Hello there,
I'm developing a C++ application on the BLE654 development bord which shall be able to generate and send 100+ BLE notifications per second on a single BLE connection.
On my first try it managed 5.
After some digging, I found that the soft device (s140, Ver 6.1.0) got a BLE_GAP_EVT_CONN_PARAM_UPDATE event, which set the minimum and maximum connection interval to 200 ms, wich was the defined MAX_CONN_INTERVAL (the code burrowed from the blinky example). After setting this to 20 ms I could get (close to) 50 notifications per second, but further decreasing the value again reduced the throughput (maybe the Android on the 'other side' of the BLE connection prohibited a further decrease).
I read somewere that soft devices from s120 up were able to process up to 6 notifications in a 7.5 ms connectipon interval, but here it looks as is the sd only does one notification per interval. What can/must be done to further increase the througput to reach at least 100 notifications per second?
Notes:
-in our application, we send the notifications with sd_ble_gatts_hvx(). I don't have exact numbers, but the internal queue of the soft device seemd rather small and we got a NRF_ERROR_RESOURCES error quickly, after wich we wait for a BLE_GATTS_EVT_HVN_TX_COMPLETE until we call sd_ble_gatts_hvx() again. I am certain the soft device at all time had notifications in its queue.
-as recipient of the notifications we used two tablets with Android 6.0.1 and 7.0, respectively. Both showed similar throughputs, and the final application shall also run on an Android device.
Lasse
