How to increase notification throughput on nRF52840?
Hello there,
I'm developing a C++ application on the BLE654 development bord which shall be able to generate and send 100+ BLE notifications per second on a single BLE connection.
On my first try it managed 5.
After some digging, I found that the soft device (s140, Ver 6.1.0) got a BLE_GAP_EVT_CONN_PARAM_UPDATE event, which set the minimum and maximum connection interval to 200 ms, wich was the defined MAX_CONN_INTERVAL (the code burrowed from the blinky example). After setting this to 20 ms I could get (close to) 50 notifications per second, but further decreasing the value again reduced the throughput (maybe the Android on the 'other side' of the BLE connection prohibited a further decrease).
I read somewere that soft devices from s120 up were able to process up to 6 notifications in a 7.5 ms connectipon interval, but here it looks as is the sd only does one notification per interval. What can/must be done to further increase the througput to reach at least 100 notifications per second?
Notes:
-in our application, we send the notifications with sd_ble_gatts_hvx(). I don't have exact numbers, but the internal queue of the soft device seemd rather small and we got a NRF_ERROR_RESOURCES error quickly, after wich we wait for a BLE_GATTS_EVT_HVN_TX_COMPLETE until we call sd_ble_gatts_hvx() again. I am certain the soft device at all time had notifications in its queue.
-as recipient of the notifications we used two tablets with Android 6.0.1 and 7.0, respectively. Both showed similar throughputs, and the final application shall also run on an Android device.
     Lasse
  • Ok. But when you try to send one single string of length 80 bytes, or even longer, what is shown in nRF Connect? do you see the entire string?
    BR,
    Edvin
  • Hi Edvin,
    Using nRF Connect I see the same *censored* 20 Bytes I saw with any other application so far.
    However, there is something curious: If I use the "Request MTU" command from the Menu besides "SERVER" to increase the MTU to x Bytes, nRF Connect shows x-3 Bytes (the header, I know) of my string. That's great, but...
    -The gatt_evt_handler() of my device still says that the nRF Connect requested 0xF7 Bytes regardless of the Value I entered. I have no confirmation that the actual x Value was send to the device.
    -Only the first time I use "Request MTU" triggers the gatt_evt_handler(). I have to dis- and reconnect the device for it to trigger the gatt_evt_handler() again.
    -If I increase the MTU twice (i.e to 40 and then 60 Bytes) the nRF Connect still only shows 37 Bytes. If I increase and then decrease the MTU (i.e to 40 ant then 30 Bytes) the nRF Connect doesn't show any new notifications (allthoug it will again if i increase the MUT back to 40 or more).
    Do you know if this behaviour is a (misunderstood) feature or a bug in the nRF Connect?
    I'd love to send you a sniffer log of this, but still, we can't get the sniffer to work.
         Lasse
  • Hello Lasse,
    I am sorry, but I am starting to loose track of where we are. Your phone supports a higher MTU, and the ble_app_uart example from SDK15.2.0 does as well, so there is something missing from your project that is not allowing it, I think.
    Do you have gatt_init as in the ble_app_uart example?
    void gatt_init(void)
        ret_code_t err_code;
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE); //247
    What is your NRF_SDH_BLE_GAP_EVENT_LENGTH in sdk_config.h?
    Can you compare your gatt values from the log in the ble_app_uart example and your example?
    In both projects, set #define NRF_LOG_DEFAULT_LEVEL 4 in sdk_config.h, and make sure you are looking at the log, and not the uart output in ble_app_uart. You need to check the RTT log.
    Try to send a string larger than 20 bytes using the ble_app_uart example. You should see a string longer than 20 *cencored* bytes in the mobile application. Do you see a string longer than this in your example?
  • Hello Edvin,
    I finally managed to nail down the problem. It seems that the only thing wrong with my application was that I set BLE_GATT_ATT_MTU_DEFAULT to 247. This seems to produce some undefined/unexpected behaviour of yout BLE stack.
    I now have
    BLE_GATT_ATT_MTU_DEFAULT          23
    NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
    The actual MTU of course is lower than 247 Bytes thanks to the phone on the other side.
    Still, I now can accumuate my data and can send one notification instead of ten, which is a tremendous help. Btw, I still use sd_ble_gatts_hvx() for this, I didn't have to use the nus.
    Thanks for your help (and patience) in the last weeks!
    Best Regards,
         Lasse
