Use nRF52 DK or nRF52 USB Dongle without nRFConnect
is it possible to use the nRF52 dev kit and/or the nRF52 Dongle (nRF52840 Dongle) wiith the dongle firmware without nRFConnect?
Background:
We want to use a nRF52 dev kit or the nRF52 dongle with our test environment.
The functionality of the dongle firmware (firmware flashed with nRFConnect) is what we need in our test environment, to scan, connect, pair/bond, read, write, ...
After a quick research I neither found the dongle project, nor the api description to use this firmware via the serial com port.
Thanks for any help and best regards,
Markus
    What you are looking for is probably the pc-ble-driver found here.
    yes, thank you. That's one part what I'm looking for.
    The other part would be the source code of the connectivity firmware. At the pc-ble-driver example is only the connectivity firmware hex.
    Is the source code of the connectivity firmware available?
    Thanks
  • Unfortunately, the source code of the connectivity firmware is not available.
  • Short Update:
    Found the source code in the SDK (15):
    <SDK_Folder>\examples\connectivity
    This is also the used source code of the .hex on the pc-ble-driver repo (git) merged with the soft device.
  • Hi
    I'm wondering did you succeed?
    I flashed the hex file "ble_connectivity_s140_usb_hci_pca10059" via nRFConnect applic, and the sub applic Programming (Experimental), but the nRF52840 dongle is no longer usable as it is no longer recognized nor the red LED on the dongle is blinking.
    I'm also not able to install the USB driver as Windows fails to install them?
    Any ideas? It seems the dongle's bootloader is ruined. Pressing the reset button on the dongle does NOT help either. Nor restarting Windows 10 or putting it in a different USB port.
    Frank
    UPDATE:
    I tried to restore with Zadig as explained in devzone.nordicsemi.com/.../144952, re-installing the libusb-win32,
    I'm getting this now again visible in Windows Device Manager...
    But the nRFConnect applic still complains, and nothing further can be done... Disappointed
    However maybe with nRFgoStudio I can restore the boatloader....
    Is this possible without doing further damage... ?
    Thanks in advance,
    UPDATE:
    DFU trigger not there, so no red blinking, so not able to flash hex files...
    ADDED log file when using nRFConnect and programming applics:
    2018-10-17T15:52:10.500Z INFO Application data folder: C:\Users\FRV\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2018-10-17T15:52:10.581Z DEBUG App pc-nrfconnect-programmer v1.0.0-experimental.5 official
    2018-10-17T15:52:10.581Z DEBUG App path: C:\Users\FRV\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2018-10-17T15:52:10.581Z DEBUG nRFConnect 2.5.0 is supported by the app (^2.5.0)
    2018-10-17T15:52:10.581Z DEBUG nRFConnect path: C:\Users\FRV\AppData\Local\Programs\nrfconnect\resources\app.asar
    2018-10-17T15:52:10.581Z DEBUG HomeDir: C:\Users\FRV
    2018-10-17T15:52:10.581Z DEBUG TmpDir: C:\Users\FRV\AppData\Local\Temp
    2018-10-17T15:52:10.587Z INFO Using nrfjprog library 9.7.1, pc-nrfjprog-js 1.2.0
    2018-10-17T15:52:10.610Z ERROR Error while probing usb device at bus.address 1.30: LIBUSB_ERROR_NOT_FOUND. Please check that a libusb-compatible kernel driver is bound to this device, see https://github.com/NordicSemiconductor/pc-nrfconnect-core/blob/master/doc/win32-usb-troubleshoot.md
    2018-10-17T15:52:10.610Z VERBOSE Could not fetch serial number for serial port at COM3
    2018-10-17T15:52:15.827Z ERROR Unsupported device. The detected device is neither JLink device nor Nordic USB device.
    2018-10-17T15:53:01.452Z INFO Parsing .hex file:  C:\Users\FRV\NORDIC\pc-ble-driver-master\sdk\s150\examples\connectivity\ble_connectivity\hex\ble_connectivity_s140_usb_hci_pca10059.hex
    2018-10-17T15:53:01.480Z INFO File was last modified at  3/22/2018, 3:24:22 PM
    2018-10-17T15:53:01.667Z INFO Data block: 0x00000000-0x00000A18 (0x00000A18  bytes long)
    2018-10-17T15:53:01.667Z INFO Data block: 0x00001000-0x000253C8 (0x000243C8  bytes long)
    2018-10-17T15:53:01.667Z INFO Data block: 0x00026000-0x00037140 (0x00011140  bytes long)
    2018-10-17T15:53:01.671Z INFO SoftDevice detected, id 0xA9 (S140 v6.0.0)
    Br,
    Frank
