Mesh relay configuration on proxy node causes assert at next startup
Hi
I have had problems when trying to update the relay status of a server node in my mesh app which is a combination of the light switch server proxy and dfu examples (plus some other stuff).
I've gone back to the default light switch server prxoy example and found that the problem is already present in that application.
If I send a config server message to disable the server's relay capabilities, I will get an entry written in flash like this:
0072000 10100408 FFFF0001 01010002 00140100 7FFFFFFF
That looks OK. But once this entry is in the flash, the node will assert at startup. This seems to be because of the NRF_MESH_IRQ_PRIORITY_LOWEST / NRF_MESH_IRQ_PRIORITY_THREAD problem described in many other threads.
At startup the call stack will look like this:
bearer_event_in_correct_irq_priority()
timer_sch_abort()
advertiser_disable()
core_tx_adv_set()
core_tx_set()
mesh_config_backend_iterate_action()
mesh_config_backend_read_all()
mesh_config_load()
mesh_stack_init()
mesh_init()
initialize()
main()
start()
And this will assert in bearer_event_in_correct_irq_priority() because there was no active irq
    if (active_irq == HAL_IRQn_NONE)
        return (m_irq_priority == NRF_MESH_IRQ_PRIORITY_THREAD || !hal_irq_is_enabled(EVENT_IRQn));
        volatile uint32_t prio = NVIC_GetPriority(active_irq);
        return (prio == m_irq_priority || (prio > m_irq_priority && !hal_irq_is_enabled(EVENT_IRQn)));
and m_irq_priority is set to NRF_MESH_IRQ_PRIORITY_LOWEST as specified in mesh_init()
If I change the priority in mesh_init() to NRF_MESH_IRQ_PRIORITY_THREAD, the startup will work OK, but as soon as I try connecting via the proxy I will get an assert in bearer_event_in_correct_irq_priority() because now the priority of SWI2_EGU2 is 7 while m_irq_priority is 15 (NRF_MESH_IRQ_PRIORITY_THREAD)
Can you help me with a suggestion how to solve this? I can't configure the relay status of my office mesh network until this is solved :-)
Thanks in advance,
P-O Håkansson
  • Just an FYI:   I am having a similar issue here:
    https://devzone.nordicsemi.com/f/nordic-q-a/38479/mesh-sdk-2-2-0-bug-in-mesh_opt_core_adv_set
    While trying to get the options API to function by changing the IRQ priority of the mesh api:
         .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_THREAD,
    the proxy interface assetrts in bearer_event_in_correct_irq_priority().
    When I use SDK 2.1.1 I do not have this issue
  • I would say you're not having a similar issue, but the same issue :-)
    Thanks for the comment,
    P-O
  • I have reported this internally. I will get back to you when I hear more from the mesh developers. They have created a new flash system in v2.2.0, so maybe this could be a reason for this priority issue.
    Update: The suggestion from R&D is to make a few changes in the mesh/stack/src/mesh_stack.c file. Below is the fixed & the original file:
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include "mesh_stack.h"
    #include "nrf_mesh_events.h"
    #include "access_config.h"
    #include "flash_manager.h"
    #include "device_state_manager.h"
    #include "config_server.h"
    #include "health_server.h"
    #include "net_state.h"
    #include "hal.h"
    #include "mesh_config.h"
    #include "mesh_config_backend_glue.h"
    #if GATT_PROXY
    #include "proxy.h"
    #include "nrf_nvic.h"
    #include "mesh_app_utils.h"
    static health_server_t m_health_server;
    static void device_reset(void)
        hal_device_reset(0);
    uint32_t mesh_stack_init(const mesh_stack_init_params_t * p_init_params,
                             bool * p_device_provisioned)
        uint32_t status;
        if (p_init_params == NULL)
            return NRF_ERROR_NULL;
        /* Initialize the mesh stack */
        status = nrf_mesh_init(&p_init_params->core);
        if (status != NRF_SUCCESS)
            return status;
        /* Initialize the access layer */
        dsm_init();
        access_init();
        /* Initialize the configuration server */
        status = config_server_init(p_init_params->models.config_server_cb);
            return status;
        /* Initialize the health server for the primary element */
        status = health_server_init(&m_health_server, 0, DEVICE_COMPANY_ID,
                                    p_init_params->models.health_server_attention_cb,
                                    p_init_params->models.p_health_server_selftest_array,
                                    p_init_params->models.health_server_num_selftests);
            return status;
        /* Give application opportunity to initialize application specific models */
        if (p_init_params->models.models_init_cb != NULL)
            p_init_params->models.models_init_cb();
        uint8_t is_nested;
        ERROR_CHECK(sd_nvic_critical_region_enter(&is_nested));
        /* Load configuration, and check if the device has already been provisioned */
        mesh_config_load();
        (void) dsm_flash_config_load();
        (void) access_flash_config_load();
        bool is_provisioned = mesh_stack_is_device_provisioned();
    #if GATT_PROXY
        if (is_provisioned)
            proxy_init();
        if (p_device_provisioned != NULL)
            *p_device_provisioned = is_provisioned;
        ERROR_CHECK(sd_nvic_critical_region_exit(is_nested));
        return NRF_SUCCESS;
    uint32_t mesh_stack_start(void)
        /* If the device is provisioned, the proxy state is automatically recovered from flash when
         * mesh_config loads the configuration. */
        uint32_t status = nrf_mesh_enable();
    #if GATT_PROXY
        if (status == NRF_SUCCESS &&
            mesh_stack_is_device_provisioned() &&
            proxy_is_enabled())
            (void) proxy_start();
        return status;
    uint32_t mesh_stack_provisioning_data_store(const nrf_mesh_prov_provisioning_data_t * p_prov_data,
                                                const uint8_t * p_devkey)
        dsm_handle_t netkey_handle, devkey_handle;
        dsm_local_unicast_address_t local_address;
        local_address.address_start = p_prov_data->address;
        local_address.count = ACCESS_ELEMENT_COUNT;
        uint32_t status;
        /* Store received provisioning data in the DSM */
        status = dsm_local_unicast_addresses_set(&local_address);
            return status;
        status = dsm_subnet_add(p_prov_data->netkey_index, p_prov_data->netkey, &netkey_handle);
            return status;
        status = dsm_devkey_add(p_prov_data->address, netkey_handle, p_devkey, &devkey_handle);
            return status;
        NRF_MESH_ERROR_CHECK(net_state_iv_index_set(p_prov_data->iv_index, p_prov_data->flags.iv_update));
        /* Bind config server to the device key */
        status = config_server_bind(devkey_handle);
            return status;
        /* Store new config server binding. */
        access_flash_config_store();
        return status;
    void mesh_stack_config_clear(void)
        access_clear();
        dsm_clear();
        net_state_reset();
    bool mesh_stack_is_device_provisioned(void)
        dsm_local_unicast_address_t addr;
        dsm_local_unicast_addresses_get(&addr);
        return (addr.address_start != NRF_MESH_ADDR_UNASSIGNED);
    #if PERSISTENT_STORAGE
    static void mesh_evt_handler(const nrf_mesh_evt_t * p_evt)
        if (p_evt->type == NRF_MESH_EVT_FLASH_STABLE)
            device_reset();
    void mesh_stack_device_reset(void)
        /* We have to do this elaborate dance to avoid nested
         * calls to bearer event. It should be possible to call this
         * function from within a bearer_event_process context.
        if (flash_manager_is_stable())
            device_reset();
            static nrf_mesh_evt_handler_t s_evt_handler = {
                .evt_cb = mesh_evt_handler
            nrf_mesh_evt_handler_add(&s_evt_handler);
    #else
        device_reset();
    #endif  /* PERSISTENT_STORAGE */
    uint32_t mesh_stack_persistence_flash_usage(const uint32_t ** pp_start, uint32_t * p_length)
        if (pp_start == NULL || p_length == NULL)
        mesh_config_backend_flash_usage_t mesh_config_usage;
        mesh_config_backend_flash_usage_get(&mesh_config_usage);
        if (mesh_config_usage.p_start != NULL)
            *pp_start = mesh_config_usage.p_start;
            /* If there's no mesh config present in flash, access holds the lowest flash area. */
            *pp_start = access_flash_area_get();
        *p_length = (((const uint8_t *) flash_manager_recovery_page_get()) - ((const uint8_t *) *pp_start) + PAGE_SIZE);
    #else
        *pp_start = NULL;
        *p_length = 0;
        return NRF_SUCCESS;
    #include "hal.h"
    #if GATT_PROXY
    #include "proxy.h"
        uint32_t status;
            return status;
        dsm_init();
        access_init();
            return status;
            return status;
        mesh_config_load();
    #if GATT_PROXY
        if (is_provisioned)
            proxy_init();
        return NRF_SUCCESS;
    #if GATT_PROXY
            proxy_is_enabled())
        return status;
        uint32_t status;
            return status;
            return status;
            return status;
            return status;
        return status;
        access_clear();
        dsm_clear();
        net_state_reset();
            device_reset();
            device_reset();
    #else
        device_reset();
    #else
        *pp_start = NULL;
        *p_length = 0;
        return NRF_SUCCESS;
    Below is the diff file:
    --- mesh_stack_orig.c	2018-09-20 15:55:47.109248666 +0200
    +++ mesh_stack_fixed.c	2018-09-20 15:55:50.709248666 +0200
    @@ -51,6 +51,9 @@
     #include "proxy.h"
    +#include "nrf_nvic.h"
    +#include "mesh_app_utils.h"
    @@ -102,6 +105,9 @@
    +    uint8_t is_nested;
    +    ERROR_CHECK(sd_nvic_critical_region_enter(&is_nested));
         mesh_config_load();
    @@ -122,6 +128,8 @@
    +    ERROR_CHECK(sd_nvic_critical_region_exit(is_nested));
         return NRF_SUCCESS;
