Fatal Error on I2C Sensor Initialization
Segger Embedded Studi, SDK 15.2, Windows 10
Nordic NRF52DK PCA 10040 1. 2 .4
Hello again everyone, I have gotten farther with my previous issues of not being able to access individual register with the Bosch IMU (BMX055). I have used an example found here that specifically applies to my application for guidance as well. Another example of a read routine using the NRF52 and the same IMU was found here, but this routine also didn't work.
I have used code from this nordic thread for reading and writing functions through i2c but have had no success with them. I will post the code in question
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "blebugIMU.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR (0x90U >> 1)
#define LM75B_REG_TEMP 0x00U
#define LM75B_REG_CONF 0x01U
#define LM75B_REG_THYST 0x02U
#define LM75B_REG_TOS 0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
* @brief Function for setting active mode on MMA7660 accelerometer.
* @brief Function for writing to registers on the MPU-6050.
ret_code_t bmx055_I2C_register_write(uint8_t reg_addr, uint8_t * p_tx_data, uint8_t bytes)
ret_code_t ret_code;
uint8_t tx_data[bytes+1];
tx_data[0] = reg_addr;
for(uint8_t i = 0 ; i<bytes ; i++)
tx_data[i+1] = p_tx_data[i];
ret_code = nrf_drv_twi_tx(&m_twi, BMX055_GYRO_ADDRESS, tx_data, sizeof(tx_data), false);
return ret_code;
* @brief Function for reading from registers on the MPU-6050.
ret_code_t bmx055_I2C_register_read( uint8_t reg_addr, uint8_t * p_rx_data, uint32_t bytes)
ret_code = nrf_drv_twi_tx(&m_twi,BMX055_GYRO_ADDRESS, &reg_addr, 1, false);
if(ret_code != NRF_SUCCESS)
return ret_code;
ret_code = nrf_drv_twi_rx(&m_twi, BMX055_GYRO_ADDRESS, p_rx_data, bytes);
return ret_code;
void bmx055_get_device_id (uint8_t * p_dev_id)
ret_code_t err_code;
uint8_t rx_data;
// Read the I2C Address of the BMX055 from the WHO_AM_I register
err_code = bmx055_I2C_register_read(BMX055_ACC_WHOAMI,&rx_data,1);
*p_dev_id = rx_data;
void bmx055_read_acc(int16_t * p_x_val, int16_t * p_y_val, int16_t * p_z_val)
// Raw accelerometer measurements buffer
uint8_t acc_data[6];
// Read the six accelerometer data registers starting from ACCEL_XOUT_H
err_code = bmx055_I2C_register_read(BMX055_ACC_D_X_LSB,acc_data,sizeof(acc_data));
/* Combine the two 8-bit data registers to a 16-bit value
for each axis by left shifting ACCEL_xOUT_H eight times
and OR it with ACCEL_xOUT_L. */
*p_x_val = (acc_data[0]<<8)|acc_data[1];
*p_y_val = (acc_data[2]<<8)|acc_data[3];
*p_z_val = (acc_data[4]<<8)|acc_data[5];
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
void bmx055_read_gyro(int16_t * p_x_gyro, int16_t * p_y_gyro, int16_t * p_z_gyro)
uint8_t gyro_data[6];
//Read the 6 gyroscope data registers starting from GYRO_XOUT_H
err_code = bmx055_I2C_register_read(BMX055_GYRO_RATE_X_LSB, gyro_data, sizeof(gyro_data));
for each axis by left shifting GYRO_xOUT_H eight times
and OR it with GYRO_xOUT_L. */
*p_x_gyro = (gyro_data[0]<<8)|gyro_data[1];
*p_y_gyro = (gyro_data[2]<<8)|gyro_data[3];
*p_z_gyro = (gyro_data[4]<<8)|gyro_data[5];
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(m_sample);
m_xfer_done = true;
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_lm75b_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
void bmx055_init (void)
uint8_t tx_data = 0xB6;
// Write one to the BMX055_ACC_BGW_SOFTRESET and register to wake up the gyro and acc
err_code = bmx055_I2C_register_write(BMX055_ACC_BGW_SOFTRESET, &tx_data, 1);
err_code = bmx055_I2C_register_write(BMX055_GYRO_BGW_SOFTRESET, &tx_data, 1);
* @brief Function for reading data from temperature sensor.
static void read_sensor_data()
/* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_init();
bmx055_init();
uint8_t device_id;
// bmx055_get_device_id(&device_id);
int16_t x_val;
int16_t y_val;
int16_t z_val;
bmx055_read_acc(&x_val, &y_val, &z_val);
int16_t x_gyro;
int16_t y_gyro;
int16_t z_gyro;
// Read Gyroscope Data
bmx055_read_gyro(&x_gyro, &y_gyro, &z_gyro);
while (true)
nrf_delay_ms(500);
do
__WFE();
}while (m_xfer_done == false);
read_sensor_data();
NRF_LOG_FLUSH();
As you will notice, I have commented out the other functions that I am not using and have narrowed down the fatal error occurrence to the instantiation of BMX055. It seems that my writing and reading routines themselves are to blame yet I don't know why. All of the pin addresses of the BMX055 are stored in a header file I put together which I will add below for reference. I would appreciate any help in getting these values sorted.
/* This header file was put tofether to include register and address definitions of the BMX055 IMU
   Pin defintions and useful enumerations are included */
#define BMX055_ACC_WHOAMI        0x00   // should return 0xFA
//#define BMX055_ACC_Reserved    0x01
#define BMX055_ACC_D_X_LSB       0x02
#define BMX055_ACC_D_X_MSB       0x03
#define BMX055_ACC_D_Y_LSB       0x04
#define BMX055_ACC_D_Y_MSB       0x05
#define BMX055_ACC_D_Z_LSB       0x06
#define BMX055_ACC_D_Z_MSB       0x07
#define BMX055_ACC_D_TEMP        0x08
#define BMX055_ACC_INT_STATUS_0  0x09
#define BMX055_ACC_INT_STATUS_1  0x0A
#define BMX055_ACC_INT_STATUS_2  0x0B
#define BMX055_ACC_INT_STATUS_3  0x0C
//#define BMX055_ACC_Reserved    0x0D
#define BMX055_ACC_FIFO_STATUS   0x0E
#define BMX055_ACC_PMU_RANGE     0x0F
#define BMX055_ACC_PMU_BW        0x10
#define BMX055_ACC_PMU_LPW       0x11
#define BMX055_ACC_PMU_LOW_POWER 0x12
#define BMX055_ACC_D_HBW         0x13
#define BMX055_ACC_BGW_SOFTRESET 0x14
//#define BMX055_ACC_Reserved    0x15
#define BMX055_ACC_INT_EN_0      0x16
#define BMX055_ACC_INT_EN_1      0x17
#define BMX055_ACC_INT_EN_2      0x18
#define BMX055_ACC_INT_MAP_0     0x19
#define BMX055_ACC_INT_MAP_1     0x1A
#define BMX055_ACC_INT_MAP_2     0x1B
//#define BMX055_ACC_Reserved    0x1C
//#define BMX055_ACC_Reserved    0x1D
#define BMX055_ACC_INT_SRC       0x1E
//#define BMX055_ACC_Reserved    0x1F
#define BMX055_ACC_INT_OUT_CTRL  0x20
#define BMX055_ACC_INT_RST_LATCH 0x21
#define BMX055_ACC_INT_0         0x22
#define BMX055_ACC_INT_1         0x23
#define BMX055_ACC_INT_2         0x24
#define BMX055_ACC_INT_3         0x25
#define BMX055_ACC_INT_4         0x26
#define BMX055_ACC_INT_5         0x27
#define BMX055_ACC_INT_6         0x28
#define BMX055_ACC_INT_7         0x29
#define BMX055_ACC_INT_8         0x2A
#define BMX055_ACC_INT_9         0x2B
#define BMX055_ACC_INT_A         0x2C
#define BMX055_ACC_INT_B         0x2D
#define BMX055_ACC_INT_C         0x2E
#define BMX055_ACC_INT_D         0x2F
#define BMX055_ACC_FIFO_CONFIG_0 0x30
//#define BMX055_ACC_Reserved    0x31
#define BMX055_ACC_PMU_SELF_TEST 0x32
#define BMX055_ACC_TRIM_NVM_CTRL 0x33
#define BMX055_ACC_BGW_SPI3_WDT  0x34
//#define BMX055_ACC_Reserved    0x35
#define BMX055_ACC_OFC_CTRL      0x36
#define BMX055_ACC_OFC_SETTING   0x37
#define BMX055_ACC_OFC_OFFSET_X  0x38
#define BMX055_ACC_OFC_OFFSET_Y  0x39
#define BMX055_ACC_OFC_OFFSET_Z  0x3A
#define BMX055_ACC_TRIM_GPO      0x3B
#define BMX055_ACC_TRIM_GP1      0x3C
//#define BMX055_ACC_Reserved    0x3D
#define BMX055_ACC_FIFO_CONFIG_1 0x3E
#define BMX055_ACC_FIFO_DATA     0x3F
// BMX055 Gyroscope Registers
#define BMX055_GYRO_WHOAMI           0x00  // should return 0x0F
//#define BMX055_GYRO_Reserved       0x01
#define BMX055_GYRO_RATE_X_LSB       0x02
#define BMX055_GYRO_RATE_X_MSB       0x03
#define BMX055_GYRO_RATE_Y_LSB       0x04
#define BMX055_GYRO_RATE_Y_MSB       0x05
#define BMX055_GYRO_RATE_Z_LSB       0x06
#define BMX055_GYRO_RATE_Z_MSB       0x07
//#define BMX055_GYRO_Reserved       0x08
#define BMX055_GYRO_INT_STATUS_0  0x09
#define BMX055_GYRO_INT_STATUS_1  0x0A
#define BMX055_GYRO_INT_STATUS_2  0x0B
#define BMX055_GYRO_INT_STATUS_3  0x0C
//#define BMX055_GYRO_Reserved    0x0D
#define BMX055_GYRO_FIFO_STATUS   0x0E
#define BMX055_GYRO_RANGE         0x0F
#define BMX055_GYRO_BW            0x10
#define BMX055_GYRO_LPM1          0x11
#define BMX055_GYRO_LPM2          0x12
#define BMX055_GYRO_RATE_HBW      0x13
#define BMX055_GYRO_BGW_SOFTRESET 0x14
#define BMX055_GYRO_INT_EN_0      0x15
#define BMX055_GYRO_INT_EN_1      0x16
#define BMX055_GYRO_INT_MAP_0     0x17
#define BMX055_GYRO_INT_MAP_1     0x18
#define BMX055_GYRO_INT_MAP_2     0x19
#define BMX055_GYRO_INT_SRC_1     0x1A
#define BMX055_GYRO_INT_SRC_2     0x1B
#define BMX055_GYRO_INT_SRC_3     0x1C
//#define BMX055_GYRO_Reserved    0x1D
#define BMX055_GYRO_FIFO_EN       0x1E
//#define BMX055_GYRO_Reserved    0x1F
//#define BMX055_GYRO_Reserved    0x20
#define BMX055_GYRO_INT_RST_LATCH 0x21
#define BMX055_GYRO_HIGH_TH_X     0x22
#define BMX055_GYRO_HIGH_DUR_X    0x23
#define BMX055_GYRO_HIGH_TH_Y     0x24
#define BMX055_GYRO_HIGH_DUR_Y    0x25
#define BMX055_GYRO_HIGH_TH_Z     0x26
#define BMX055_GYRO_HIGH_DUR_Z    0x27
//#define BMX055_GYRO_Reserved    0x28
//#define BMX055_GYRO_Reserved    0x29
//#define BMX055_GYRO_Reserved    0x2A
#define BMX055_GYRO_SOC           0x31
#define BMX055_GYRO_A_FOC         0x32
#define BMX055_GYRO_TRIM_NVM_CTRL 0x33
#define BMX055_GYRO_BGW_SPI3_WDT  0x34
//#define BMX055_GYRO_Reserved    0x35
#define BMX055_GYRO_OFC1          0x36
#define BMX055_GYRO_OFC2          0x37
#define BMX055_GYRO_OFC3          0x38
#define BMX055_GYRO_OFC4          0x39
#define BMX055_GYRO_TRIM_GP0      0x3A
#define BMX055_GYRO_TRIM_GP1      0x3B
#define BMX055_GYRO_BIST          0x3C
#define BMX055_GYRO_FIFO_CONFIG_0 0x3D
#define BMX055_GYRO_FIFO_CONFIG_1 0x3E
// BMX055 magnetometer registers
#define BMX055_MAG_WHOAMI         0x40  // should return 0x32
#define BMX055_MAG_Reserved       0x41
#define BMX055_MAG_XOUT_LSB       0x42
#define BMX055_MAG_XOUT_MSB       0x43
#define BMX055_MAG_YOUT_LSB       0x44
#define BMX055_MAG_YOUT_MSB       0x45
#define BMX055_MAG_ZOUT_LSB       0x46
#define BMX055_MAG_ZOUT_MSB       0x47
#define BMX055_MAG_ROUT_LSB       0x48
#define BMX055_MAG_ROUT_MSB       0x49
#define BMX055_MAG_INT_STATUS     0x4A
#define BMX055_MAG_PWR_CNTL1      0x4B
#define BMX055_MAG_PWR_CNTL2      0x4C
#define BMX055_MAG_INT_EN_1       0x4D
#define BMX055_MAG_INT_EN_2       0x4E
#define BMX055_MAG_LOW_THS        0x4F
#define BMX055_MAG_HIGH_THS       0x50
#define BMX055_MAG_REP_XY         0x51
#define BMX055_MAG_REP_Z          0x52
/* Trim Extended Registers */
#define BMM050_DIG_X1             0x5D // needed for magnetic field calculation
#define BMM050_DIG_Y1             0x5E
#define BMM050_DIG_Z4_LSB         0x62
#define BMM050_DIG_Z4_MSB         0x63
#define BMM050_DIG_X2             0x64
#define BMM050_DIG_Y2             0x65
#define BMM050_DIG_Z2_LSB         0x68
#define BMM050_DIG_Z2_MSB         0x69
#define BMM050_DIG_Z1_LSB         0x6A
#define BMM050_DIG_Z1_MSB         0x6B
#define BMM050_DIG_XYZ1_LSB       0x6C
#define BMM050_DIG_XYZ1_MSB       0x6D
#define BMM050_DIG_Z3_LSB         0x6E
#define BMM050_DIG_Z3_MSB         0x6F
#define BMM050_DIG_XY2            0x70
#define BMM050_DIG_XY1            0x71
// Seven-bit device addresses are ACC = 0x18, GYRO = 0x68, MAG = 0x10
#define BMX055_ACC_ADDRESS  0x18   // Address of BMX055 accelerometer
#define BMX055_GYRO_ADDRESS 0x68 // Address of BMX055 gyroscope
#define BMX055_MAG_ADDRESS  0x10   // Address of BMX055 magnetometer
#define MS5637_ADDRESS      0x76   // Address of altimeter
#define AFS_2G  0x03
#define AFS_4G  0x05
#define AFS_8G  0x08
#define AFS_16G 0x0C
