX_BUFFERS )
       else if( port == SPI_RIGHT )
          if( SPI_right_tx_buff[SPI_right_tx_enq_index].busy != SPI_AVAILABLE )
    	 ret_index = -1;
    	 ret_index = ++SPI_right_tx_enq_index;
    	 if( SPI_right_tx_enq_index > SPI_TX_BUFFERS )
       else if( port == SPI_FLASH )
          if( SPI_flash_buff[SPI_flash_enq_index].busy != SPI_AVAILABLE )
    	 ret_index = -1;
    	 ret_index = ++SPI_flash_enq_index;
    	 if( SPI_flash_enq_index > SPI_TX_BUFFERS )
          ret_index = -1;
       return( ret_index );
    }  // end of spi_get_tx_buff()
    // spi_get_rx_buff()
    int
       spi_get_rx_buff( uint8_t port )
       int		ret_index;
          if( SPI_left_rx_buff[SPI_left_rx_enq_index].busy != SPI_AVAILABLE )
    	 ret_index = -1;
    	 ret_index = ++SPI_left_rx_enq_index;
    	 if( SPI_left_rx_enq_index > SPI_RX_BUFFERS )
          if( SPI_right_rx_buff[SPI_right_rx_enq_index].busy != SPI_AVAILABLE )
    	 ret_index = -1;
    	 ret_index = ++SPI_right_rx_enq_index;
    	 if( SPI_right_rx_enq_index > SPI_RX_BUFFERS )
    	 ret_index = -1;
          ret_index = -1;
    }  // end of spi_get_rx_buff()
    // spi_free_tx_buff()
    // Release a buffer from the specified port
    void
       spi_free_tx_buff(
          uint8_t		port,
          int		index )
       if( index < SPI_TX_BUFFERS )
    	 SPI_left_tx_buff[index].busy = SPI_AVAILABLE;
    	 SPI_left_tx_buff[index].bytes = 0;
    	 memset( SPI_left_tx_buff[index].data,
    		0,
    	 SPI_right_tx_buff[index].busy = SPI_AVAILABLE;
    	 SPI_right_tx_buff[index].bytes = 0;
    	 memset( SPI_right_tx_buff[index].data,
    		0,
    	 SPI_flash_buff[index].busy = SPI_AVAILABLE;
    	 SPI_flash_buff[index].bytes = 0;
    	 memset( SPI_flash_buff[index].data,
    		0,
    	 NRF_LOG_DEBUG( "Wrong port at line %s in %d", __LINE__, __FILE__ );
          NRF_LOG_DEBUG( "index too large at line %d in %d", __LINE__, __FILE__ );
       return;
    }// spi_free_tx_buff()
    // spi_free_rx_buff()
    void
       spi_free_rx_buff(
          uint8_t		port,
          int		index )
          if( index < SPI_RX_BUFFERS )
    		0,
    		0,
          if( index < SPI_TX_BUFFERS )	// Flash uses TX size
    		0,
       return;
    }// spi_free_rx_buff()
    // spi_rx_msg_queued()
    // Get a count of the number of spi rx messages queued
    uint8_t
       spi_rx_msg_queued(
          uint8_t			port )
       uint8_t		msg_count;
       msg_count = 0;
       return( msg_count );
    } // end of spi_rx_msg_queued()
    //  end of file spi.c
    84487.sdk_config.h
    3683.main.h
  • The answer turns out to be careful about cut-n-paste errors in the SPI controller management code.  The SPI controller dedicated to the right side port had left-over references to the SPI controller dedicated to the left side.
