dimming_server example stop responding when trying to set delta = 0
Hi, to repeat the problem, you need to press button 3 and then button 2 on the board with an example of dimming_client, after that the board with dimming_server stops responding.
  1.  0> <t:          0>, main.c,  239, ----- BLE Mesh Light Switch Server Demo -----
  2.  0> <t:          0>, mesh_softdevice_init.c,  117, Initializing SoftDevice...
  3.  0> <t:          0>, mesh_softdevice_init.c,   75, Enabling BLE...
  4.  0> <t:         15>, mesh_softdevice_init.c,  109, sd_ble_enable: app_ram_base should be adjusted to 0x20002DA0
  5.  0> <t:        565>, main.c,  215, Initializing and adding models
  6.  0> <t:        570>, main.c,  250, PWM max ticks: 1600
  7.  0> <t:       5440>, main.c,  273, Device UUID : 005955BB00000000C4301495C4674564
  8.  0> <t:     828179>, main.c,  206, Successfully provisioned
  9.  0> <t:     828181>, main.c,  210, Node Address: 0x0103
  10.  0> <t:    1229922>, app_level.c,  513, Delta SET: delta: 10000  delay: 100  tt: 2000
  11.  0> <t:    1229925>, app_level.c,  516, Delta SET: initial-level: 0  present-level: 0  target-level: 10000
  12.  0> <t:    1233207>, app_level.c,  270, Selecting minimum tick interval
  13.  0> <t:    1233210>, app_level.c,  280, timeout_rtc_ticks: 33 ticks
  14.  0> <t:    1450338>, app_level.c,  513, Delta SET: delta: 0  delay: 100  tt: 2000
  15.  0> <t:    1450341>, app_level.c,  516, Delta SET: initial-level: 10000  present-level: 10000  target-level: 10000
And one more case:
If you press button 1 on the dimming_client five times, then the board with dimming_server will also stop responding.
  •  0> <t:          0>, main.c,  490, ----- BLE Mesh Light Switch Server Demo -----
  •  0> <t:        564>, main.c,  417, Initializing and adding models
  •  0> <t:       5458>, main.c,  547, Device UUID : 005955BB00000000A7123154A5976C18
  •  0> <t:        551>, main.c,  408, Successfully provisioned
  •  0> <t:        554>, main.c,  412, Node Address: 0x0103
  •  0> <t:     707226>, app_level.c,  454, SET: Level: 10000  delay: 100  tt: 2000  req-delta: 10000
  •  0> <t:     710507>, app_level.c,  270, Selecting minimum tick interval
  •  0> <t:     710510>, app_level.c,  280, timeout_rtc_ticks: 33 ticks
  •  0> <t:     888987>, app_level.c,  454, SET: Level: 20000  delay: 100  tt: 2000  req-delta: 10000
  •  0> <t:     892270>, app_level.c,  270, Selecting minimum tick interval
  •  0> <t:     892272>, app_level.c,  280, timeout_rtc_ticks: 33 ticks
  •  0> <t:    1135748>, app_level.c,  454, SET: Level: 30000  delay: 100  tt: 2000  req-delta: 10000
  •  0> <t:    1139029>, app_level.c,  270, Selecting minimum tick interval
  •  0> <t:    1139032>, app_level.c,  280, timeout_rtc_ticks: 33 ticks
  •  0> <t:    1280788>, app_level.c,  454, SET: Level: 32767  delay: 100  tt: 2000  req-delta: 2767
  •  0> <t:    1284069>, app_level.c,  270, Selecting minimum tick interval
  •  0> <t:    1284072>, app_level.c,  280, timeout_rtc_ticks: 33 ticks
  •  0> <t:    1447308>, app_level.c,  454, SET: Level: 32767  delay: 100  tt: 2000  req-delta: 0
How to fix this problem?
  • Did you provision the examples via the provisioner board or via the nRF Mesh app? Also, it's probably a good idea to adjust the RAM base to the value shown in the first log you uploaded.
  • The first log was obtained from a modified dimming_server example, I added proxy support there. This example was provisioned using the  nRF Mesh app. Second log from the original example. Provisioned with a board.
    How to adjust the RAM base?
  • Right-click on the Project in Segger Embedded Studios -> Edit Options ->change to the Common configuration -> Linker tab -> Section Placement macros -> change the RAM_START value. See if that helps at all. If not, let me know & I will take a closer look.
  • After changing the RAM_START value, the problem did not disappear.
    0> <t: 566>, main.c, 417, Initializing and adding models
    0> <t: 5454>, main.c, 547, Device UUID : 005955BB00000000A7123154A5976C18
    0> <t: 550>, main.c, 408, Successfully provisioned
    0> <t: 552>, main.c, 412, Node Address: 0x0103
    0> <t: 348254>, app_level.c, 513, Delta SET: delta: 10000 delay: 100 tt: 2000
    0> <t: 348258>, app_level.c, 516, Delta SET: initial-level: 0 present-level: 0 target-level: 10000
    0> <t: 351539>, app_level.c, 270, Selecting minimum tick interval
    0> <t: 351542>, app_level.c, 280, timeout_rtc_ticks: 33 ticks
    0> <t: 467073>, app_level.c, 513, Delta SET: delta: 0 delay: 100 tt: 2000
    0> <t: 467076>, app_level.c, 516, Delta SET: initial-level: 10000 present-level: 10000 target-level: 10000
  • Inside the function a_transition_start, in the calculation of transition_step_us the division into zero occurs.
    Please tell me the best way to fix this?
       github.com/.../app_level.c
1 2
